Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 08-30-2015, 02:32 AM
n54power n54power is offline
Sergeant
Member's Gallery
Default hydra tuning -modified valve body vs non
Yes I've searched but no real answers.
Im.seeing a modified valve body option for each tune. Is there a benefit or downside to this.
I have a built trans but I'm not sure on the valve body used
Since the standard tune would increase line pressure, would this be a a safe option?
__________________
00 f250 ccsb
38r,4" mbrp,PHP FU,RR frx,RR plenums,RR everything,
6" w/37" tires
  #2
Old 08-30-2015, 06:04 AM
79jasper's Avatar
79jasper 79jasper is offline
Colonel
Member's Gallery
Default
Imo, if a trans is "built," theoretically it should have a "modified" valve body.
You don't know who built the trans, nor what they did to it?
__________________
2003 F250 KR SCSB FX4
Depleted, studded, airdog (which isn't currently hooked up), fass regulated return, airaide, 4 inch straight pipe with mbrp muffler(so on to go), glowchit pyro, fuel, boost, and trans temp. (Of course don't work lol) Hercules terra track A/T2 315/70/17.
2013 Honda pilot Touring
http://badges.fuelly.com/images/sig-us/778639.png
http://badges.fuelly.com/images/sig-us/776628.png
  #3
Old 08-30-2015, 10:15 AM
Northwoods2002 Northwoods2002 is offline
Sergeant
Member's Gallery
Default
While I rebuilt my own 4r100 and use the modified valve body (transgo tugger) tunes, I've often wondered how much line pressure php has in the stock tunes and if it would be detrimental to a modified transmission. Maybe Mark K or PHP will chime in?
__________________
2002 F250 7.3 Extended Cab Lariat Long Bed - AIS Air Intake; MBRP 4" Stainless turbo-back exhaust; Glowshift triple pillar w/EGT,ATtemp,boost; Racer X Eagle Modified Converter; 4R100 Completely rebuilt with upgraded H.D. internals and Tugger VB kit; Hydra Chip with PHP tunes
  #4
Old 08-30-2015, 10:26 AM
mandkole's Avatar
mandkole mandkole is offline
Major
Member's Gallery
Default
This is where its good for trans guys to talk to tuners. Will Bill do this?
__________________
2000 F250 CCSB GT4294R, 250/100s, Dahl/Fuelab, BTS, PHP tuning, stock 17* pump
1994 F250 SCLB
(sold)
1997 F250 CCSB 2wd (sold)
  #5
Old 08-30-2015, 01:04 PM
Sergeant
Member's Gallery
Default
The trans was built shortly before I bought the truck.goerend parts were used. The trans has about on it.
I'm religious on maintenance so it's healthy. I have been thinking about updating the valve body.
Going from a php FU with no valvebody tune options to the hydra with them I added a each to it.
Using the standard and modified I'll see how it deives
__________________
00 f250 ccsb
6" w/37" tires
  #6
Old 08-30-2015, 01:35 PM
Dmstrucks02's Avatar
Dmstrucks02 Dmstrucks02 is offline
Colonel
Member's Gallery
Default
When I installed the trango tugger kit Matt just said to see how it drove before getting a reburn. It drove and shifted great so I just left it
When I sent my chip in for the injectors- standard TS chip, I told them about the Trans mods but it shifts just like it did so I don't know if they changed much..
__________________
02 CCSB X code leafs on 33's
Texas Tuned
5" MBRP
Isspro gauges
  #7
Old 08-30-2015, 03:01 PM
Derek@Vision Diesel's Avatar
Derek@Vision Diesel Derek@Vision Diesel is offline
General
Member's Gallery
Default
I would start with the standard, non valve body tunes, and see where that gets you. Shift firmness is really the difference between the tunes and we have found quite often with John Woods transmissions and PHP tuning that the standard tunes work AWESOME. We rarely install the valve body tunes, I like the crisp tight shifts that you can feel.
  #8
Old 08-30-2015, 04:03 PM
Carolina444's Avatar
Carolina444 Carolina444 is offline
Sergeant
Member's Gallery
Default
I know the JW valve bodies that you buy from the vendors are setup for the tuner to add the line pressure desired. I tried the php "modified vb." tune and it shifted very soft and slow.
__________________
E99 f250 2wd cclb 261k, tymar intake,4" exhaust, stock turbo w/riffraff billet wheel,reg return, PIS 230/100, tuned by dynoproven and power-struck, hbjr, isspro's, ccv and ebpv ******, 140v idm, pmt1, jwvb 6.0 cooler
BASB coming soon!
  #9
Old 08-30-2015, 11:44 PM
Sergeant
Member's Gallery
Default
Good to know,thanks.
__________________
00 f250 ccsb
6" w/37" tires
  #10
Old 08-31-2015, 08:51 AM
Sergeant
Member's Gallery
Default
Ummm, this makes me wonder if I should recalibrate my hydra with a normal tune for comparison...
__________________
  #11
Old 08-31-2015, 09:46 AM
Gearhead Gearhead is offline
Major
Member's Gallery
Default
the main thing on the trans build/valvebody is how big the holes in the separator plate are and the linemod valve used. For the love of GOD... do not ever use the .5xx" line mod valve. it is not needed.
__________________
Matt Robinson
******** Automotive Performance
www.********automotiveperformance.com
  #12
Old 08-31-2015, 09:49 PM
4.0l sahara's Avatar
4.0l sahara 4.0l sahara is offline
Major
Member's Gallery
Default
Quote:
Yup the .500 line mod valve is good for one thing. breaking ****.
__________________
Champion Transmission & Diesel Performance
Phone-203-931-6178
old antiquated pos with some crap bw s467 fmw,irate rr/full fuel system,full force 350/200 injectors,irate SS gated t4 mount,arp studs,smith bro push rods,comp 910's, gen3, twin ipr's, ams1000 with co2, champion built 4r100,tuned by bill, etc
  #13
Old 09-01-2015, 07:52 AM
NC714's Avatar
NC714 NC714 is offline
Corporal
Member's Gallery
Default
What line mod valve is recommended? Something like .372 or .427 ?
__________________
2015 F350 Lariat CCLB Bronze Fire
Sold - 99.5 CCLB - PIS 175/80s, Irate T4/BASB, Adrenaline, Irate Reg Return, Dual stock pumps, Beans Sump, Hydra, ******** tunes, Mighty Trans Built 4R100
  #14
Old 09-01-2015, 10:28 PM
Major
Member's Gallery
Default
.372 with good tuning works perfect.
__________________
Phone-203-931-6178
  #15
Old 09-02-2015, 12:18 AM
Major
Member's Gallery
Default
If you have really grippy clutches and a lot of them you don't even need the 427. On mild builds the 427 is okay.
__________________
Matt Robinson
  #16
Old 09-02-2015, 01:49 PM
NC714's Avatar
Corporal
Member's Gallery
Default
Thanks for sharing. I have an appointment with a transmission builder next week and am trying to gather as much information as possible.
__________________
  #17
Old 05-14-2018, 06:54 PM
bassthumper's Avatar
bassthumper bassthumper is offline
Private
Member's Gallery
Default
I just installed the PHP Hydra on my '00 F350 7.3. I see this has been a question that has been around for some time bu I don't really see a clear answer. I am not the original owner of the truck. Yes it has had a shift kit if some sort put in it but the original owner (whom I happen to know) does not remember what all was done inside the tranny. When using the tunes that are not listed as "modified valve body tunes", my truck shifts super hard..... So much to the point that it is concerning. I haven't used a modified valve body tune yet simply because I do not know what the differences are. I have since went back to the default 00 tune until I get this figured out because I don't want to potentially damage my truck.
Does anyone have any further information on this?
Thanks...
  #18
Old 05-14-2018, 09:12 PM
79jasper's Avatar
Colonel
Member's Gallery
Default
So try one for a modified VB......
Sent from my SM-G892A using Tapatalk
__________________
  #19
Old 05-15-2018, 07:25 AM
Private
Member's Gallery
Default
My concern is since I do not know exactly what is there if it will damage anything. That is causing inadvertent damage.
  #20
Old 05-15-2018, 08:14 AM
DieselDC's Avatar
DieselDC DieselDC is offline
Sergeant
Member's Gallery
Default
Quote:
If so, buy a vb you would know the
History of from BTS.DIESELSITE.JW.SamWyse. feed thay directly to the tuner and be done with ti.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
  #21
Old 05-15-2018, 08:23 AM
Private
Member's Gallery
Default
If thats my option only then i will just go in it and find out the vb thats installed...... my question is more related to the tunes which no one has answered.
i appreciate the info. i will probably just go in the tranny at some point and research it.
  #22
Old 05-15-2018, 08:29 AM
DieselDC's Avatar
Sergeant
Member's Gallery
Default
Php will give you a custom tune per Transmission specs. I used a transgo kit and they wanted to know specifically what components were used. Gave it to them and the result is a transmission that shifts as smooth as my BTS 4r100.
—————signature—————
  #23
Old 05-15-2018, 08:43 AM
mandkole's Avatar
Major
Member's Gallery
Default
If you even remotely think the VB or trans is modded (has line risers, etc.. ) automatically select no trans tuning for your engine tuning package. To me, risers in the tunes are just another way to kill a perfectly good stock trans.
__________________
1994 F250 SCLB
(sold)
  #24
Old 05-15-2018, 10:12 AM
79jasper's Avatar
Colonel
Member's Gallery
Default
Quote:
Wouldn't it be the other way around?
Since typically tunes for a auto have already been customized. So maybe "w/modified valvebody" is lesser trans tuning/lower line pressure?
__________________
  #25
Old 05-17-2018, 11:06 AM
General
Member's Gallery
Default
Correct.
If you have line pressure being raised mechanically in the transmission you would select "w/modified valvebody". This will lessen the added pressure from the tune.
  #26
Old 05-17-2018, 08:49 PM
mandkole's Avatar
Major
Member's Gallery
Default
Thanks guys for the clarification.. 👍
__________________
1994 F250 SCLB
(sold)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
