Go Back   PowerStrokeArmy > The Bunker > General Discussion Forum
Reply
Thread Tools Display Modes
  #1
Old 05-19-2011, 12:08 AM
TANK'S 250's Avatar
TANK'S 250 TANK'S 250 is offline
Colonel
Member's Gallery
Default Posting Pictures: How-To
Can't figure out how to post up an image of your truck or anything else you'd like to show? You've come to the right place... this tutorial might be a little bit long, but it tells you everything you need to know about hosting your image(s) and posing them up here
Step 1:
Now, first thing's first. You must have an image to begin with, so find where it is located - I will use one of mine as an example. The picture I will be posting is in the "Pics for collages" folder on my computer, the picture can be anywhere on your computer as long as you know how to get to it!
NOTE: you should have two tabs or windows open at the same time to make this easier.
Step 2:
Now open up your internet browser (Firefox, Internet Explorer, Opera, etc.). There are many different places that will host your image. We will use PhotoBucket, it's free..... so head on over to Image hosting, free photo sharing & video sharing at Photobucket.
Step 3:
At the top right, click on Join Now and on the next page type in any username you would like and a password then click on Next Step. On the next page, type in your:
- First name (can be real or fake)
- Last name (can be real or fake)
- Email
- Gender
- Birthdate
- Zip code
- Type the letters/numbers you see in the image in the text box
Step 4:
Click on "I accept, sign me up!" and you're now registered! Navigate through any other pages until you get to the one that has in big letters "Upload Images and Video" at the top. Click the blue button "Choose Files" and a box will open. Navigate to your image and double-click on it:
Your image or images (you can select more than one to upload at a time) will now automatically begin to upload and you can see the progress on the bar(s) that appear. When all the images are done uploading, the page will refresh itself and show your images a little bit further down.
Step 5:
To post the image to this website, put the mouse over the image and 4 bars will appear under it with text in them. Click inside of the bar at the bottom with the [IMG] code and the line of text will be highlighted, then right click and click on Copy or while it's highlighted you could hold down the Ctrl key and press C for copy.
Step 6:
Now come over to the forum here (you should have two tabs or windows open at the same time to make this easier) and in your post, right click and click on Paste or hold down Ctrl and press V. Your code should look like this:
Now you're done!
__________________
2005 F-250, CC,SB,PSD, MANUAL TRANS
40" IROK M16's, 20 x 10 AR Mojave Teflon- ARB Air Lockers -SCT XCAL II - ARP Headstuds - Stage II fuel and Oil system - AFE - MBRP - Southbend 550+ HP Clutch - Autometer Cobalt Series Gauges - Harley Davidson CB - train horns -10,000 watt inverter- Porter Cable 115 volt, 2.5hp Air Compressor - Crown SS braided Brake Lines -Custom Fabricated Front Bumper - Custom Fabricated Safari Rack - AMP Research - Bushwacker Cut-out Fender Flares -
  #2
Old 05-19-2011, 12:10 AM
MAC's Avatar
MAC MAC is offline
Colonel
Member's Gallery
Default
Vary informational
__________________
It is very difficult to argue with me, since I am likely to have knowledge regarding everything, not in detail.
  #3
Old 05-19-2011, 12:20 AM
TANK'S 250's Avatar
Colonel
Member's Gallery
Default
thanks you...hopefully it'll be a sticky
__________________
  #4
Old 05-19-2011, 09:34 AM
USMCpoolee's Avatar
USMCpoolee USMCpoolee is offline
Sergeant
Member's Gallery
Default
x2 on the sticky
  #5
Old 05-20-2011, 05:34 PM
Ouch's Avatar
Ouch Ouch is offline
Sergeant
Member's Gallery
Default
Thanks finally got my pics on here.
  #6
Old 05-21-2011, 10:36 PM
Whytry's Avatar
Whytry Whytry is offline
Lieutenant
Member's Gallery
Default
x3 on sticky
  #7
Old 05-22-2011, 01:53 AM
TANK'S 250's Avatar
Colonel
Member's Gallery
Default
glad I could help
__________________
  #8
Old 05-22-2011, 06:19 PM
Dzchey21's Avatar
Dzchey21 Dzchey21 is offline
Super Moderator
Member's Gallery
Default
Thanks tank...
__________________
2017 F-350 DRW Platinum stock for now
1979 F-150 6.0 Swap in progress, 86mm LP turbo, 04 frame and interior
  #9
Old 05-24-2011, 04:07 PM
Big Calo Big Calo is offline
Sergeant
Member's Gallery
Default
Great write up Tank! Even when I had my Iphone I would use PhotoBucket. Liked it better than even a direct upload, because then I could acess my pics from any computer.
Just a thought but I also like to use the bulk uploader if I have several pictures. Seems to work the best for me.
  #10
Old 05-25-2011, 09:06 PM
HOLDERDOWN's Avatar
HOLDERDOWN HOLDERDOWN is offline
Colonel
Member's Gallery
Default
Very good!
__________________
Jaran @ Holderdown
A Not Fast Enough 2006 F-250
  #11
Old 05-29-2011, 04:51 PM
Dieselcraft's Avatar
Dieselcraft Dieselcraft is offline
Major
Member's Gallery
Default
tank thanks for the thread i hope it will help all new members im always picture happy
__________________
Weston S.
05-F250 lariat CCSB custom painted and airbrushed inside and out lil lift kit and other goodies
FullForce Diesel-190/75,Sinister reg return,fuel lab pump custom filtration ,TSD sump,Empire Diesel Stage 1 CYL Heads,MPD manifolds-up pipes,Borg Warner S468 ,Banks CAC system,SCT=********,Edge cts,Twisted stage 2 Trans,custom cold air, 35 M16 interco's
  #12
Old 05-30-2011, 09:13 PM
David S.'s Avatar
David S. David S. is offline
Major
Member's Gallery
Default
is it possible to do this with flickr? I can't get my photobucket to work and just opened a flickr account
__________________
2008 F350 Lariat
  #13
Old 06-28-2011, 01:55 PM
96stacked&smoken's Avatar
96stacked&smoken 96stacked&smoken is offline
Major
Member's Gallery
Default
__________________
96 obs ext.cablb 5speed, 3in dp,4in strait,7in stacks,php tunes,isspro gauges,ccv mod,shimmed fpr, modded fuel bowl,ebpv ******d,6637,custom front bumper,led 3rd brake,smoked tails,train horns, black moto metal 951's,33-12.50 bfg's,traction bars,ww2,ff 180/30's
08 edge 3.5 awd sel
13 xlt screw 5.0 4x4 f150
  #14
Old 06-28-2011, 01:56 PM
Major
Member's Gallery
Default
__________________
08 edge 3.5 awd sel
  #15
Old 06-28-2011, 02:04 PM
Major
Member's Gallery
Default
oops wrong thread sorry.lol
__________________
08 edge 3.5 awd sel
  #16
Old 06-29-2011, 08:58 AM
harley1rocker's Avatar
harley1rocker harley1rocker is offline
Private
Member's Gallery
Default hey bud
Hey,its big bad harleyrocker. I new u from psn, i cant remember but i think you had a 6.0 ,i need help with one. Didnt u hav the 6.0?? Sorry,im driving
  #17
Old 08-03-2011, 11:22 PM
RBernardi RBernardi is offline
Lieutenant
Member's Gallery
Default
Hey tank, I can post pics but I can't set one to my avatar. I click use custom avatar. Then paste my code. It's proceeds to the next page, and says invalid file. This happens to every file I try to enter. Any tips?
__________________
RIP Zack Freeman & Dustin Malson 8-14-10, California 200
1997 f250 HD ccsb, 140k idm, diy e-fuel, diy intake w/6637, 3.5" dp, 5" exhaust, 6" superlift, 2" bd lift , 35" Cooper discovery a/t's on 16" alcoa's, 2007 lariat interior.
  #18
Old 08-04-2011, 03:28 PM
TANK'S 250's Avatar
Colonel
Member's Gallery
Default
shrink the image size
__________________
  #19
Old 12-27-2011, 10:24 PM
superdutyman97's Avatar
superdutyman97 superdutyman97 is offline
Sergeant
Member's Gallery
Default
Thanks for the detailed how to. Made life a lot easier and its tons better than attaching a thumbnail.
__________________
97 F250 eclb 2wd, TS 6 pos, 4in exhaust into a 5 inch miter, Autometer Sport Comp II boost and pyro, diy 6637-Sold for 6.0 parts money
05 F-250 ccsb 2wd-Removed old man looking parts, 4 inch diamond eye exhaust with a *** tip, SCT w/ ******** tunes, Banks Technicooler, and hopefully new tires soon...
  #20
Old 05-10-2012, 08:56 AM
3brorce's Avatar
3brorce 3brorce is offline
Colonel
Member's Gallery
Default
Awesome. Thank you. Just posted my first pic with the help of this sticky
__________________
Anarchy Diesel Tuning EFI Live, MCC and UDC
  #21
Old 06-27-2014, 12:31 AM
MaxdLaw's Avatar
MaxdLaw MaxdLaw is offline
Major
Member's Gallery
Default
Thanks! Been trying all night!
__________________
2005 Harley Edition
8 inch lift, 38 inch mud grapplers. Also may contain big turbo, big injectors, and built heads, and supporting mods....
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
