Go Back   PowerStrokeArmy > Premium Vendors > Dyno Proven
Reply
Thread Tools Display Modes
  #1
Old 04-17-2013, 06:11 PM
thuglike's Avatar
thuglike thuglike is offline
Major
Member's Gallery
Default Modded 7.3 Pistons
We have in stock 2 variations of our modded 7.3 pistons:
Stock and .020 bore
They have an intake and exhaust valve relief cut in them and the fuel bowlis opened up for bigger nozzles.
I'll get a pic posted up soon.
PM me for pricing!!!
  #2
Old 04-17-2013, 07:54 PM
dynoproventuner's Avatar
dynoproventuner dynoproventuner is offline
Corporal
Member's Gallery
Default
Here is a pic Cassie just took for the website, a sneak peak for the PSA:
  #3
Old 04-17-2013, 09:25 PM
David@BSDP David@BSDP is offline
Sponsor
Member's Gallery
Default
do you also do piston coating? How deep is the valve reliefs cut into the piston? Is there any way with the bowl work and the reliefs cut in does it alter the compression?
On EDIT: They look very good!!
  #4
Old 04-18-2013, 05:45 AM
kyle43335 kyle43335 is offline
Member's Gallery
Default
compression would be affected....
  #5
Old 04-18-2013, 06:03 AM
PSDEng's Avatar
PSDEng PSDEng is offline
Major
Member's Gallery
Default
Very nice! Any testing done on these yet? I'd be interested to see how the bowl configuration works with a stock injector.
  #6
Old 04-18-2013, 06:52 AM
thuglike's Avatar
Major
Member's Gallery
Default
We do offer them coated as well.
There is very little effect on stock compression.
The valve reliefs are cut .050 and can be customized to our customers specs.
The bowls are cut to optimize Jonathan's timing tables for specific injectors spray patterns. (I can't get into specifics) They too, can be customized to our customers specs.
They are in a few motors right now with great results. A stock injector is a great match for these pistons. Or should I say the pistons are a great match for the stock sticks. At this point all I can say is we have seen an increased potential of the stockers. After testing a few added benefits were reduced noise and heat with the loss of all the sharp edges of the stocker.
These are made in house and can be made from top to bottom to your specifications.
  #7
Old 04-18-2013, 07:23 AM
PSDEng's Avatar
Major
Member's Gallery
Default
So are these a forged piston? Or a monotherm? Maybe I missed it
  #8
Old 04-18-2013, 07:45 AM
Gearhead Gearhead is offline
Major
Member's Gallery
Default
In for info.
__________________
Matt Robinson
******** Automotive Performance
www.********automotiveperformance.com
  #9
Old 04-18-2013, 08:47 AM
thuglike's Avatar
Major
Member's Gallery
Default
These Pistons are The Mahle Performace line (Aluminum).
Note:...We will also modify your stockers.
  #10
Old 04-18-2013, 10:19 AM
Major
Member's Gallery
Default
stock style cast or forged? That looks like the forged line with anodized top ring land but I can't tell if it is the steel insert or not.
__________________
Matt Robinson
  #11
Old 04-18-2013, 10:31 AM
PSDEng's Avatar
Major
Member's Gallery
Default
I think it'd be tits if someone made a stock style piston with a square cut ring land rather than a keystone land
  #12
Old 04-18-2013, 11:12 AM
thuglike's Avatar
Major
Member's Gallery
Default
Quote:
Cast
  #13
Old 04-18-2013, 06:30 PM
Sponsor
Member's Gallery
Default
Is there anything that could be tweaked in the engine like a thinner head gasket to bring the compression back up? I would like to keep stock compression OR run a little more compression for quicker throttle response under the turbo.
Sending a PM for a price.
  #14
Old 04-18-2013, 06:53 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
looking good!
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #15
Old 04-19-2013, 07:44 AM
thuglike's Avatar
Major
Member's Gallery
Default
Compression is so close to stock you really won't need to worry about it.
Price list is being worked out right now....
  #16
Old 04-19-2013, 07:48 AM
Sponsor
Member's Gallery
Default
Thanks Jason! Pm sent back to you.
  #17
Old 04-19-2013, 02:04 PM
Corporal
Member's Gallery
Default Compression
I am sure we could do something about compression but I do not see the need. This past winter, two of the trucks that were running these pistons experienced NO white smoke on cold start up, even on 30 degree days or colder. Furthermore, the idle was smoother and quieter than most other 7.3L trucks, even though they were running larger injectors. With our programming, throttle response is not an issue.
  #18
Old 04-19-2013, 03:00 PM
Sponsor
Member's Gallery
Default
Quote:
Thanks for taking the time to help me out. Right now even IF ( I want to go with them and your stage to cam) i did not need to go with valve reliefs cut in I was still wanting to raise the compression a little. That would only be if it was worth it. I start and run my pickup in -30 and colder temps in the winter. And would like it to still start as good if not a little better then stock compression. Yes I agree with you with tuning most of, if not all the issues could be took care of.
I talked with Jason on the Phone this morning for about 45 minutes. We went over most of these things. I just now need to take my spare engine apart and see exactly what I would like to do and need to do. After this I plan on buying some parts. Just need to figure out what is needed and what route i want to go.
Thanks again.
David
  #19
Old 04-25-2013, 01:14 AM
Snowman269 Snowman269 is offline
Corporal
Member's Gallery
Default
Them are sweet, I should buy them for Amanda...
  #20
Old 04-25-2013, 06:33 AM
thuglike's Avatar
Major
Member's Gallery
Default
What is up Dennis!!!!!!
Nice avatar..she looks good.
  #21
Old 04-25-2013, 09:42 AM
General
Member's Gallery
Default
Quote:
do you currently own all the trucks in your sig?
sorry for the derail.
__________________
  #22
Old 04-25-2013, 03:09 PM
thuglike's Avatar
Major
Member's Gallery
Default
Yes he does...Dennis bought mine and he is buying Amanda's rig as well.
  #23
Old 04-25-2013, 03:16 PM
General
Member's Gallery
Default
holy crap!
__________________
  #24
Old 06-03-2013, 01:50 PM
backwoodsboy's Avatar
backwoodsboy backwoodsboy is offline
Major
Member's Gallery
Default
In for prices.
  #25
Old 06-03-2013, 02:15 PM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default
Dude I was gonna ask the same question, imagine how much money he has spent on trannies just alone
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2018 Ram 5500 Mechanics Truck
2001Tdi Jetta 5 speed
  #26
Old 06-03-2013, 02:39 PM
thuglike's Avatar
Major
Member's Gallery
Default
Quote:
Originally Posted by backwoodsboy View Post
In for prices.
If you supply the pistons:
50$ For bowl mod (ea.)
60$ For bowl mod and valve relief (ea.)
80$ For bowl Mod, valve relief and coated.
Set of pistons from us:
Set of 8 stock Mahle.....500.00
with the bowl mod.........900.00
with bowl mod and valve relief......1000.00
bowl mod, valve relief and coated..1100.00
  #27
Old 03-04-2016, 07:34 AM
fordpulling29's Avatar
fordpulling29 fordpulling29 is offline
Sergeant
Member's Gallery
Default
NICE !!
__________________
03 F250 lariat 7.3 ZF6 gauges ... that's it for now
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Designed by Military Ltd
