S366 on stock fuel
Winchester, VA/ Bloomery, WV
So after going back and forth on what to do with my OBS I've decided to throw some money at it and just run it. I plan to buy Irates T4 kit and run a 366. Just looking to see who has thissetup or one similar. It'll be on stock fuel for a little while, then will be upgrading injectors. Not looking for anything crazy, just a good reliable rig for towing. Just looking for first hand experience and any other input.
Bair
Pinehurst Idaho
I ran a 366/74/1.0 on my stock obs for 3 years. E-fuel and beans tunes. It ran slightly stronger than a stock turbo. Definitely drivable if your set on doing the buildup in that order. I'd detune the injectors of your choice rather then doing the turbo first, but as I said, it's definitely drivable.
Bair
Pinehurst Idaho
There probably would be better turbo choices now. The 366 is attractive because it's cheap. I know some say they don't hold up. Mine is 4 years old. Ran 275/100's, stock for three years and now 180/100's. Still going strong. Spool up is another consideration. And I have no experience with other turbos.
