First off, the packaging was about as good as it gets. Not a scratch on anything and all parts were protected from intrusion, after all we all know our fuel systems are sensitive as hell already. Secondly, the craftsmanship on the one off parts is perfect in every sense.
Onward:
1st and foremost, IF you have a TransferFlow or Titan tank, MAKE SURE you tell H&S that when you order, you'll see why later. Some of these pictures are mine, and some are H&S's, you can tell by how dirty mine is
Step 1: Clean up the drool and get to work... Lay out all the parts and make sure you have everything. We can go ahead and knock out a BUNCH of preassembly before we ever have to step foot outside of the house. Make sure you get yourself some locktite/permatex thread sealer for all the pipe thread fittings.
H&S install directions has the exact info on which parts to put where on the filter bases, pump, and regulator so I'll just show pictures.
This is what each group of parts should look like when complete.
Onward:
