not enoughsmoke
I have decide to sell my 1999 F350 fummins.
Motor is a fresh rebuild motor less than 200 miles on new motor
truck has 530,000 miles on it
orginally truck was a 2wd,powerstroke,auto
now cummins ZF6, Ford 271,01 dodge dana 80,and ford dana 50
mods
Engine
marine pistons STD bore
STD rod and main bearings
new oil pump
billet piston coolers
titanium valve keepers and locks
60lbs valve springs
billet freeze plugs
billet tappet cover
5x17 schied diesel injectors
215 pump 5gsk 131 delivery valves flowed out from Seth
areomotive fuel pressure regulator
Banks Twin ram
Ats T4 ported manifold
Billet 63/73/.91 new with motor
Fass 240gph with billet sump
South bend Dual disc 3600 diaphragm pressure plate,ceramic buttons and bronze inlay
new cummins block heater
New oil cooler
breather setup with catch can
2 10"electric fans
4" down pipe with 5" exhaust 52" semi muffler all painted, 6"x18" tip
Isspro gauges boost,pryo,fuel,turbo backpressure
Autometer 5" tach with recall
katskin black leather covered front seat with cummins in headrest
Pioneer DVD/cd/stereo
1500 kicker amp
2 10" alpine subs
all door speakers are kickers
front half of cab has sound deading done
Amp power steps
8.5" Procomp lift
tires are 85% tread
37x13.50 toyo mt
on 20x12 XD diesel blacks
08 tow mirrors
2011 taillights conversion
new B&W goosneck hitch
Mag-Hy tec diff cover
Dodge Dana 80 with disc brakes
Top gun customz dualsteering stablizer setup
warn lockouts
front has adapters to 8x170 to 8x6.5 lug pattern
rear is 8x6.5 lug pattern
mods
Engine
new oil pump
60lbs valve springs
billet freeze plugs
billet tappet cover
Banks Twin ram
New oil cooler
2 10"electric fans
1500 kicker amp
2 10" alpine subs
Amp power steps
8.5" Procomp lift
tires are 85% tread
37x13.50 toyo mt
08 tow mirrors
warn lockouts
