16 inch Wilwood brakes install
weekendwarriorfsw32
Central California
Just got one of the first 100% Wilwood brakes kits from them. I'll put some pics up as I go but all I can say so far is everything is HUGE!!! Very excited to put this kit on. I will be doing some before and after stopping results from 60-0 with the current stock brakes I have on it now and after with the new brakes. :thumbup:
weekendwarriorfsw32
Central California
Here the whole kit
These rotors are MASSIVE
And same for the calipers
Heres what there going on
UNBROKEN
When I put the 16" front kit with 8 piston calipers and 15" rear with 4 piston on my little RCSB Ram 1/2 ton I thought I was gonna fly through the windshield. It stopped ridiculously quick. I imagine you'll have a similar experience.
weekendwarriorfsw32
Central California
Did some before numbers with the stock brakes.
Truck weighted 8,600 with the 2 of us in it and a full tank of fuel, all tires were at 40psi and it was 44* out side. I did 3 60-0 runs in a row on a long flat stretch of road.
1. Was 173 Ft
2. Was 158 Ft
3. Was 165 Ft
So the average was 165.3 ft so I will be shooting to beat that when I slap on these bad boys.
weekendwarriorfsw32
Central California
Well at a stand still right now. Apparently even tho wildwood says it will clear 20's it doesn't. I have had 3 sets of 20's so far and none will clear the caliper even after machining the brackets it still won't clear. Pretty bummed and even after a call the useless people that man the phones at wildwood no direction to go.
UNBROKEN
Everyone else's 16" kit requires a 22" wheel....I wonder why they think theirs is different?
Those big fixed calipers take up some real estate too.
I ran into a similar issue with 4 piston SSBC calipers clearing SRT10 wheels...they said they did but I proved they didn't and then they wouldn't do a refund because I mounted them. I was a little pissed to say the least.
