Dealership quote on degas bottle, etc.
coxracen43
WV
Went to the local dealership today to get radiator pressure tested due to coolant leaking found under driver side wheel well. They said it wasn't losing any pressure however, evidence of leakage under degas bottle and hose, slight corrosion at left radiator tank.
Recommended me to replace degas bottle, cap, and degas hose, estimated repair $600.75. I declined lol
StrokiNDieseL
Geneva, Fl.
That's crazy, Contact sunrise on here b/c I was just quoted degas bottle list $174.30 sell $125.50 & that supply hose I also have recently replaced (has small oring w/snap ring style like rest of cooling systems) and that wasn't that much. Only thing I still need to invest is an airlift coolant prime tool but I haven't had any problems the 3 times I've refilled mine so far.. Good luck
coxracen43
WV
Thanks for the input! And how have you refilled yours the past 3 times? And how often should it be done? We are talking about the coolant right?
RSK
Connecticut
crossing my fingers that's where my leak is coming from too. Mine drips coolant down the radiator hose onto the track bar and sometimes onto the ground sometimes it doesn't but you can see something was leaking onto the drivers side radius arm...if its as easy as swapping out the degas bottle, it would be done now, and deff check with sunrise ford, there are two threads on here about it, best pricing in the country!
coxracen43
WV
Always something with these trucks lol
RSK
Connecticut
yah but i'm lazy and procrastinate bad, so my truck could be leak free, sometimes it doesn't leak coolant at all so i'm not sure about it. the oil leak is deff from my crank case vent or lack there of...
coxracen43
WV
Same here! Sometimes it'll leak and sometimes it won't. And I need to do ccv reroute but I procrastinate bad too..
StrokiNDieseL
Geneva, Fl.
Cap, parts store under $10.
1. Egr delete, 2. Thermostat replacement w/coolant flush & cat coolant, 3. Thermostat replacement/degas bottle upgrade. I refill & run w/cap off for 20+mins in hope of burping (idk if it helps) the system.
coxracen43
WV
Do I need to replace thermostat if I only 30k miles on the truck?
StrokiNDieseL
Geneva, Fl.
Mines only at 56K. Idk, peace of mind ($30) here & 2nd round was b/c of hi temps. I'd do Egr delete & flush at the same time if I ever had to do it again. Jayson
coxracen43
WV
Yea I figured I'd do the egr delete at the same time. And thanks for the input!
