stroker221
I replaced my rad with a mishimoto a couple thousand miles ago after it started leaking. Now I've got a leak coming from directly below on the backside of my k16 or beside it somewhere. I've downloaded the PDF on our cooling system to try to figure out where its coming from with no luck. Its not coming from the head or block freeze plugs. The bottom of my trans pan is covered with coolant. Like I said, I've followed it really high up on the block with a mirror but I can't seem to pinpoint it. Any ideas??
