6.4 Powerstroke 2.5 Truck Puller
krasselt21
Well the long awaited truck build. Kept this quiet for the most part. been a very long build and process to get it done. Hopefully will be ready in the next week or two. I bought a 2009 f350 6.4 with a zf6 speed blown up. turning into a dedicated 2.5 sled puller. big shout out to morgan and the guys at midwest diesel and auto. been great help and awesome to deal with. the build consists of the following:
2 New Ported heads
Bored 20 Over Block
Balanced Rotating Assembly
Midwest Valve Springs
Midwest Push rods
Midwest Piston cut and coated
Midwest S400 turbo Pedestal
Midwest 100 over injectors
Midwest dual fueler
stage 4 cam
ported intake manifold
south bend competition clutch
no limit cold air
fluid damper balancer
custom 4 link
custom traction bars
custom hitch
custom electric fan
custom weight bracket
custom adjustable suspension stops
custom 1 piece rear driveshaft
roll pan and sled stops
fuel cell
stack
nitto terra grappler g2
The truck will be running central wisonsin, new motorsports, western Wisconsin and some south west Wisconsin pulls.
http://s1126.photobucket.com/user/krasselt21/media/IMG_0374_zpsg6rieco6.jpg.html
IMG_0358_zpswaryjev1.png.html
IMG_0553_zpsbfajvhqf.jpg.html
IMG_0467_zpsysu5y3ic.jpg.html
http://s1126.photobucket.com/user/krasselt21/media/IMG_0468_zpsoyg5sdgv.jpg.html?sort=3&o=17
http://s1126.photobucket.com/user/krasselt21/media/IMG_0488_zpsxciodpaf.jpg.html?sort=3&o=13
http://s1126.photobucket.com/user/krasselt21/media/IMG_0378_zpshhoswvkc.jpg.html?sort=3&o=46
http://s1126.photobucket.com/user/krasselt21/media/IMG_0373_zpsh26oyffx.jpg.html?sort=3&o=51
http://s1126.photobucket.com/user/krasselt21/media/IMG_0547_zpscx7ybfkq.jpg.html?sort=3&o=8
http://s1126.photobucket.com/user/krasselt21/media/IMG_0370_zpscubsrszn.jpg.html?sort=3&o=54
krasselt21
no rods. I'm pretty sure morgans 2.6 truck ran with stock rods. our rules limit us to a s400 cast charger. not huge boost numbers
krasselt21
well had a little mishap in richland center on may 14th. wrecked a turbo, had an oiling issue. just went thru and replaced pump and regulator and re tested supply everything is good to go now. Had some good help from Joel on my kill switch, was ready to go this past weekend but rained every day. shooting to hook it Friday nite and Saturday nite.
krasselt21
Here are some changes. Had rear aluminum hubs mad. Wilwood brakes front and rear. Aluminum front rotor. New intercooler and fresh air piping. New weight box
webb06
Seneca, MO
I'd like to see what you did with those positive battery cable connections. I've got mine like the picture right now and I'd like to make it look cleaner
