Go Back   PowerStrokeArmy > Power Strokes > Excursions
Reply
Thread Tools Display Modes
  #1
Old 05-09-2017, 03:25 PM
bordo380's Avatar
bordo380 bordo380 is offline
Corporal
Member's Gallery
Default Is a 4" exhaust worth it?
A friend of mine has a new turbo back exhaust laying around that I can get for 200 bucks.
I've researched that it may not be worth the trouble.
Who has installed the 4" DP with out trouble?
As of now it's stock with what looks like a couple of big glass packs in place of muffler and CAT.
Mods :TS Chip, S&B, DieselSite BRV.
Thank you.
  #2
Old 05-09-2017, 05:13 PM
Bgdiesel's Avatar
Bgdiesel Bgdiesel is offline
Private
Member's Gallery
Default
Only worth it if it's new, otherwise just buy new buddy
__________________
'96 RCSB PIS 400/400's Single 80mm BTS Twin pump setup Dry Sump Oil System designed for HEUI by Gray's Diesel Performance. Zero balance rotating assembly 16v electrical system/electric water pump/Gray's Diesel engine mounted fuel system with Fass 220/Colt Cams stage 2/Gray's Diesel piston bowl work and ring mods/Swamps tuning
  #3
Old 05-09-2017, 05:18 PM
bordo380's Avatar
Corporal
Member's Gallery
Default
Quote:
It is new.
I guess I didn't ask my question correctly.
I also meant is it worth it performance wise and is it going to kick my ass getting that DP around my firewall.
  #4
Old 05-09-2017, 06:28 PM
Bgdiesel's Avatar
Private
Member's Gallery
Default
Quote:
Originally Posted by bordo380 View Post
It is new.
Ok and if it is an excursion like the section we are in, Then no it won't be hardly all, it is very simple and no clearance issues whatsoever on excursions or superduty's with 4"DP, I like to remove the trans crossmember personally and put a spin jack under the trans, for ease of stock DP removal. But not necessary you could just saw saw the stock one out and slip the new 2 piece one easily just pay attention to clamp position
__________________
  #5
Old 05-09-2017, 06:29 PM
Bgdiesel's Avatar
Private
Member's Gallery
Hard at all*
__________________
  #6
Old 05-09-2017, 07:10 PM
bordo380's Avatar
Corporal
Member's Gallery
Default
Ok glad to hear it. Thanks so much.
And the performance gain? Is it worth my time?
I think our stock pipe is 3 or 3.5.
I am hoping some excursion guys chime in that's done it and let me know if the straight pipe is too loud as well.
  #7
Old 05-09-2017, 07:16 PM
Bgdiesel's Avatar
Private
Member's Gallery
Default
One of my vehicles is an Excursion that is 4" straight pipe with a 6" tip I like it, but it is moderately loud from the outside, not too bad inside. most of my customers are fine with a straight pipe, I put mufflers on let's say 5 fords out of what seems like a thousand kits we've installed
__________________
  #8
Old 05-09-2017, 07:43 PM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default
A 4" downpipe isn't some ungodly task on a super duty or Excursion. If this was an obs, then yes, you would have your work cut out for you. Cut the stock downpipe out with a sawzall, and you'll have it out in no time. It really doesn't take much time to remove the factory exhaust, iirc, you may have to cut the stock exhaust where it goes over the rear axle as well.
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2011 International Duraturd 4300 Mechanics truck
2001Tdi Jetta 5 speed
  #9
Old 05-09-2017, 09:24 PM
Jomax's Avatar
Jomax Jomax is offline
General
Member's Gallery
Default
You won't feel ANY performance gains. You'll see a minimal EGT drop. And in an excursion, you'll just make it louder inside.
I honestly think the stock exhaust is just fine for a 7.3 that is just chipped.
__________________
2017 F-250 KR CCSB 4x4- 4400 coils, rear block removal, 20x10 novakanes, nitto 420s, king shocks, OUO traction bars, 5in Alum Driveshaft.
  #10
Old 05-09-2017, 10:09 PM
bordo380's Avatar
Corporal
Member's Gallery
Default
Thank you Jomax that's what I thought as well and needed to hear it from a reputable source.
Thank you BG and Ghohouston as well. Sounds like I can handle the task but I won't be doing it unless I get real bored one day. Lol.
It will still happen but it might be when I upgrade the turbo. It's just not a priority.
Thanks again.
  #11
Old 05-09-2017, 10:27 PM
superpsd's Avatar
superpsd superpsd is offline
Major
Member's Gallery
Default
I think quite a few have built a 7.3 and Dyno'd over 600hp exhaling thru a 3" down pipe.
__________________
97-250 7.3 Eaton TVS Supercharged, S369sxe, R&D IDI performance T4 mount, my B350/200s, Honey Badger SR with My tunes, BMW M3 seats, Sky 5" RSK skyjacker drop pivot brackets, Sky shackles and hangers, Toyo M/T
1948 GMC Detroit 453T
1951 Mack A51T
1916 Federal 1 1/2T
  #12
Old 05-10-2017, 08:39 AM
79jasper's Avatar
79jasper 79jasper is offline
Major
Member's Gallery
Default
Quote:
I think diesel Dave did some testing.
I wanna say it was mid 500's all stock exhaust.
__________________
2003 F250 KR SCSB FX4
Depleted, studded, airdog (which isn't currently hooked up), fass regulated return, airaide, 4 inch straight pipe with mbrp muffler(so on to go), glowchit pyro, fuel, boost, and trans temp. (Of course don't work lol) Hercules terra track A/T2 315/70/17.
2013 Honda pilot Touring
http://badges.fuelly.com/images/sig-us/778639.png
http://badges.fuelly.com/images/sig-us/776628.png
  #13
Old 05-16-2017, 02:10 PM
bordo380's Avatar
Corporal
Member's Gallery
Default
Ok thanks for all the help. It's great to hear what everyone has.
So I need help for next mod.
Do I get the WW2 or upgrade the housing? I'm reading mixed reviews on the ATS.
  #14
Old 05-16-2017, 03:06 PM
Jomax's Avatar
General
Member's Gallery
Default
I'd personally do ported housing, Dennis at strictly diesel sells a good one. Best part is you don't have to remove the turbo. I loved mine.
__________________
  #15
Old 08-10-2017, 01:04 AM
C_Hallbert's Avatar
C_Hallbert C_Hallbert is offline
Private
Member's Gallery
Default
After getting an Edge Juice with Attitude installed on my Wife's 2000 Excursion 7.3L 4x4, I immediately discovered EGTs approaching 1300 Deg. F. when going up hills etc. So, I had a 4" SS Exhaust installed with a Low Resistance Muffler and (aside from the fact that it is now louder in the cab) the EGTs rarely reach 900 Deg. F. I believe that the factory exhaust added unnecessary obstruction to flow......resulting in higher EGTs. That's just my opinion based on casual observation. Just saying.
  #16
Old 08-10-2017, 04:46 AM
Back woods Back woods is offline
Corporal
Member's Gallery
Default
This is a 4" turbo back I built for my Wife's Excursion. It uses a 6.4 resonator and a 24" body muffler. There is zero drone in the cab and it has a nice tone to it. Still loud when you get on it but almost quiet as stock going down the highway.
https://www.youtube.com/watch?v=zOe3...mwvszvte3yn0ca
  #17
Old 08-10-2017, 06:24 AM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Quote:
The chit tuning you are running doesnt help your truck any either....
  #18
Old 08-10-2017, 09:26 PM
C_Hallbert's Avatar
Private
Member's Gallery
Default
I use my Chip Tuner basically as a monitor. Predominantly, it remains on Factory Street Level 1. I have used Level 2 when towing a fairly heavy 23 foot boat and trailer. I'm 70 y.o. and retired and I don't put the hammer down. The EGT and Turbo data has helped me troubleshoot a both exhaust and MAP Sensor problems.
  #19
Old 08-11-2017, 07:25 AM
dmd's Avatar
dmd dmd is offline
Lieutenant
Member's Gallery
Default
Pipes are not the problem, it is the muffler. Swap that out with a free flowing one and
you are 80% there... I noticed a very large performance difference when getting that
stock muffler out.
As one other mentioned, the X will be louder inside without a muffler.. i.e. drone.
__________________
2k, F350 SuperCruzer, 7.3L Diesel, Auto trans, 4x4, GH Tunes w/190/30s, S&B cold air intake, 4-inch turbo-back exhaust, Garrett 38r, Adrenaline HPOP, BTS Transmission w/6.0 cooler, Swamps IDM(broke, back to stock), in-tank and pre-pump mod, Heater valve mod, X-car sound panel mod
  #20
Old 08-11-2017, 06:36 PM
Jomax's Avatar
General
Member's Gallery
Default
stock muffler out.
That's one thing I didn't want on my parents X drone. I left the stock exhaust alone. Installed a DP tuner, one setting 80hp. No gauges. AIS intake and called it good. Unless you're towing all the time. I didn't care to do anything gauges wise.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
