Edge CTS2 Sale !!
bigrpowr
<How I Fly
Administrator
On Sale Now !
$349 Shipped. Purchase includes a free shirt as usual !
Black AOD
Ohio
I already Own a CTS 2. And I run all Mikes Piping....how do i Get a free t-shirt? :pimp:
Extended Power
So does it read inject control pressure?
Your link, and the Edge website don't say....just that different years have different features...more or less.
If it reads ICP for my 2003, I'd be interested in one for sure!
Extended Power
Thanks for the help Mike!
Looking forward to hooking it up, and gettin rid of some gauges!
slowcoupe
Las Vegas, NV
Order placed. I too was curious about what PIDs the CTS2 read so I contacted Mike but I know hes busy with SEMA stuff so I called Edge and got the PIDs that are supported by the CTS2.
99-03
Accel Pedal Position
Battery Voltage
Engine Oil Temp
Engine RPM
Exhaust Back Pressure
Gear with TCL
ICP Pressure
Injector Pulse Width
Intake Air Temp
IPR Duty Cycle
Manifold Abs Pressure
Mileage Coach
MPG Instant
MPG Average
Time 0-60
Time 1/4 mile
Timing
Trans Temp
Turbo Boost
Vehicle Speed
Waste Gate Control Duty Cycle
03-07
Barometric Pressure
Battery Voltage
Corrected Speed (03-04)
Engine Coolant Temp
Engine Load
Engine Oil Temp
Engine RPM
Engine Run Time
Exh. Backpressure
FICM Voltage
FICM Synchronization
Gear with TCL
ICP Pressure
ICP Voltage
INJ Press Regulator
Intake Air Temp
Main INJ PWR
Mass Air Flow
Mileage Coach
MPG Instant
MPG Average
TCC Duty Cycle
Time 0-60
Time 1/4 mile
Trans Fluid Temp
Turbo Boost
Vehicle Speed (04-07)
Variable Geometry Turbo Duty Cycle
08-10
Barometric Pressure
Battery Voltage
Corrected Speed
EGT
Engine Coolant Temp
Engine Load
Engine Oil Temp
Engine RPM
Engine Run Time
Gear with TCL
Intake Air Temp
Mass Air Flow
Mileage Coach
MPG Instant
MPG Average
Regeneration Status
Time 0-60
Time 1/4 mile
Trans Temp
Turbo Boost�
11-15
Ambient Air Temp
Barometric Pressure
Battery Voltage
Corrected Speed
Dist. Between Regens
Dist. Since DTC Clear
Dist. Since Regen
D P F Pressure
D P F Soot Mass
DTC Count
EGT Post D P F
EGT Pre D P F
EGT Post Turbo
EGT Post SCR/Pre D P F
Engine Coolant Temp
Engine Load
Engine Oil Temp
Engine RPM
Engine Run Time
Fuel Level
Fuel Rate
Gear with Reverse
Gear with TCL
Intake Air Temp
Mileage Coach
MPG Instant
MPG Average
x PPM
Regeneration Status
Reductant (Urea) Level
Time 0-60
Time 1/4 mile
Torque
Torque Soleid Pressure
Trans Temp
Turbo Boost
Fuel Pressure
EGR Temperature
Fuel Injector Pulse Width
Fuel Injection Timing
Charge Air Temperature
08Monster
I don't think that is a full list though. It reads FRP on my 6.4 and that is not on your list.
Illinois
I'm looking to purchase a CTS2 with an additional sensor to monitor oil pressure. Can you guys PM me a price ?
Thanks,
Pete
