American Force on stock height 2013 F250
RyanD
Guys,
Any of y'all running AF on stock suspension? I'm considering the independence in either 20x9 (0 offset, 4.5" BS) or the 20x10 (-25 offset, 4.5" BS) with a 35x12.50 and can't seem to find anyone running a similar setup to see if it's possible. Thoughts?
Thank you!
ChattyCathy
Guys,
Thank you!
Yep 22x10
BK39
Texas
325/50/22
I did have to cut off a bracket and do a good amount of trimming to the fender liner.
Have any more pics of your truck, different angles? I'm trying to figure out if I want to try and run 285 55 22s or 325 50 22s. I don't mind minor modifications if it'll get the look i want.
According to an online calculator I found:
285/55 22 is 34.3 tall 11.2 wide.
325/50 22 is 34.8 tall 12.8 wide.
I'm thinking the wider tire is going to look the best.
ChattyCathy
BK39
Texas
Ya man......that looks good. I think 325s are going to be the way to go.
laingenb
Geneseo Illinois
I'm running 20x12 with 35 inch toyo m/t's on an 08 f250. Only the rub is at full lock or when you're turning on an uneven road like an uphill driveway.
BK39
Texas
325/50/22
So I have my tires mounted, but it's hitting pretty hard on the actual fender itself. Did you trim fender liner AND the bottom part of the fender? Or do you have an aftermarket 3 link or something that shoved the axle a hair forward?
ChattyCathy
I did trim a little bit of the fender but not much. Also removed the bracket in the front of the wheel well.
BK39
Texas
Pic attached. What about here, circled in Green, once I cut back the first part, do the tires end up hitting this part of the fender too?
I'm thinking of maybe trying to bend the fender instead of cutting it. But I don't want to bend it if it's going to hit here too. At that point, might as well cut it.
ChattyCathy
Dang. I don't remember mine being that tight or high into to the fender. I only cut into the metal prior to the pinch weld, I also did not touch the pinch weld. If I had my truck here I would take a pic.
WHY NOT
Carlyle IL
I had to trim just a bit of the circled area to get my set up to clear even leveled. I am hoping that ALA's will push it forward a bit to clear better.
JColeman7827
I'm running 24x12's and 305/35 Terra's with a 1" level until my lift and new wheels come in.
truckman1974
Are you going to be selling the wheels that you have on there right now? If so, how much would you want for them? PM me..... I'm looking at some 22x12's right now but may be interested in some 24's if they're not cray cray expensive...
