Warrens shop truck?
strokin6L
Springville NY
S475 TCT Bullseye turbo, dual hpop and like 565cc hybrids with 225% nozzles. He said only flowed like little over 400cc tho. But with a larger nozzle he's seen over 500cc on their flow bench. 2.4ms at 4000psi.
ford rules
Wow very impressive setup. Thats gotta be about the highest HP fuel only 6.0 id imagine.
I wonder what id do with say like a set of 225's
hawgdoctor
king george, va.
Yes, hey only flowed around 400 with the 7mm plungers, but he has the 8mm plungers which pushes them more towards 485 cc IIRC.
strokin6L
Springville NY
Yeah he is running 8mm plungers in the hybrids. He never gave an exact "cc" amount...he just said with the 8mm plungers the injectors flowed 400cc's on their flow bench.
strokin6L
Springville NY
Probably should have it built by a reputable trans shop then. If built right and tuned right....it should hold 1000hp.
TBagAMouseTrap
Windber PA
I don't think a reputable shop can offer anything more than I can offer myself. My builder is a senior master tech, 26 years at ford, 19 years building transmissions. Also has 3 heavy hitter 6.4 trans under his belt that pull regularly on the local pull circuit. I'm convinced it's tuning since it's a repeat offense 3 times with my '04 trans and 2 times with a 5r out of a '09. New epc and direct solenoids and new filters/sp fluid every build. Guess it's time to give gearhead a try. Also I have about $2700 total invested in all of the builds.
strokin20
brownwood, tx
Quick question, have you replaced your cooler? I had multiple failures in mine like that and we determined we weren't able to get all the fine clutch material out of the cooler. Replaced the cooler, and not one more problem.
Sent from my SAMSUNG-SM-G870A using Xparent BlueTapatalk 2
