delayed reverse
Welderup
Trucks been having a delayed reverse or almost like a false neutral every once in a while. Trying to figure out if it's a tuning issue or valve body anyone have any input on this on the best way to diagnose the problem. Trucks a 2013 with 36k ******d with sct.
BOHICA256
Midland, Texas
Mine started doing it at around 90K and I brought it in at 99K. They ended up putting a new transmission in. And I'm at 175K and its doing it again. Just every once in a while though.
Raynor
Mine did it today. It better not be burnt clutches, I only have 34,XXX and I baby it.
i had a issue once after switching tunes where it would seem like it just popped out of gear and hit neutral. i talked to Rudy's about it. they said reload the tune. did that and no problems ever since..
the reverse delay i have also but i blame that on shifting into reverse to fast before coming to a complete stop first.. if i stop then shift, no problems..
Jmuck
I had an 11 that I bought with 88K on it. Started doing the same thing at 90K, traded for a new one shortly after and it was back in the dealer getting a trans a couple months later.
CallMeColt
Mine only started doing this right after a tune & ******. Only happens once in a blue moon. I will try making sure I'm completely stopped before shifting.
Also going to try & re-flash the tune & do the proper "learning" that I've been reading about on here as well.
CallMeColt
No luck with the re-flash. Doesn't do it a lot. When it does, a light tap on the accelerator gets it in gear.
NCSU dirt man
Ft. Bragg, NC
mine used to do it at 98K miles with PIP tunes. bought new tunes and did a trans re-learn and it never has since then which i thought was kinda weird?
CallMeColt
I got updated tune files & I haven't had it happen since then. Been about 10,000 miles.
