tbsimmons
Got home from a trip pulling the fiver.
Noticed that the truck had a different noise coming out of the driver side fender. It is the same air noise that the exhaust has without the rumble of the engine.
I searched and cant find any broken pipe, bellows, soot, etc. on the firewall or back of the engine.
When you unlplug the VGT to the turbo it goes away, wont come back even driving with it unplugged. When you move the arm back towards the spot that it is at idle with the VGT plugged in the noise comes back. It is almost like the turbo is dumping air at idle. The arm moves freely in both directions.
Truck has a DPF and EGR Delete.
Still runs fine and full boost. Pulled fine all the way home. Other than the sound it runs just like normal.
Is it possible for the VGT to get out of adjustment?
If so how do you clear it?
I have loaded different tunes. Tow on Eric's tow tune and loaded the street tune and same noise.
