Infinity chip switching testing is a success!
SeeYa
Georgia
Chip switching control testing for the following chips has been successful and will be available soon for the following chips:
DP-Tuner F5, F6 & F8
SCT chips
TS
The cable for our chips will be plug & go. The one for all other rotary knob chips will come with special instructions for hooking it up.
You will now be able to see the name of the tune on the display. Better yet, You will be able to label each tune whatever you like. (Keep in mind what it is though for troubleshooting purposes).
Stay Tuned!
Its only getting better
SeeYa
Georgia
Got the word all the features we asked for are not going to happen. Sorry!
:mad:
WE ARE GETTING MORE THAN WHAT WE ASKED FOR!!!!!!!! :pimp:
So let's recap:
Chip switching for the following:
F5, F6, F8
TS chips
SCT chips
DSP5 for Duramax
In addition to Chip switching capabilities the following will be included:
Dual EGT inputs
8- Zero to 5v analog inputs
Design is done. Size is proximately 2.50in. x 2.50in x 0.90 in. We are just waiting for a final price.
Let me know if you have any questions.
SeeYa
Georgia
So it works with just SCT chips or can SCT tunes be loaded to it?
This is for switching only. The only tunes that can go on the unit are ours. The infinity will control switching between the programs only.
So no one starts rumors...The Infinity can't read programs off the chips.
Diane
HOOV3R
Central PA
Diane
That's what I thought, but I wanted to make sure.
Justin@DP-Tuner
Just to keep everyone updated on this... We have received the updated version and all of the bugs seem to be worked out. Jody has tested it with the F5, F6, F8, and SCT chips with zero issues. He will be testing it with TS chips this weekend and if all goes well it will be available to purchase as soon as we get our shipment of them. Stay tuned for prices!
Let me know if you have any questions about this product.
SeeYa
Georgia
This just came down the tube from Jody....
TS chip switching works perfect
F5, F6, & F8 chip switching works perfect.
Autometer 0-60psi boost and 0-100psi fuel pressure work perfect.
We're on the home stretch with this project. :tree:
Thanks to everyone and your continued interest.
Diane
Justin@DP-Tuner
Here are a couple pictures of the HUB in action.
This is the HUB with an F5 and Infinity wiring harness connected.
This is the on screen display of the chip and it's positions. Whichever position you choose will be displayed on the screen with the rest of your gauges.
superstroked
Celina, TX
Is that via dasdaq?
Powerstroke Racer
Brenham TX
Diane
Only problem I see is no hub came in my box:poke:
SeeYa
Georgia
So the 8 inputs you were speaking of. What can be used here?
sent while doing burnouts somewhere in the country
Anything you want to monitor through them. You set up the formulas so skies the limit. Currently Jody has hooked up fuel pressure and boost. He is working on hooking up coolant temp using a factory coolant temp sensor to see if it works without having to add an additional sensor. On our 6.0 he is thinking of doing coolant pressure.
bad12jr
Thinking this would be an awesome addition to my truck. Keeping an eye on the sensor progress.
Sent from my x2 chillin in the middle of no where
SeeYa
Georgia
The 8 0-5V hook ups are already in place. All you will need is the sensor you want with the formulas and you're there. You will add the forumla via the INFINITY to begin monitoring.
Diane
BozoTheClown321
CT
What's the cost of converting a DD into an Infinity? Are any of the standard DD features locked down or missing?
Justin@DP-Tuner
Shoot me an e-mail or PM if you are interested in this. We can talk prices in that matter.
The Infinity has all of the standard features of the DashDAQ, plus everything that makes it unique for the Powerstroke.
Here is a chart Jody made comparing the two devices...
Does that answer your question? If not, let me know so I can explain it further.
