Go Back   PowerStrokeArmy > Power Strokes > 6.0 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 07-13-2013, 07:59 PM
HobbyStock62's Avatar
HobbyStock62 HobbyStock62 is offline
Sergeant
Member's Gallery
Default 7/8 -14 UNF fittings?
yes, another fuel system question...so i am getting baldwin filter bases (FB1311) and they have a 7/8 inlet and outlet...im not sure if i am overlooking something simple, or if they are hard to find, but what i THINK i need is a 7/8 -14 UNF fitting to go from the filter base to the -10 an hose end. is that right, or do i sound like a crack addict?
__________________
2004 f350. 2.5" leveling kit on 35's, 6" aussies, barder stage 2, stock fuel and SCT xtreme custom tunes from ********.
  #2
Old 07-13-2013, 08:06 PM
ford rules's Avatar
ford rules ford rules is offline
Major
Member's Gallery
Default
Yes you are correct on that but the 7/8 14 is thread size. Get a -10 o ring seal to an adapter.
http://m.summitracing.com/parts/aei-15608 that's what you need, local hydraulic stores have them much cheaper...
__________________
2006 F-250 6.0. Studded, ******d, 66/74/.91, T4 divided upipes built by me, 230/100 7 hole MPD injectors, fuelab 41402 pump/strictly RR, Dieselsite HPODS, 4800lb coils no blocks/overloads, 20x12 Fuel hostages 305/50R20 nitto 420s.
  #3
Old 07-13-2013, 08:09 PM
HOOV3R's Avatar
HOOV3R HOOV3R is offline
Colonel
Member's Gallery
Default
Should be -10 orb
__________________
08 6.4 2WD Shorty - Scattered Everywhere
05 True Blue Harley - Holders 205/75s, DieselSite HPODS, Alradco Intercooler, MPD Log Manifolds & Vbanded T4 Uppipes, SXE-369, MPD Cooler Plate W/ Fluidyne Cooler, Van Filter, & Improved Racing Tstat, Custom Reverse Feed Fuel System W/ Fuelab Pump, Absolute Apex, O-Ringed Heads, Extreme Studs, RCD Cam, Pushrods, & Springs, No Limit Intake & Cold Side, CED Vbanded Hot Side, Vision Degas Tank, Bulletproof Waterpump, ******** Tuned
  #4
Sergeant
Member's Gallery
Default
awesome, thank you
__________________
  #5
Old 07-13-2013, 08:27 PM
Sergeant
Member's Gallery
Default
one more quick question about in between the filter and a1000. would i be able to link them directly, or will i have to use hose in between the filters and pump? if so, can i just use a strait -10 an to -10 an fitting in the a1000 then my -10 an hose ends?
__________________
  #6
Old 07-13-2013, 08:42 PM
ford rules's Avatar
Major
Member's Gallery
Default
You will need 2 -10 orb to -10 an male then 2 -10 orb to -10 female swivel.
__________________
  #7
Old 07-13-2013, 08:51 PM
Sergeant
Member's Gallery
Default
could i use these in between?
http://www.summitracing.com/parts/mrf-mp-3011
also, going into the front of the heads, would i just use a -6 90* fitting? or a strait fitting then a 90*? or something else?
__________________
  #8
Old 07-13-2013, 10:41 PM
ford rules's Avatar
Major
Member's Gallery
Default
Those should work also, didnt know where to buy those at. I may get some.
Your just going to have to see what will fit but i would say your gonna need a 90 and also have to find out what siZe thread is in the head, i wanna say its m12x1.5 but im not 100% sure on that.
__________________
  #9
Old 07-13-2013, 11:26 PM
09stroker's Avatar
09stroker 09stroker is offline
Major
Member's Gallery
Default
For the heads you need a 12mmX1.5 to -6 JIC or A/N adapter. Then use a -6 90 degree hose end.
__________________
09 F-350
*******, Intake, Exhaust
4" Down Pipe
No Limit
LP Fuel System
2 Stage Nitrous System w/ Progressive Controller
Batmowheel
  #10
Old 07-14-2013, 10:48 AM
Sergeant
Member's Gallery
Default
alright, thanks guys!
__________________
  #11
Old 07-14-2013, 05:47 PM
ford rules's Avatar
Major
Member's Gallery
Default
Here's a few pics of a 90* threaded into the front driver side head.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
