2002 7.3 Trans temo running 250*+
Smokin 6.0
Indiana
Running my 2002 with a superchip the other day on the 85hp setting and my tranny started to over heat (250*+) I did away with the cooler that runs through the radiator and just put a cooler that is 14x8x3/4 in.. Thinking this is my issue and the cooler just isn't big enough. Any help is appreciated. Thanks
drunk on diesel
run them in series, but don't get rid of the fluid cooler. a fluid cooler is far more efficient than an air cooler
Smokin 6.0
Indiana
Ok I just did it because I toasted the last tranny and was afraid of metal shavings stuck in the radiator cooler.
drunk on diesel
I would definitely flush it.
if you're going external, you need a huge cooler. take a look at an OEM trans cooler for a diesel truck if they don't utilize water
Powerstroke Man 6.4
DEEZUZ
NO PUKESTERS
NWI
How in the hell does a trans get that hot? Hottest I've ever seen was 180 with 5k and a 203 ac on highway speed
Mark Kovalsky
SE Florida, USA
That is WAY undercooled for a stock setup. With an additional 85HP running through the trans I'm surprised it didn't get hotter than it did.
You need to junk that tiny cooler, it belongs on a Fiesta, not a truck. Get a cooler from a 6.0L truck, and I recommend the radiator cooler, too. If it were my truck I'd replace the radiator. I do not believe there is an effective way to flush it.
