DPF delete Exhaust 6.4 to 6.7, are they the same?
BK39
Texas
For you guys that had 6.4s and bought 6.7s, are the delete pipes the same? Did your 6.4 exhaust fit on the 6.7? Best I can tell, looks like the rear section will work, just curious if the delete pipes are the same?
I got rid of my 08, so probably going to tune the 13 now.
BK39
Texas
No the deletes are different
Thank you sir!
Yeah, I saw both delete pipes.. Def different. I am sure a skilled fab guy could work some magic, but they are not the same pipe, for sure. I am still debating deleting mine... Already have better mileage, and power than the 6.4 450 I had...
I hear you. When I still had my 08, I was content not deleting this 13. But after selling the 08, now I'm thinking hard about deleting this one.
SEABEE08FX4
Montgomery TX
The frame from the firewall back is the same, you could use evey thing after the down pipe flange if you had the ability to cut and weld. A few of the hangers are different as well, so in other words you could make it work but the headache is far more than the cost of the correct bolt in kit.
