Ford Dana 60 4.10 RSK 4" lift wheels and tires F250 F350 OBS - $2500 in MN
F-127
Located near Vergas, MN 56587
Craigslist listing with pics: Ford Dana 60 4.10 RSK 4" lift wheels and tires F250 F350 OBS
Selling as a package deal. Will keep complete for a while, then may divide up items(individual prices at bottom). Perfect time to get rid of TTB suspension on your OBS F250. Dana 60 ball joint axle 4.10 gears, leaf springs front(Super duty) and rear, 4" lift RSK front mount, rear shackle for front leaf spring, rear springs with 2" block, extended brake lines, pitman arm, drag link, track bar mount and track bar, wheels and tires, 2" wheel spacers, Bilstein shocks.
Complete package deal on parts above for $2,500 cash. Will also include rear axle in the package in case you have a 3.55 pickup. Prefer to have items inspected on vehicle with $250 down, remaining on pickup. Willing to travel half way for up to around 120 miles max to meet someone for inspection of items. Selling because I would lower it a bit with smaller sized wheels and tires and use a different and newer suspension if I keep the pickup.
Or buy complete pickup $13,500 1997 Ford F250 4x4 7.3l diesel crew cab short box F-250
Tires are 325/65R18(measures 34.6"x12.8") Toyo Open County A/T, center is wore with less tread than outer edge, can probably go another 5-10k or more without issue.
Wheels are American Racing Dale Earnhardt Jr. Cannon, very good overall condition, minor overspray on one wheel(pictured, not on chome/machined area)
Front axle is about 4" overall wider than rear, outside edge of front tires are about 84" rear is 80"
Rear fender well sit about 44" high at top of arch, front around an inch lower than rear
Front axle has ball joints replaced, could use right axle seal.
Will separate if I get interest in two items
Wheels with 8x6.5" bolt circle, tires, lugnuts, spacers. $800
Front Axle $1000
RSK lift kit $1000 (front and rear springs, rear block, front mount and rear shackle for front leaf spring, extended brake lines, pitman arm, drag link, track bar mount and track bar, bilstein shocks)
F-127
Price change.
Complete package $2,200 no rear axle
Rear axle $200 if buying all other parts.
Individual prices, will separate if I get interest in two items.
Wheels with 8x6.5" bolt circle, tires, lugnuts, spacers. $700
Front Axle $900
RSK lift kit $900 (front and rear springs, rear block, front mount and rear shackle for front leaf spring, extended brake lines, pitman arm, drag link, track bar mount and track bar, bilstein shocks)
F-127
Price drop. $2000
Most recent listing
http://fargo.craigslist.org/pts/5120749608.html
All parts removed and ready to go.
Right axle tube has had some welding to locate it, not sure if had been removed or what. I knew but forgot about it. It was done before I got the vehicle. I drove this pickup 17k miles like this. Does collect some dust around tube-to-center housing but never leaked an actual "drop" on the floor/ground. May need outer u-joints and RH tie rod. Brake life 90%+, tight ball joints, premium 9/10th turn Warn lockouts.
Wheels with 8x6.5" bolt circle, tires, lugnuts, spacers. $750
Front Axle Dana 60 4.10 gears $800
RSK lift kit $800 (front and rear springs, rear block, front mount and rear shackle for front leaf spring, extended brake lines, pitman arm, drag link, track bar mount and track bar, bilstein shocks)
Rear axle Ford 10.25 limited slip 4.10 gears with 08 diff cover $400
