Go Back   PowerStrokeArmy > Power Strokes > 6.4 Aftermarket > MCC / DIY Tuning for 6.4
Reply
Thread Tools Display Modes
  #1
Old 01-02-2013, 01:53 PM
drunk on diesel drunk on diesel is offline
Sponsor
Member's Gallery
Default Trans tuning thread?
Can this be it?
I'm trying to wrap my head around why the canned S2M lugs into lockup so bad at part throttle vs. the factory EZ tuning.
I realize the torque scale is way off between factory tuning and a big tune like HD300, so I'm sure that's a factor.
I also realize that H&S uses hot mode to get 3rd lockup at WOT, but looking at the minimum speed ratio between the factory tuning and the H&S hot mode, there's a big difference there. I'm assuming that speed ratio is the difference between engine rpm and input rpm?
Can I just scooch the speed ratio higher and get closer to OEM engagement at part throttle?
__________________
**** 6.* **** cab **** "The Big Taco" *** & *** ******. Tunes by ******* **********. Full ***** ** ***** * ****** * ********* with ***, ***, ****, and ****. Custom powdercoated ****** *** coming soon!!!
  #2
Old 01-02-2013, 08:14 PM
Dzchey21's Avatar
Dzchey21 Dzchey21 is offline
Super Moderator
Member's Gallery
Default
The minimum speed ration does indeed have to do with when the torque converter will lock...but its more of an efficiency thing for when towing or under full power, this makes the converter lock later to help save the converter. So eccentially if it doesnt pass this effiecency ratio it will not lock untill its at this ratio.
What i would suggest is going thru the lock up tables and raising the mph of the lock up point
__________________
2017 F-350 DRW Platinum stock for now
1979 F-150 6.0 Swap in progress, 86mm LP turbo, 04 frame and interior
  #3
Old 01-02-2013, 08:26 PM
scorpion6.7 scorpion6.7 is offline
Member's Gallery
Default
has anyone ever heard of eccc strategy?
some call it ec cubed?
  #4
Old 01-02-2013, 08:28 PM
Member's Gallery
Default
it is basically a startegy that starting in 2nd sometimes 3rd gear partially slips the tcc, it is why most manufacturers use black high carbon content clutches.
Starting with partial coverage in 1997 and continuing with 1998 and later vehicles, the TCC strategy changed again. Similar to what we've just covered, the new strategy allows for the converter clutch to begin slipping as early as 2nd gear and to continue slipping until a cruising speed of approximately 54 mph has been reached. For this type of strategy to be successful, the type of material used for the clutch had to change. It should be noted that the original ON/OFF strategy utilized a cellulose-based converter clutch, otherwise known as a paper-lined clutch. The second strategy utilized a Kevlar-based lining (several designs, depending on 2WD, 4WD, heavy-duty, etc.) and for this third strategy, a carbon-based woven lining is used. This type of converter clutch apply is referred to as Electronically Controlled Clutch Capacity (ECCC), or EC 3 , for short.
In addition to these changes in material, the tension of the damper plate springs, which are integral to the clutch disc, was also altered. These springs act as shock absorbers, and their tension has progressively lightened from the ON/OFF strategy all the way through to the ECCC strategy. Should anyone modify the PWM or ECCC strategy to function as an ON/OFF apply while using a converter with a damper plate designed for PWM or ECCC, a tail end bump on the apply of the clutch would be felt, possibly resulting in a customer complaint. In some cases, a code for Converter Clutch Stuck On may also occur as a result of this modification to ECCC strategy vehicles.
  #5
Old 01-02-2013, 08:30 PM
Member's Gallery
Default
also helps with milage as there is less slippage
  #6
Old 01-02-2013, 08:31 PM
Member's Gallery
Default
i bet h&s turns on hot mode to limt slippage as a hot mode will apply tcc early to cool trans and be a on/off strategy
  #7
Old 01-02-2013, 10:26 PM
Sponsor
Member's Gallery
Default
Quote:
they turn on hot mode because the normal tuning strategy won't lock the converter in lower gears. they want to be able to lock the converter at WOT, so they just lower the "hot" temp threshold.
__________________
  #8
Old 01-02-2013, 10:34 PM
Sponsor
Member's Gallery
Default
the lock up tables honestly don't make any sense... they are commanding lockup in 5th at like 45mph, but it doesn't happen until 51/52 at the very earliest.
my speedo is perfect per GPS, and when I watch the speed displayed by the MM, it matches my dash speedo perfectly
I can only assume it has to do with the speed ratio. I think the biggest issue I'm going to have to deal with is the torque/throttle scale. If I turn the power down to "no power", the shifting is a lot better. The problem is HD300 makes the same power at 25% throttle that the stock truck makes at 65%
And H&S shift points and lockup are pretty close to stock.
One thing I've thought about doing is tap into the trans temp circuit so that I can toggle between the regular and hot maps
__________________
  #9
Old 01-03-2013, 06:01 AM
Dzchey21's Avatar
Super Moderator
Member's Gallery
Default
Is the delay for lock up after the 4-5 shift set to 0
The converter should always be locked in 5th unless your in tow Haul with your foot to the floor
__________________
  #10
Old 01-03-2013, 07:35 AM
Sponsor
Member's Gallery
Default
It is set to 0, but I don't want the converter to always be locked in 5th... It's not like that from the factory.
I typically run S2M. I don't like the 4th gear lockup schedules because driving through town I'm sitting at 1800-2000 in 4th vs. 1300 in 5th unlocked.
But when you floor it, it still locks in 3rd/4th/5th.
My truck weighs 9500lbs. When the converter locks in 5th at part throttle at 55, pulling the revs down from 2200-2400 to 1700, it's annoying. It pulls the turbos down, the truck hazes, and I don't care to imagine the slippage going on in the converter. I'll accept abuse to the converter when I'm at WOT, but I see no need to tax it during normal driving
__________________
  #11
Old 01-04-2013, 11:40 AM
Fast-6.0's Avatar
Fast-6.0 Fast-6.0 is offline
Lieutenant
Member's Gallery
Default
Look at the stock converter lockup tables for non "hot" lockup. Then just copy and paste them into the hot lockup section. You will now have the same lockup commands. Or return the tables that dictate when to enter hot mode, back to stock. Then just set your 5th lockup to match a stock file. Make sense?
I have adjusted the speed ratio trying to get the converter to lock sooner without much luck but I would set it to the lower of the two % to insure its not the reason.
__________________
www.elitedieselengineering.com
  #12
Old 01-04-2013, 11:44 AM
Gearhead Gearhead is offline
Major
Member's Gallery
Default
what are your guys having trouble with on the lockup. I always set mine to like .5 and let the speed vs throttle position tables do the rest.
__________________
Matt Robinson
******** Automotive Performance
www.********automotiveperformance.com
  #13
Old 01-04-2013, 08:34 PM
08twinturbo's Avatar
08twinturbo 08twinturbo is offline
Lieutenant
Member's Gallery
Default
I actually have good luck with the s1l schedule but I dont feel the stock shifting is firm enough not to slip. My kem 345 was very quick and snappy where the h&s almost shifts like stock until you floor it. What are you guys adjusting to firm the shifts up and make them quicker? Thanks.
  #14
Old 01-17-2013, 05:01 PM
Dzchey21's Avatar
Super Moderator
Member's Gallery
Default
Forest did you ever come up with a fix for this?
__________________
  #15
Old 01-17-2013, 09:27 PM
Dzchey21's Avatar
Super Moderator
Member's Gallery
Default
so i did some looking and if you look at the calulated torque table at the very top it looks to me like at the 1300-1700 rpm levels have far too low torque readings? I upped them and smoothed it but im not sure it helps, but it might make a difference for the stock to hot tables less noticable.
And i think what you need to do to get what you want is lower all the shift points, but raise the torque converter lock up speed so the truck will actually cruise in 5th with the converter unlocked.
Also it apears that for whatever reason the speed tables are not right. looks like they might be 5-10 mph off depending on gear ratio, tire size ect.
I know with sct there was two ways to calibrate the speedo, one was for the transmission and one was for the actual speedometer, i wonder if we are only changing one and thats why things arent working quite like we think they should?
__________________
  #16
Old 01-18-2013, 08:36 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Major
Member's Gallery
Default
Why would you want to have the torque converter unlocked cruising in 5th gear? That's just wasting fuel.
__________________
Mark
Former Ford Automatic Transmission Engineer
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
  #17
Old 01-18-2013, 08:45 AM
Sponsor
Member's Gallery
Default
Quote:
1300rpm wastes more fuel than 2000rpm? interesting
__________________
  #18
Old 01-18-2013, 03:12 PM
UpstateDieselGuy's Avatar
UpstateDieselGuy UpstateDieselGuy is offline
Lieutenant
Member's Gallery
Default
Quote:
I have never seen the engine speed lower with the converter unlocked? Are you sure you didn't miss read what he said?
__________________
2015 F-350 Extended Cab Short Box Lariat; Tuxedo Black with Black Leather Interior; 8 1/2' Fisher MM2
  #19
Old 03-31-2013, 09:05 AM
Sponsor
Member's Gallery
Default
If I'm cruising unlocked in 5th at 1300 RPM, I'm clearly driving too slow to be locked in 5th... I would be at 900RPM.
But the tune doesn't allow that, so my only alternative is to be in 4th at 2000rpm
__________________
  #20
Old 05-29-2013, 10:08 PM
Dzchey21's Avatar
Super Moderator
Member's Gallery
Default
well i have done just about everything i can to try and solve my unlock/lock during the shift and cant seam to figure it out, anyone else been messing with it?
__________________
  #21
Dzchey21's Avatar
Super Moderator
Member's Gallery
Default
im wondering if it has something to do with the torque/inertia phases i see the stock files and h&s files are the same
__________________
  #22
Old 05-29-2013, 11:00 PM
Dzchey21's Avatar
Super Moderator
Member's Gallery
Default
alright, another thing im not quiet understanding is the minimum speed ratio for lock up
right now the standard is 1.25 i think
the min speed ratio for lock up in hot mode is .56
So i changed the regular to .56 and it never locked the converter ever...
SO i guess i dont see how these two are used exactly
__________________
  #23
Old 05-30-2013, 07:48 AM
Major
Member's Gallery
Default
max doesn't really need to change
min is the one that needs changing because the lower the number, the more slipping there is.
__________________
Matt Robinson
  #24
Old 05-30-2013, 10:11 AM
Dzchey21's Avatar
Super Moderator
Member's Gallery
Default
They are both labeled min
__________________
  #25
Old 05-30-2013, 10:13 AM
Major
Member's Gallery
Default
yeah the 1.05 or whatever the larger number is max not min. the only way to have this above a 1 is if the truck was coasting down a hill and the trans input shaft is turning faster than engine RPM.
__________________
Matt Robinson
  #26
Old 05-30-2013, 10:21 AM
Dzchey21's Avatar
Super Moderator
Member's Gallery
Default
Quote:
So would it help to make that number closer to 2? I think its 1.25 now and the min is .56 currently the "max" is set to 1.56
I changed the min to .26 with no apparent change
I have also set the lock up rate during a lock to lock shift to 0 as well as the other shift lock up tables with no apparent change to anything
Might put a lock up switch on it and see if my issues go away and Make positive its a lock up problem and not a clutch application problem or something but I don't feel it is
__________________
  #27
Old 05-30-2013, 10:27 AM
Dzchey21's Avatar
Super Moderator
Member's Gallery
Default
And fwiw I don't have issues with the converter locking I have issues with it unlocking seemingly at every shift and then re-locking right after. Converter seams solid when its locked I mean even at 80 when the tires break loose there is no slip
__________________
  #28
Old 05-30-2013, 11:14 AM
Major
Member's Gallery
Default
I have emailed Bentley about it and he is trying his hardest to look for the parameter that is keeping it from relocking. The tighter converters or the lower power tunes seem to allow lockup just fine.
__________________
Matt Robinson
  #29
Old 05-30-2013, 11:51 AM
Dzchey21's Avatar
Super Moderator
Member's Gallery
Default
Like I said I have no issues with it locking when commanded to lock its the shifts after that fuk it all up
__________________
  #30
Old 05-30-2013, 02:58 PM
Major
Member's Gallery
Default
yeah when it downshifts and then can't relock fast enough, it cries uncle and won't relock to "save" the converter clutch.
__________________
Matt Robinson
  #31
Old 05-30-2013, 07:30 PM
Frank_C's Avatar
Frank_C Frank_C is offline
Sergeant
Member's Gallery
Default
Dzchey, It sounds like you're trying to keep the converter from unlocking between up shifts under power if I'm reading it right?
Isn't the converter supposed to unlock between shifts under power, to put less stress on hard parts during a shift? Or is it unlocking during shifts at light throttle too?
__________________
2008 F250 Crew Cab
GTX4202R...plus some other things
  #32
Old 05-30-2013, 07:33 PM
Dzchey21's Avatar
Super Moderator
Member's Gallery
Default
It appears to only do it under full power from what I can feel.
I understand its probably trying to save parts. Mine takes seemingly forever to relock which I'm sure Costs me time at the track even if I could reduce the slip time for the unlock I would be happy
__________________
  #33
Old 08-01-2013, 02:50 PM
Will@Rudy'sDiesel's Avatar
Will@Rudy'sDiesel Will@Rudy'sDiesel is offline
Lieutenant
Member's Gallery
Default
Is there any way that I can get the converter to lock as soon as it goes into second gear? Not a just WOT but like just when Im driving around town say at 5-10% throttle?
__________________
Zak Peters
Sales at Rudy's Diesel Performance
www.rudysdiesel.com
Cell-(828)-467-1118
Shop-(919)-383-9300 x206
​Direct Line- (919)-589-4755
2008 CCSB 740hp-Sold
2014 CCSB-Just getting started.... - Sold
2016 CCSB Monotone King Ranch
  #34
Old 08-01-2013, 03:22 PM
Fordtrucks's Avatar
Fordtrucks Fordtrucks is offline
Lieutenant
Member's Gallery
Default
Quote:
Yes, you can. But you wont see any benefit from it unless your at WOT. My tune locks in 3rd at part throttle and that's plenty early enough..
__________________
Superior Trucking LLC.
2008 F250 CC SB Lariat 4x4.
Ford, Elite Diesel, River City Diesel, Midwest Diesel,
No Limit, AFE, Sinister Diesel, ARP, H&S, ********,
Detroit, Pro comp, Z-Fab, Diesel Site, BMF and Nitto.
MAXED OUT ON STOCK FUEL.
  #35
Old 08-01-2013, 05:38 PM
Dzchey21's Avatar
Super Moderator
Member's Gallery
Default
I have been running a tune that locks in second and it works pretty well. The shift points are very hard to get right depending on how well the truck spools weight of the truck ect. I do like it better and I think the mileage is better. You do seem to lose some response since the rpm wont flash up the second you hit the throttle like unlocked.
Sent from my SCH-I545 using Tapatalk 2
__________________
  #36
Old 08-02-2013, 11:30 AM
Lieutenant
Member's Gallery
Default
That's what I was going to try to get was better fuel mileage, it would have to help some.
__________________
Zak Peters
www.rudysdiesel.com
Cell-(828)-467-1118
  #37
Old 05-30-2017, 10:16 AM
tnutcher tnutcher is offline
Private
Member's Gallery
Default
Very old post I know but curious if you ever figured what to adjust to fix it? I'm having the same issue and been playing with the MCC myself but no luck. Locks strong in 4th, then unlocks, upshifts to 5th, and relocks strong in 5th; jerks the truck and rpms around a lot, especially if I try running a 3rd gear TC lock tune.
Sent from my SM-G900T using Tapatalk
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
