smokinstroker
Working on stripping the truck down and going back to stock to trade it in.
Ideally I would like someone in the area to save on shipping back and forth.
Everything is still on the truck and needs to be removed but the truck is just parked collecting dust. I would be happy to workout swapping parts or paying for them to be removed to work on pricing.
Make an offer on anything you are interested in.
Located in San Antonio, TX or surrounding area
Elite 76mm atmo (factory low pressure needed in swap)
RCD 59mm vgt (no core needed)
MPD log style manifolds and up pipes (no cores needed)
No Limit intake
No Limit cold side
No Limit hot side with bd blow off valve
White FX4 grille with carriage works billet grille
MBRP stainless dual exhaust down pipe back
OUO ALA arms
OUO short gusset traction bars
Icon trac bar
Icon 1" spacer
Carli 4.5" coil springs
Carli 4.5" leaf springs
Fox 2.5 DSC adjustable resi shocks (all 4 corners)
True trac rearend (if someone wants to swap full axles *must be 3.73 gears*)
No Limit intake
No Limit cold side
OUO ALA arms
Icon trac bar
Icon 1" spacer
