7.3 Performance and stock parts
Strokersace
Towanda, KS
Parting out a couple of engines and have a whole mess of parts for sale. All parts are located in Wichita, Kansas. Most are still on/in the motors but will be pulled this weekend. Would be available to ship next Monday of next week.
Here's the list:
Hypermax Stage 2.5 injectors w/ .010 nozzles. Single shots. Not or ordinary 2's. These are approx. 200-225cc/200%. Good for over 525 rwhp with supporting mods. 00Rich did over 550 with his a year or so ago. $1,200 shipped with Cores.
ARP Headstuds. Torqued once w/ lube. $425 shipped
Terminator modded 17* hpop. This is NOT a T500. $250 shipped
Regulated Return w/ ITP (Strictly Diesel) bowl delete. I built this setup. Worked flawlessly. Parker 836 push-lock hoses (only diesel rated push-lock they made at the time) with Aeromotive regulator. Comes with supply and return to the crossmember, all fittings, as well as a post pump filter base and mount. Mount requires pump to be relocated back closer to the tank, or can be modified to work w/ stock location on SD's. No hose from the post filter to crossmember due to different mounting configurations. Will work on SD and OBS when using SD hpop res. $425 shipped.
International Bellowed up-pipes. For a SD. $300 shipped.
Stock 3" intake plenums w/ RiffRaff inserts. 10 bolt holes. Painted sliver. $65 shipped.
Stock 3" intake plenums w/ RiffRaff inserts. 2 holes welded up for use on 94.5 - 95 heads. Should be able to use them on all heads though. Black. $65 shipped.
99.5-03 gutted pedestal. $65 shipped.
99.5-03 DELETE pedestal. $100 shipped.
All aluminum stock intercooler w/ pipes. $300 shipped.
Plastic end 7.3 intercooler. No pipes. $125 shipped.
99.5-03 Spider. Tapped for boost and MAP on hot side. Also tapped on cold side where hose fittings used to be. $125 shipped.
E99 truck turbo. No shaft play. Moves free. $175 shipped.
99.5-03 SD Van turbo. Needs rebuilt. $150 shipped.
99.5-03 SD Van turbo w/ USA ported housing and boot. No shaft play. Has been rebuilt. Runs great. $450 shipped.
Driver's side SD exhaust manifold. Great for an OBS guy doing a SD swap. $70 shipped.
Stock Flexplate. $75 shipped.
Valve Cover set. Good shape. $65 shipped.
Rebuilt oil cooler. $65 shipped.
2 Rebuilt IPR's. $100 shipped EACH.
Oil pan. Good shape. $50 + shipping.
SD hpop res. $35 shipped.
99.5-03 front cover. $100 shipped.
Stock LPOP. Good condition. $35 shipped.
1995 CORE block w/ heads. 300K+ miles, lots of blowby, used oil. No compression numbers. Heads will come off to removed headstuds but will be included. Heads have the 8 bolt plenums. $300 + shipping
SWAMPS 6 pos. TS chip. Tuned for a 1997 TDE1 pcm w/ baby swamp injectors. Auto trans. Stock, High Idle, Tow, Daily, Race, Extreme. $200 shipped.
PM me or call/text at 208-316-1828. If you text, please let me know who you are and where you saw the ad.
THANKS!
Strokersace
Towanda, KS
I/c pipes sold. So only intercooler left.
Also sold 1 set of plenums and spider.
A lot of interest in studs and other parts but no money received yet.
