New 6.7 drop in turbo options!
Athens, IL
Just going to put out a little drop for the new options of turbos we are releasing for the 6.7's. Nothing wrong with what we had but with the ability to improve, why not?
We will be offering three new sizes. A 62.5, 65.5 and, in conjunction with Barder turbo, the new 66/70.5 with large turbine.
Starting off with the smaller two being the 62.5 and 65.5 we are calling these the "R" series turbos. The 62.5 will be the TowMaxR and the 65.5 will be the StreetMaxR
The wheels go from left to right 65.5, 64, 62.5. You can see the difference and evolution of design. These wheels have been in design for a while and will move more air when compared to the old 61 and 64 versions. The blade design and more aerodynamic center allows for quicker spoolup and better top end flow vs previous designs.
All the new R turbos will share the same sintered iron 360 degree thrust bearing that we have been utilizing in our 64mm version. We have had them for quite a while with zero failures. All of them come assembly balanced which means the oppressor and turbine are removed and balanced together.
In the bottom picture you can see the stock 270 degree thrust next to our 360 degree version. Pricing for the new turbos will be as follows, TowMaxR $1799 plus $1000 core. StreetMaxR will be priced as $1999 plus $1000 core. They will also be available in retrofit kits for 11-14 trucks.
The biggest release and most anticipated is the new 66mm inducer with a 70.5 mm turbine from Barder that we have been testing for almost a year. This turbo has proven reliable and that it can support a ton of power for a drop in vgt. We seen consistent 750 hp dynos and track times that back those numbers. Has held drag racing, truck pulling, daily driving, towing and way more nitrous than it should have ever seen! The Barder 6670R turbo is the ultimate drop in 2015 charger. And the only one on the market with a proven background. These will all be made from new ford chargers. They will have the same $250 core that ford offers. Pricing is set at $3699 plus core. They are expensive but it you want drop in simplicity and big power potential this is the one! Not to mention the awesome Powermax like whistle!
All of these are now ready for order and will be able to ship within a week depending on options.
O4ep3civ
What's the stock specs on the 15 turbo in comparison
Sent from the front seat of my rocket ship
WHY NOT
Carlyle IL
Very nice Morgan. Just to clear things up in my head if someone has an 11-14 turbo and want the 65.5 the cost will be $2999 correct since our factory turbo won't go towards the $1000 core?
