Go Back   PowerStrokeArmy > Power Strokes > 6.0 Tech
Reply
Thread Tools Display Modes
  #1
Old 08-22-2014, 05:03 PM
JD3020's Avatar
JD3020 JD3020 is offline
Colonel
Member's Gallery
Default Converting form auto to manual hubs
This is for my brothers 06 F-250. Currently have an issue where the front hubs are in the auto position but aren't unlocking. We had the same issue on our 99 plow truck but it was simple enough to put in a set of Warns and be done with it. But with these 05+ axles it looks like the only option is Ford parts. So where can we source manual hubs and what is needed to swap them in?
BTW this is the 2nd set of auto hubs on this truck, with 130k miles on it. So we are not going to put another set back in. Hell if it were up to me i'd put a manual t-case in it too and ditch all this vacuum/electronic crap.
__________________
Jimmy
2014 F-250 XLT, 68k, H&S IC pipe, Tyrant tunes and deleeted
97 F-250 ECLB 7.3/E4OD/4wd, 215k miles: FFD 250/200%'s, Swamps IDM, built trans. Built and tuned by me
01 F-450 crew cab, XLT ZF-6 7.3: tuned, intake, exhaust, 310k miles
05 Jeep Liberty diesel, tuned, EGR deleet
  #2
Old 08-22-2014, 05:07 PM
Radioflyer's Avatar
Radioflyer Radioflyer is offline
Major
Member's Gallery
Default
If your wanting to go full manual, then I vote for the Dynatrac kit. Really nice quality and comes with everything to convert it over to full manual hubs. If ya want a price, shoot me a PM.
__________________
08' CCSB F-250 6.4
GTX **SOLD**
  #3
Old 11-29-2016, 04:55 PM
eng53ine's Avatar
eng53ine eng53ine is offline
Lieutenant
Member's Gallery
Default
Bringing this back up, my dad is having the same issue. Cans he just throw a set of manual Warns on the truck? Will the switch still engage the 4wd when they are locked?
Thanks
__________________
02 F-250, 7.3, auto, ccsb, 4x4, 4'' duals, 6637, IH bellowed up pipes, RiffRaff billet wheel, canned 6 pos. TS
  #4
Old 11-29-2016, 07:51 PM
CTC DEEZUL's Avatar
CTC DEEZUL CTC DEEZUL is offline
General
Member's Gallery
Default
Quote:
Thanks
Yup. In winter I usually just leave my Hubs locked and when needed flip the switch and I'm good to go
__________________
Teamsters Local 444- Rolling Coal United
  #5
Old 11-29-2016, 09:33 PM
eng53ine's Avatar
Lieutenant
Member's Gallery
Default
Quote:
Good deal I thought it would be fine, but figured I'd make sure. Thanks
__________________
  #6
Old 11-29-2016, 10:08 PM
Zmann's Avatar
Zmann Zmann is offline
Colonel
Member's Gallery
Default
what year is his truck ?
if 05 up there is only one hub other than OEM and it's a pricey Warn
or the Dynatrac but thats a whole lot of parts and $$ just to get manual Hubs
OEM works just like a manual ( specially if you defeat the vacuum signal) and if it won't unlock the Warn ( yes they make the OEM)
turn the selector to Auto - unlock a few times and land on unlock
__________________
DTR RON Huxell's Memorial donation page please donate
https://www.gofundme.com/2464axqr
  #7
Old 11-30-2016, 12:26 AM
co04cobra's Avatar
co04cobra co04cobra is offline
Sponsor
Member's Gallery
Default
What do you mean turn the selector a few times? I just assume you mean the obvious of the hub turning it from auto to unlock?
In my experience a lot of times the hub is corroded to bad to get it to turn. Usually someone has already broke the center of the hub out trying to turn it with pliers.
__________________
00 cc/sb zf6 F250- Some stuff done always more to do-Fuel 300/200s Air-Garrett 68/94-Oil SRP 1-Airdog to Fuellab
97 cc/sb- zf-5- Work in progress. PMF rsk w/ SD axles. 66 turbo, E fuel, 230/100s. SB DD clutch.
08 cc/sb - Elite bottom end - 2 fuelers, 59vgt/78atmo, Midwest 100% nozzles and coated heads etc....
www.teddavisautos.com
Many parts available for super duty trucks PM me.
  #8
Old 11-30-2016, 11:01 AM
eng53ine's Avatar
Lieutenant
Member's Gallery
Default
Truck is an 06 F350 he's been messing with them. Auto feature hasn't work for quite some time. I wouldn't think oem hubs would be cheaper then the others but I haven't priced oem hubs for it. He just wants to have working hubs and isn't concerned about the auto feature.
__________________
  #9
Old 12-01-2016, 09:59 PM
06Amarillo 06Amarillo is offline
Corporal
Member's Gallery
Default
I don't see why you wouldn't want the auto feature. When you need 4wd it's there. And when it's not your not getting the extra wear on the front end. Nice option in my opinion.
__________________
2006 6.0 Amarillo
37/13.5-r20
200,000km
Sinister egr Cooler
Airdog2 165gph
5 inch turbo back stainless exhaust
  #10
Old 12-01-2016, 10:20 PM
Vader's Fury's Avatar
Vader's Fury Vader's Fury is offline
Colonel
Member's Gallery
Default
Warn all the way. I have them on all 3 of mine and love them. Just lock them before I do anything that might require 4wd.
__________________
Robert
2003 F-350 CCLB, Frame off restoration in progress
2002 F-250 ECLB, Parts hauler
2002 Excursion, Twin hauler
  #11
Old 12-02-2016, 04:53 PM
co04cobra's Avatar
Sponsor
Member's Gallery
Default
Quote:
It is a nice feature WHEN it works. Problem is it rarely works.
When the vacuum doesn't work, because seals etc.. are shot or PVM doesn't work, and hubs are corroded into the "auto" position it's a PITA.
__________________
  #12
Old 12-02-2016, 05:40 PM
Zmann's Avatar
Colonel
Member's Gallery
Default
what u guys are missin is the fact the 05 up only has OEM or 1 style of Warn available
and the aftermarket Warn are over 340.00
https://www.warn.com/truck/hubs/fordSuperDuty_Hubs.jsp
the OEM is also made my warn you can even get a manual version but they are the same as the auto minus a few pieces
__________________
  #13
Old 12-02-2016, 05:44 PM
co04cobra's Avatar
Sponsor
Member's Gallery
Default
I do know that. If the auto hubs turn they work the same as a manual lockout hub.
The "auto" feature working long term is the downfall.
__________________
  #14
Old 12-02-2016, 07:42 PM
JD3020's Avatar
Colonel
Member's Gallery
Default
Holy old post.
Anyways i guess i never followed up. We got manual Ford hubs and put in, and going on 2 years now without an issue. Hubs actually lock and unlock when you want them to. Amazing
__________________
Jimmy
  #15
Old 12-02-2016, 08:57 PM
Decker's Avatar
Decker Decker is offline
Sergeant
Member's Gallery
Default
I'm little confused... are you guys tossing on manual hubs from 99-04 super duty on a 05+?
I understand by doing this the auto feature would not work but still lock in the transfer case while you manually lock in the hubs.
what manual hubs you putting on the 05+?
__________________
06 F350 CCSB King Ranch
Studded, *******, upgraded banjos, blue spring,
6.7 fuel pump with sump, swamps 58v ficm
4in turbo back, coolant filter, guages, CAI,
SCT w/ IDP & TSD tuning & PHP ficm tuned
04 F250 CCLB XL - Sold
  #16
Old 12-03-2016, 03:26 AM
eng53ine's Avatar
Lieutenant
Member's Gallery
Default
Manual hubs for a 05+
__________________
  #17
Old 04-14-2018, 03:23 PM
chuckels chuckels is offline
Private
Member's Gallery
Default
Sometimes the two square fuse blocks driver side under the hood when one goes out it will stay locked in four-wheel drive . just take and switch them around and see if it unlocks if it does you need a new fuse. Just a thought.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
