That is what this calculator is for
![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
oke:. Stock 99-04 wheels have 4.5” backspacing and are 7” wide. So that would be 12 or 13mm of backspacing. Now you need to figure out how wide of a wheel you want and how far you want it to stick out past the stock wheel. Then use the calculator and do the math.
I don’t recall what the backspacing is for 05-07 wheels, and know anything of 08+. That might be a useful bit of info for those using this.
