#1
took our 6.4 pulling truck to a little local pull to test out the new air to water set up this weekend. super short track. had to shut it down real soon or it would have ended up in the parking lot
![]() https://www.facebook.com/photo.php?v...type=2&theater |
#2
Impressive!!
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, S471, Beans IDM, ARP head & main, girdle, half filled block, DI cam, Dual IPRs, ceramic coated bowls, anti-friction skirts, Haldex pump over Stock pump, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth. ![]() |
#3
What's the specs on the truck it sounds real good.
#4
s480, 100% nozzles, RCD cp3 kit, 6.0 manifolds, custom built up pipes, valve spring, pushrods, FASS 220, elite fuel bowl ****** and all the other custom stuff that goes along with all that
#5
westminister, south carolina this past weekend
#6
Holy ****.... Did you plan on taking that sled home? What kinda Rpms are you turning with it
__________________
2008 F350 King Ranch Engine build coming soon, 800hp goal 1988 Ford F-250 Larait 7.3L IDI Austen ❤️s Michaela
#7
I bet that sled driver needed to change his pants after that run.
__________________
Robert 2003 F-350 CCLB, Frame off restoration in progress 2002 F-250 ECLB, Parts hauler 2002 Excursion, Twin hauler |
#8
Hahah nice!! You should have drug it back around to the start line. Any mods to the driveline?
__________________
00 cc/sb zf6 F250- Some stuff done always more to do-Fuel 300/200s Air-Garrett 68/94-Oil SRP 1-Airdog to Fuellab 97 cc/sb- zf-5- Work in progress. PMF rsk w/ SD axles. 66 turbo, E fuel, 230/100s. SB DD clutch. 08 cc/sb - Elite bottom end - 2 fuelers, 59vgt/78atmo, Midwest 100% nozzles and coated heads etc.... www.teddavisautos.com Many parts available for super duty trucks PM me. |
#9
Cute little baby sled. Nice hook though. Shoulda kept going if it was a floating finish.
__________________
02 F250 7.3 Crew Cab Short Bed Lariat PHP Hydra, Ge4rhead tunes, Edge insight CTS monitor Mild Trans Build, Dual disc TC GTP38R, T500, PIS 175/80s in the engine. waiting to see rods one day Turned 200k miles 1/18/2015 |
#10
Hs lols
Idk if the sleds have brakes but if so i bet the operator locked them up. Haha
__________________
Stage III genitalia. |
#11
Operator would have pulled the air shut off hahaha
__________________
#12
Nice pulls guys.. looks good
__________________
2000 7.3 ECSB BLACK ![]() Elite built b-codes, with twin BTS pumps full billet trans, 910's p-rods Had a 76mm precison BB.R.I.P (11.86@115.9 fuel) Now has a GTX4294 (like to trade for GTX4202R) 2 stage NOS, A1000 fuel / RR, and some water.. |
Thread Tools | |
Display Modes | |
