Some stock style "66" turbo testing I did...long
gnxtc2
Bergen County, NJ USA
The background:
My truck is a 1997 OBS, auto, 3.55 with 285 tires. The trans is fully built by Paul aka The Punisher out of CT with a PI converter. I don't drag race nor pull, my truck is my daily driver and tow vehicle, a working truck.
I had injectors known as Baby Hybrids (hybrids with stock nozzles) from Swamps. Truck was live tuned by Jonathan at Jason's place in NJ on Aug 2011. Aside from the injectors, the motor was all stock: stock turbo, stock fuel, stock HPOP; it put down 380 HP to the wheels.
Truck was running great. A year or 2 later I installed a D66 with a 1.15 housing from Beans. Left tuning alone. When I installed the D66, it was laggy, smoked a little. Did some reading about it and most found it laggy down low. I left it alone.
Dec 2013, I had to pull the motor due a severly leaking oil pan. Since the motor was out, I sent the injectors (had 90K on them) to Tim. I installed a Honey Badger Jr, ARPs, 910s, Smith Bros PR, fixed the broken bolts on the manifolds and did some other maintenance items. Got the report from Tim and the injectors were worn and he recommended 175/80s.
Dropped the motor in, got tunes for the new set up and that's when the issue began: turbo (D66) was now really lazy to spool and high EGTs. Yes, checked for boost leaks and exhaust leaks....all checked fine. I tried different tuners (DynoProven, DP, Gearhead) and they all had the same result: smoke and high EGTs and loss of fuel mileage (2-4 MPGs). In the meantime, the oil seal on the exhaust side of D66 sprung a leak and a Brute 66 went in with a billet wheel (6/6).
When driving/cruising, there would hardly be any boost. When I press down on the throttle, I couldn't see the cars behind me. The boost would slowly build, then at 30lbs the EGTs were at 1300*. Felt like the fuel was putting out the fire or "snuffing" the turbo. Couldn't stand the smoke and EGTs so I pulled the chip and drove around on the stock TDE1 ECM. The truck was responsive and peppy like a chipped stock truck but didn't have the raw power.
I began to research turbos (TP38, GTP38R, S366) and reading the forums of 66 style turbos. I called up a few turbo shops and went over my issue. They all told me it was due to 66 wheel installed in the stock turbo. The 38r turbo has a ball bearing which really helps the spool up and hence the reason it has 66 wheel. The journal bearing (TP38) just doesn't respond the same way as the BB. All the turbo builders said to put the stock wheel or better yet a WW2. I ordered a WW2 from Dieselsite.
I then did my research.
TP38 specs
Compressor wheel inducer diameter: 59.87 mm (60 mm)
Compressor wheel exducer diameter: 80 mm
Compressor housing A/R: 1.10
Turbine wheel inducer diameter: 76.2 mm
Turbine wheel exducer diameter: 69.84 mm (70 mm)
GTP38R (ball bearing center section)
Compressor Inducer: 65.91mm (66mm)
Compressor Exducer: 88.14mm
Same turbine
Each turbo has a choice of turbine housings which up to the user.
So I decided to do some testing:
Since I have Irate's one piece up-pipes, I am able to swap exhaust housings without removing the turbo. So I swapped in a 1.0 housing on the D66. Still chipless, the boost build better but nothing great.
While waiting for the WW2 to arrive, I put the chips back and tried each one. Went on 20 mile rides with each tuner's tunes and made mental notes. I am not going to go into a tuner report. The motor was making 0-1lb boost while cruising with the 1.0 housing. But the turbo spool up was better but still laggy and the smoke/EGT issue was still present. The mileage started to come back around.
The WW2 arrived on Tuesday. Today, I removed the turbo to swap in the wheel because I couldn't get to the bottom compressor housing bolt. Swapped wheels and put the 1.15 housing back in.....basically going back to a stock turbo with a WW2.
Now with a stock size turbo, cruising boost is in the 2-3lb range, the smoke is down to haze and the EGT issue is now managable on how much I beat on the truck. The turbo makes 25lbs boost with a slight haze which kinda good for a stock turbo for longevity. The EGTs climb very slowly. I hit 1400* after staying at WOT for 10 secs on the highway climbing an incline, the speedo needle was pinned. As soon it 1400*, I lifted and the EGTs dropped instantly. Tripped the CEL with P1211 but that's a tuning issue.
What I concluded with this:
The 66 style turbos have their place. There is a reason why Garrett built a 66mm turbo with a ball bearing instead of a journal bearing. Why would they make a ball bearing turbo if they already had a journal bearing turbo out there? Wouldn't it been easier to machine a cover that was already made rather than casting a whole new cover?
What I found out with my truck, to spool the 66 turbo, either the rpms have to be high or fuel needs to be cut back. At no time did I alter the tunes.
Is my truck not correctly built for a 66 style turbo with 3.55s and 285 tire? My cruising rpms at 55 is 1450 and at 70 is 1850. Remember this is my daily driver running around empty most of the time. I enjoy not having to turn high rpms. Maybe a BASB/T4 conversion might be better for me due to the rpm range I cruise. I also tow my trailer at 70. The BASB starts to boost at 1500 rpms
I am supposed to tow my trailer Friday for track rental if the weather holds out. I gross out at 21K. I will see if the 1.15 is fine or should try the 1.0 housing.
Here is thread from PSN with another truck with 3.55 and a zf5.
http://powerstrokenation.com/forums/showthread.php?t=256858
Oh yea, getting my truck live tuned will be the best thing to do. All this testing I did was with the butt dyno and looking out the side mirror for smoke conditions.
Fire away
Billy T.
[email protected]
jwlandry
S.W. Louisiana
I had the same issues with the d66. That's why I went w the t4 stuff and s366. With the turbo swap it made a completly different truck. Runs cooler, more responsive, less smoke. I never get out the daily file because I don't have studs, springs, or pushrods so I don't really know what's it capable of other then 40 psi in the daily setting. Truck pulls 15-20k no problem.
4.10 gears by chance?
ja_cain
I'm quite convinced that a broad map turbo for a mildly built daily driver/tow vehicle is the way to go. Especially if you are running a stick. That being said, not sure why the tuners couldn't just pull in the fuel on the bottom end to accommodate the lack of airflow and high rear gear ratio (low numerical). The anecdotal info of Jeremiah's zf5 truck running the BASB is what got me interested in that turbo. Low drive pressures, low egt's while towing and turbo starts to spool early like a 38r with 175/100's. What I would like to know is if someone could get the d66/brute 66 turbos to light better with less pw but same amount of fuel that you were originally delivering with your tunes? In other words, run a larger nozzle hybrid and tune it to deliver the same fuel flow of your current injectors.
Thanks for your testimony. This is good info for the guy running a stock truck looking to take it to the next level.
ja_cain
I wonder what the rotating mass differences are between your 66mm turbo and the stock ww2 turbo is. If it is significantly different then this might play a role in how the two turbos behave down low especially since you were able to clean things up by switching compressor wheels while keeping exhaust side the same.
gnxtc2
One of the turbo builders spoke about messing the weight differences of the wheels but didn't go into detail. Also by changing the wheels, the intake to exhaust ratio was affected.
Billy T.
[email protected]
just seems that the op is running way to low of rpm and staying under the turbo way to much to keep it happy and lit.
Swaan
I do know with the lasb turbo I had it would pull hard down to 1700-1800 rpm if I wanted to while towing. The 366 is not that happy down that low. The egts get hot. It's a 2200 and over turbo under a long hard pull. That's the bigger comp wheel and turbine that effects that. On average the lasb made 5-7 psi more boost everywhere in the rpm range then the 366. But wot the 366 pulls harder on the top end thou
rusty1161
Whittier, CA
Billy,
I have a 97, TDE1 PCM, D66 with WW2 and 1.0 and now a 0.84 exhaust housing, Irate one piece up pipes, I/C, PIS 160/30's, 3.73 gears and 33" tires. I have had pretty much the same experience as you have. Truck runs good, just not as cool as I would hope. I hope you find a reasonable solution.
Thanks for posting.
Rusty
Swaan
Swaan
What's the difference between lasb and basb turbos?
At what rpm did the lasb start making boost?
Thinking about going with Irate's T4 kit.
Billy T.
[email protected]
Billy. They don't even make the lasb any more. It evolved into the basb. The early lasb had a smaller comp wheel called the Z wheel. The later lasb got the ZQ wheel. It flows more. Mine was the ZQ. Now there just called basb.
The boost neddle would start moving on my truck at like 1200 rpm by 1500 it's goin up fast.
Work well. Cruisin on hwy at 1800 it would sit at 8-10 psi towing my 8000lb tt
gnxtc2
Billy,
Thanks for posting.
Rusty
At least I'm not the only one.
Billy T.
[email protected]
ithumpwheniwalk
BC Canada
Billy T.
[email protected]
I've got a d66 with 160cc injectors, I've checked for boost leaks etc and found none. This thing is a dog. Worst upgrade I've ever done to my truck. Won't light worth a crap and is smokey and hot as hell. Almost tempted to go back to stock, as I can't afford to upgrade to something better at the moment. Although that being said, I don't beat on my vehicle and the truck rarely see's 3k rpms. Maybe I'm just not making it work hard enough to spool, but I was sure expecting to get more than about a 1k (if that, from about 2200-3k)rpm powerband out of it, if that makes sense?
gnxtc2
I would put the stock turbo back on ot atleast the stock compressor. You can also replace the 66m wheel with a WW2 for the stock turbo, you just to put a stock compressor cover on. That is how I am currently running my turbo.
The WW2 for the stock turbo cost $229 from Dieselsite and you can probably find a stock compressor cover somewhere.
Billy T.
[email protected]
