2011-2014 Turbo Kits master list
jcain
Feel free to post what I missed and I will add it or fix it.
Elite Diesel:
Stock 2015 61mm turbo upgrade : $2799
Stock 2015 61mm turbo w/ billet wheel : $3499
Garrett GT3794 64.7mm turbo w/ piping, dp, air filter, and fuel filter relocate : $5200
Garrett GT4094 67.8mm turbo w/ piping, dp, air filter, and fuel filter relocate : $5600
Garrett Danville 72mm turbo w/ piping, dp, air filter, and fuel filter relocate: $6600
Fleece Cheetah 63mm turbo w/ piping, dp, air filter, and fuel filter relocate, Designed for 2.5 Sled Pulling class : $6400
Precision Turbo 6466 turbo (non vgt 66mm) w/ pedestal, piping, air filter, and fuel filter relocate : $6250
Precision Turbo 7168 turbo (non vgt 71mm) w/ pedestal, piping, 39mm wastegate, air filter, and fuel filter relocate : $7500
Precision Turbo 7668 turbo (non vgt 76mm) w/ pedestal, piping, 39mm wastegate, air filter, and fuel filter relocate : $7500
Industrial Injection:
ADDS a Borgwarner S475 turbo to your existing factory turbo and comes with everything needed : $4250
Midwest Diesel:
Stock 2015 61mm turbo w/ billet wheel : $3399
S300 kit w/ 63 or 66mm turbo w/ piping and dp : $4150
S300 kit w/ 63 or 66mm turbo w/ billet wheel, piping and dp : $4550
S300 kit like above with NO turbo : $3425
Maryland Performance Diesel:
NON vgt turbo kit 63-71mm cast or billet, new exhaust manifolds and piping : CALL for pricing
Snyder Performance Engineering (SPE):
Stock 2015 61mm turbo upgrade w/ new bearings : $2999
Stock 2015 61mm turbo w/ bearing upgrade, all piping, new intercooler and tuning : $4500
Spatel23
Olive Branch, MS
Great info here.....
If anyone has videos of any specific kit, PM me and I will edit the first post and attach them under the listed kit
Athens, IL
Anyone know the difference between the Midwest & elite 2015 w/billet wheel besides $100?
I can't speak for elite. But I am sure they are similar. Either one would perform very close on power.
We do have a larger option than the current 61mm TowMax vgt kit comin very soon. The StreetMax 64mm will be in testing within a week on my 2015. It will be reverse compatible back to the 11-14 with retrofit kits too.
1st last59
Elite also sells the upgraded piping for the tow max 15' turbo for $1100 I believe and say that it gains 30hp and 100 ft-lbs.
Trevor008
Maryland
When you say "reverse compatible", you mean they are built to fit the 11-14 but can be used on the 15 by retrofitting it with certain 11-14 parts correct?
Stangr8cr
It's a direct swap on a 15, the lower intake for sure changed on the 15. The kits make them fit the 11-14 trucks. Elite told me the kit comes with new up pipes and down pipe. Can't wait for it to get here!!
Keith
Athens, IL
No. It uses the new 2015 style turbo. The 2015 turbo requires changing parts from the intake manifolds, exhaust manifolds, piping, pedestal and basically everything that pertains to the old style turbo to the new style.
We have had the first '15 turbo retrofit that was actually on a running truck and available to be sold as a complete kit. We have an inclusive kit that has all parts needed to run the new 61mm 2015 vgt on 2011-14 trucks.
We have had real world testing results and back to back dyno results for a while. We changed NOTHING but adding the 61mm TowMax billet vgt kit (not even a tuning change) and dynoed back to back and netted 70+ hp and 170+ ftlbs. Again, we changed NOTHING but turbo kits. Pretty solid gains and drivability is very good.
We've sold over ten of these kits so far for applications from daily drivers to f550 service trucks.
My only complaint is parts availability. We cannot keep them in stock as fast as we could sell them. So now we are having to tell people that they are backordered before they make the decision to buy.
Take a look at this thread from earlier this year for more details, pics and videos of the kit.
http://powerstrokearmy.com/forums/showthread.php?t=52628
We will have a full stainless piping kit available in the next month that will work with 2011-14 trucks and 2015 trucks that use a '15 charger. It will replace the upper and lower intake manifolds. It will also be fully complete with the adapter to run your existing cold air intake or use a No-limit ect... Which will be a first if it's kind for piping. It will be available in raw or polished.
Here is a pic of the 61mm TowMax vgt sitting in the valley during installation on a 2011.
