05 shop truck part out thread
Cutting-Edge Diesel
Newkirk, OK
Complete turbo set up with 5'' intake $1700 ($2535 new)
This is an early design on my up pipes but have the same bellows I use now. They are pre tig welded up pipes so they are mig welded, price reflects that. Turbo is a s364.5 FMW with 68mm turbine and .83 exhaust housing. Turbo is practically brand new. Intake is a 5'' intake and filter but use the factory plumbing into the turbo.
https://www.youtube.com/watch?v=KAPBZXpkMWM
205/75 injectors $800 with cores $1500 without
I built these injectors and they run perfect. I didnt do any machining just put different parts of injectors together to make them 205s they hold 4.8v of icp.
here is a start up video of them cold. this truck always fires right off.
https://www.youtube.com/watch?v=LzFtLR92s5w
Edge CTS $350 perfect working condition
Alpine in dash dvd/navigation not sure what its worth make reasonable offer and its yours
Harley head lights $150 pair
they are showing some smoking on the lens im sure it would clean up easy
Flex-a-light E fans $450
they have some surface rust on the motors but they are 6 months old
08 tail gate $400
just looked it over close there are no imperfections.
C28BEF60-41BE-4C39-9812-00756E5E9190_zpscx87euzi.jpg.html
slc dzl
Riverton, Utah
What all comes with the flex a lite e-fans?
Does it have the variable controller and oem fan signal fooler?
