Morgan@Midwest Diesel & Auto
Comes with everything necessary to mount the pump, hook up the belt, plug and play harness, high pressure lines and necessary hardware.
This pump mounts with no extra belts, does not remove your alternator, uses factory programming and wiring, uses solid high pressure lines. It is easy to install cab on with very little removal of factory components. The LP fuel side is left to the customer to hook up to because of all the different fuel system variations. Must use an intake elbow that clears the larger pulley. Fits with many aftermarket cold air intakes. The brackets are made of 3/8" thick steel with fully welded structure to be indestructible. The pump runs on factory belt line.
We are officially taking orders for these on Monday Sept 9th.
Pricing goes,
dual pump kit without pump: $1800
Dual pump kit with pump: $2800
These will be shipping next week to orders that are taken.
