5r110 reverse issue
08_6.4stroker
Listowel ON Canada
Hello all, So recently my brother in laws truck has been slow to engage into reverse. He needs to rev it up a bit to get it to move. There are no codes,we have changed the reverse,direct, and line pressure solenoids with no change. We have read pump pressure at an idle.
P/N 95psi
R 80psi
D 100psi
3 110psi
2 110psi
1 110psi
Transmission is a used one he picked up with 45000miles has been running it for a year without an issue until now. Truck is a 2009 f250 running H & S HD300.
Any help would be appreciated.
Lipka101
Maryland
What should pressures be. I'm not sure on the 5r110 but reverse is usually the highest pressure. Sounds like there is a leak bleeding off pressure in reverse
Bustedknuckles
P/N 95psi
R 80psi
D 100psi
3 110psi
2 110psi
1 110psi
Sorry i ment to quote you and quoted the guy asking a question. My bad. Lol
Mark Kovalsky
SE Florida, USA
Yes it does.
5R110 Pressure Chart:
Line Pressure - Idle
P,N - 50 psi
R - 100 psi
D - 70 psi
3 - 80 psi
2 - 80 psi
1 - 80 psi
After studying this, I think the leak is probably in the low/reverse clutch. That would cause low pressure in P,R, and N, with a slight loss in D. That's what I see here. I don't know why the others are high.
Oroville, CA
There was no clutch material in the pan and the fluid looked new. And it drives fine just the reverse issue. Could be the clutches tho?
Half the ones I take apart have almost no clutch material in the pan and the fluid is still decent. My guess is that the clutches wear so slowly that the junk makes it to the filters and everywhere else in the trans.
