Go Back   PowerStrokeArmy > Non - Specific > Welding & Fabrication Forum
Reply
Thread Tools Display Modes
  #1
Old 10-11-2016, 02:26 PM
UpstateDieselGuy's Avatar
UpstateDieselGuy UpstateDieselGuy is offline
Lieutenant
Member's Gallery
Default Entry Level MIG Welder
My father in law gave me an oxy/acetylene torch set which got me thinking about a welder. After looking around, I'm thinking an entry level MIG would be the best for me. I'm thinking that a gas/gas less setup would be ideal. Just looking to pick some brains. Thanks, Chris
__________________
2015 F-350 Extended Cab Short Box Lariat; Tuxedo Black with Black Leather Interior; 8 1/2' Fisher MM2
  #2
Old 10-11-2016, 02:39 PM
David1089 David1089 is offline
Sergeant
Member's Gallery
Default
Fluxcore is your option for gasless and it's not ideal for much. Maybe thin mild steel. I'd suggest a system that allows the use of gas all day. It's smoother, more consistent and easier to control
__________________
2015 F2SEXY Platinum!!
  #3
Old 10-11-2016, 02:41 PM
Skill_Kills Skill_Kills is offline
Sergeant
Member's Gallery
Default
I learned on a lincoln sp135. IIRC I liked it. had a gasless machine at home and i hate it. Now i have a hobart Ironman 230 which i love. Also ran a Miller 250 in school and liked it quite a bit as well.
If id get an entry level machine id just grab a 110v gas mig welder. flux machines are frustrating IMO
__________________
-Brian = Fulltime Farmer, Part time Welder
'53 F250
S468, 250/200s, ARP studs, COMP springs, smith bros pushrods, South Bend DD Clutch, Irate fuel, 1023tunes on hydra
02 350 CCSB 7.3L Lariat 4x4
Farm truck. homemade flatbed
  #4
Old 10-11-2016, 02:52 PM
Flounder_Pounder's Avatar
Flounder_Pounder Flounder_Pounder is offline
Sergeant
Member's Gallery
Default
Quote:
Ditto, try and save up for a 220 machine if you can. As an owner of Hobart 140....I wish I'd saved up for a 120/240v machine such as the 210 MVP
__________________
Travis T
1999.5 F350 4X4 CC LWB (mine)
2002 F250 4X2 CC SWB (wife's)
  #5
Old 10-11-2016, 04:09 PM
TRUBBS's Avatar
TRUBBS TRUBBS is offline
Lieutenant
Member's Gallery
Default
i have a millermatic 211 and really like it a lot. can be done either 110/220 and will do 035 wire
__________________
Just another 6.4 on the road waiting to split a piston
  #6
Old 10-11-2016, 05:34 PM
Lieutenant
Member's Gallery
Default
Thanks for the input. So many options out there!
__________________
  #7
Old 10-11-2016, 06:15 PM
fine69's Avatar
fine69 fine69 is offline
Major
Member's Gallery
Default
I have a 200 amp, 240 volt Lincoln MIG I bought at Home Depot. It will work with or without gas, and weld steel up to 1/4" thick. I've never used it without gas, only with Argon. It works great, and I'm a newbie welder!
__________________
2009 F350 4x4 CCLB
  #8
Old 10-11-2016, 06:23 PM
89 Stroker's Avatar
89 Stroker 89 Stroker is offline
Major
Member's Gallery
Default
Any of the Miller Matic's would do you good. 100% C02 is cheap gas, gets good penetration but does not look as good as 75/25 ect.
i would arc weld before i used flux-core, unless your burning thick stuff.
Check out CyberWeld.com , they have good prices on just about everything.
__________________
-Jeremy
Got A Few Rides...
  #9
Old 10-11-2016, 06:30 PM
78f100's Avatar
78f100 78f100 is offline
Major
Member's Gallery
Default
I have a Hobart handler 190 from tractor supply, it's a great welder for the average guy. Iirc they are 800$ish
__________________
08 F250 ccsb 7.40@82mph with a broke trans.
Lord help me be the man my son thinks I am.
  #10
Old 10-11-2016, 06:52 PM
Mechcont Mechcont is offline
Corporal
Member's Gallery
Default
The biggest question is what are you looking to weld and what is your budget. If your looking for a cheap learning machine that will weld 3/16" and thinner a 120v machine will do if your looking to be able to learn and grow with the machine definitely get a 120/240 machine. With that said a few good 110v machines are the longevity 140 and the hobart 140 for under $500 and they will both run flux core. The miller 211, 212 and the o matics are great but will cost you some money but you can weld anything you want.
Just my opinion but stay away from flux core unless your welding outside and use a 75/25 mix there is less smoke the welds are much better looing.
__________________
2015 *****ed, S*****N SOTF, No Limit Stage 1, 5" Flo Pro, Rigid Industries, No Limit CCV relocate, BDS radius arms, BDS 2" leveling blocks, BDS Leaf Springs, PMF Track bar, Fox, Carli.
  #11
Old 10-11-2016, 07:06 PM
89 Stroker's Avatar
Major
Member's Gallery
Default
ideal would be 75/25 although i have been using 84/16 lately with great results. Like i said 100% c02 is the cheapest of them all it just doesn't look as good, but gets the best penetration.
__________________
-Jeremy
Got A Few Rides...
  #12
Old 10-11-2016, 08:03 PM
bluedge8's Avatar
bluedge8 bluedge8 is offline
Colonel
Member's Gallery
Default
Quote:
I bought the Hobart hanlder 190 and like it a lot, I did overwork it this summer repairing a car trailer, I hit the overtemp shut down on it a lot, I didn't think that would happen stitch welding but it did. The first one I had was a 120v which I thought was really important but with a couple of extension cords I built I haven't had any problems with where I need to weld.
__________________
'96 f350 cc lb 4x4, 6637, auto, 264k Pretty much stock
'03 chev 2500 crew cab duramax 395k bone stock
'02 F350 dually, Lariat, auto, banks everything, hydra on the way.
Quote:
Originally Posted by Arisley View Post
D3leted 6.0's are the best. D3lete them and replace with a Cummings.
  #13
Old 10-12-2016, 04:24 AM
little luke's Avatar
little luke little luke is offline
Major
Member's Gallery
Default
I run a Miller 211. Pretty versatile little machine. I recently built a welding table with it that involved welding a lot of 1", 3/8" and 1/4". Yes it was wide open the whole time and I burned up the stock gun about half way through the project. I would have rather used my stick welder, but it was at another job for two weeks and it's a pain to transport.
__________________
2006 F250 Amarillo Edition. Extreme X, industrial injection stage 1 hybrid, studs setting in my room
  #14
Old 10-12-2016, 04:40 AM
tbsimmons's Avatar
tbsimmons tbsimmons is offline
Major
Member's Gallery
Default
I started with a Lincoln Weldpack and now have a Miller. I like the way the Miller welds better than the Lincoln but that is preference only. Both did a good job. Never welded with a Hobart but I have been told they are good also.
__________________
16 F350 DRW 4x4 - Stock and staying that way, Well I think it will.
  #15
Old 10-12-2016, 05:22 AM
Major
Member's Gallery
Default
Quote:
I used a Hobart handler 187 before the Miller. I prefer the millers performance over the hobarts.
__________________
  #16
Old 10-12-2016, 05:37 AM
Sergeant
Member's Gallery
Default
Can learn A Lot from this guy Jody http://www.weldingtipsandtricks.com lots of great YouTube videos
__________________
Travis T
  #17
Old 10-12-2016, 06:24 AM
m j m j is offline
Major
Member's Gallery
Default
depends on you situation, but a 200amp welder like a miller 250/251/252 is pretty much as good as it gets on single phase power and will do everything you can weld probably for your lifetime.
the price for quality smaller welders doesnt get cheap enough to justify their lack of duty cycle IMO
a lot of the smaller welders like to use a number in the 200 range on the side of the case but many are 90amp or less when you read the 60% duty cycle spec that is industry standard.
they have a 2?? hobart (amps at 60% are way under 200) in the shop at work but when I have to work winters doing repairs I just bring my 251 miller from home.
__________________
Quote:
Originally Posted by Chvyrkr
BTS transmissions have the absolute top of the line hard parts and clutches, in every single one.....every once in a while that somebody like Mike O or Charles gets a different piece, because they've broken his normal piece.
  #18
Old 10-12-2016, 06:47 AM
521turbo's Avatar
521turbo 521turbo is offline
Sergeant
Member's Gallery
Default
Lincoln MP 210 is an awesome welder. 110/220. also has the option for tig attachment, and ARC. You can fide them for around a grand.
  #19
Old 10-12-2016, 07:27 AM
Lieutenant
Member's Gallery
Default
Small things for now. I have a plow frame that needs some rust repair and I'm sure other things like exhausts, trailers, etc. will come along. I have friends and family with stick welders, but think the MIG will be better for what I am after.
__________________
  #20
Old 10-16-2016, 06:44 PM
mandkole's Avatar
mandkole mandkole is offline
Major
Member's Gallery
Default
Hobart handler 187 here also. Uses the Miller gun assy and easy to get parts for-been happy with it.
__________________
2000 F250 CCSB GT4294R, 250/100s, Dahl/Fuelab, BTS, PHP tuning, stock 17* pump
1994 F250 SCLB
(sold)
1997 F250 CCSB 2wd (sold)
  #21
Old 10-16-2016, 06:54 PM
Dirtclod's Avatar
Dirtclod Dirtclod is offline
Lieutenant
Member's Gallery
Default
What are your goals with buying a welding machine?
  #22
Old 10-20-2016, 02:25 PM
Lieutenant
Member's Gallery
Default
Smaller projects in the garage.
__________________
  #23
Old 10-24-2016, 06:42 AM
m j m j is offline
Major
Member's Gallery
Default
Quote:
that is a perfect example
Rated Output
120V: 100A/19.0/40%
230V: 200A/24V/25%
they dont even list a 60% duty cycle rating.
says 210 on the box but is more likely a 60 amp welder.
__________________
  #24
Old 10-27-2016, 07:06 AM
Sterling B.'s Avatar
Sterling B. Sterling B. is offline
Sergeant
Member's Gallery
Default
Quote:
Another vote for the MM 211. I go it because I didn't have access to a 220 plug, but wanted the option to run on 220. I really wanted the 252, but without access to the power to run it, it would have been useless.
__________________
'00 F250 ECLB 4x4 315/75R16 Cooper STT Pro
F450 front and 350 DRW Springs w/ PMF front Shackles
370K miles and counting
DP Tuner: Stock, 40T, 60T, 80E; 6637 air filter
5" Flo-Pro, B&W Turnover Ball, Sinister coolant filter
ISSPRO EV2s (Pyro, Boost, Trans)
'15 F350 CCLB DRW... basically stock
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
