NRHX2009
Hey there, I was thinking of releasing a Do It Yourself OBS and E99 Billet 66mm Kit.
Kit would include the Following:
--Machined Compressor Cover
--Machined Backing plate
--Billet 66mm x 88mm Extended Tip Compressor Wheel
--360 Thrust Bearing Conversion with compressor side piston ring seal
--Compressor housing to backing plate O-ring
--Backing Plate to Bearing housing O-Ring
-4 Viton Pedestal O-Rings
Cost would be in the $700 range plus core. (Your old compressor housing and backing plate)
Let me know what you guys think and maybe i will get a few sets done for some to try out.
Thanks-- James
Thanks-- James
