Please help! 01 F350 developed new problem today!
700hauler
Hey guys,
I was running errands today in the 01 F350 (7.3) when it started acting weird. It would randomly make a bit of a thud then act like it was engine braking..then it would go away and drive normal after I let off the gas for a second. It does this in roughly 2-5 second spurts then drives normal again. When it does this it doesn't respond when I give it gas. Once it stops it drives normal. WTH!? It's doing it quite often now and I really can't drive it. Is a transmission repair eminent? Or is this possibly something else like fuel delivery etc? Please help I have no idea where to go from here. This is my first ever diesel truck. Thanks!
ToMang07
Mainah!
You really need to explain what it's doing better. Is the engine missing? Transmission shifting hard? Clunk sound? Grinding sound? Where is it coming from? Always? At speed? Starting? Relative to RPMs? Is the CEL or O/D lights on?
700hauler
I know. I apologize. That's what is killing me...it really is hard to explain. The best way I can describe is that it feels like its engine breaking at random times, regardless of throttle input. Its like the truck is lugging itself down. It does it for a few seconds then it quits and drives normal...then does it a gain for a few seconds. No grinding, a slight thud and then it starts slowing down as if the breaks are being pushed...even when on throttle. It seems to be somewhat random as to when it does it. No lights are flashing/on. The engine seems to be running fine. It seems to be doing it within a gear...not while shifting.
ToMang07
Mainah!
Does it seem like a cylinder or two are cutting out? How much fuel do/did you have in the tank when it happens? Any idea when the last time the fuel filter was changed?
And I'd start giving it diesel...not gas. LOL
700hauler
It really doesn't seem like any cylinders are cutting out...if anything it seems like everything is cutting out at once. My other thought was maybe fuel starvation issues? Or some sort of vapor locking? It had 1/2 tank of fuel when this was all occurring.
haha ya ya I figured that would come up when I said "give it gas" sorry.....give it throttle :slap:
POWER-STRUCK
Indiana
you will have to narrow it down to which system is causing this issue. i have seen trucks have a transmission sprag failure on the forward clutch exhibit similar symptoms. but this also could be an engine or fuel system issue. also might try unplugging the ebpv solenoid to see if it helps
700hauler
Ok thanks for the help. If it were stuck closed wouldn't it do this all the time instead of off and on though?
700hauler
Well I just did a drive around the block and when it starts doing it if I put it in Neutral it coasts and runs fine. It seemingly does it worse in 3rd gear. Tranny fluid is at the correct level but it kinda smells burnt :( I think I know where this is heading. awesome. We are currently having to drop $2k on the wife's Subaru for a trans....have no idea how I'm going to pay for the F350 trans...when it rains it pours. :flush:
ghohouston
Lewisville,Texas
Ouch, best of luck. Hell you might as well snag one of the used bts trannys on here if you can swing it, but I understand being broke
INFRNL
Colorado
Maybe you just need to get a servicing done on the tranny or replace the filter and flush it yourself. Might be worth it rather than a new tranny. Although things could be sticking in the valvebody. I do not think a full service at the tranny shop is too bad, maybe a couple hundred. Its an option.
700hauler
INFRNL I thought about that but the thought of tossing several hundred dollars at it, only for it to possibly still fail, is hard to swallow.
Lethalthreat7.3
Denver, CO
The transmission may be fine and it may be electrical. The TR switch can cause havoc when they start to fail. I would install a pressure gauge with a hose long enough to read while you drive. See what the pressures are.
