FS: II 62/65/.70 internally gated charger
smokinstroker
Texas
Yes for a 6.0
If you pick this up I'll throw in my pedistal for free.
It's just been rebuilt and sitting in the box.
Steal for sure
6.0dirtworker
Cloud 9
smokinstroker
Texas
turbo needs a drain and feed from industrial. I have a t3 to v-band adapter that should work for it.
smokinstroker
Texas
just talked to industrial, should be roughly 150-200 for the drain and feed.
a sponsor may be able to get it cheaper.
smokinstroker
Texas
you should be ok, there are some people that have ran 190s with this. a 175/75 should be a good injector with quick spool.
Countryboy07
N. Manchester, IN
Has II updated the drain line? When I had a charger like this on my 6.0 the drain line was absolutly terrible. I ran this turbo with my 190/100's and it ran pretty good! David you should buy it!
Extended Power
You have the vband connector and hose end for it as well?
If not, I know BD Power sells everything separately.
