Fumoto Oil Drain Valve?
BBottoms
Buffalo, KY
Have had one for 3 years/40k miles on the 6.4 without a problem. Had one on my OBS for 2 years too with no problem.
BKopp
I've had one in every truck I've had since early 2000's and never had an issue
Sent from my iPad using Tapatalk HD
StrokiNDieseL
Geneva, Fl.
1.5yrs, drainage is very clean & great for sampling in between changes. I just started changing out factory plug (magnet style) every other ish oil change just to see if everything's clean from researching others experiences.
NY_Mott
The Real "OC" NY
They should make one with a Magnet....
nickg9785
long island, ny
all of the Cat excavators at work have them. i am going to get one for my truck next oil change. if there good enough for Cat to use there good enough for me.
KingStroker
Central Louisiana
Just ordered one today, here's directly from Fumoto. Drain, cap, hose, and security clip.
These are the part numbers for a 6.7 by the way.
AllGo'N'Show
West Canada
Drain cap hose clip? That is a lot of options! I have the nipple'd 6.4 drain that I have my own hose for, put it in 2-3 years ago, oil changes are simple and fast, no mess now, super easy to send oil samples even though I've been slacking.
