Go Back   PowerStrokeArmy > Power Strokes > 7.3 Tech
Reply
Thread Tools Display Modes
  #1
Old 10-19-2011, 11:52 AM
Dieselfever's Avatar
Dieselfever Dieselfever is offline
Sergeant
Member's Gallery
Default P1209?
I came across a code in a truck that is having an intermittent loss of power. The code is P1209 - injector control pressure peak delta test fault, I have not seen this code before ad was wonder if there was some insight on it
Also had P1211 for ICP above/below desired, but ran fine and ICP and IPR duty cycle were fine when I drove it
-Michael
__________________
Michael
1997 F350: Regular cab XLT, 7.3L PSD, S5-47, 4x4 - Work in Progress
2002 Excursion: Limited, 7.3 PSD, 4R100, 4x4 - Some stuff
2010 GOLF: 2 door, 2.0L TDi, 6 speed - Still stock
Powered by: SWAMPS DIESEL PERFORMANCE AND TECHNOLOGY
  #2
Old 10-19-2011, 09:01 PM
JLDickmon's Avatar
JLDickmon JLDickmon is offline
Major
Member's Gallery
Default
the P1209 would make me start looking at the ICP sensor on the left head.. a lot of times they like to leak into the wiring pigtail.. other times they get a layer of glop built up over the end of it..
could have a bearing on the 1211 code, but a lot of times you see that one if you're running hot tunes on a factory HPOP, and the HPOP simply runs out of oil..
__________________
'99 7.3
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
