6.4 Single Turbo
BrendanWhat
I'm pretty new to diesels. Just started looking more into single turbo set ups for the 6.4, may possibly make the switch myself. My primary use for my truck will be racing and general fun.
What are the advantages to switching over to a single turbo set up?
HS-MotorsportsZane
The biggest advantage's to switching over to a single are reliability, the loss of back pressure, and a horsepower gain with loss of egt. The factory vgt turbo runs a very high back pressure number vs manifold boost. Back pressure is very hard on engine parts, head gaskets, rocker arms etc.... We offer a complete kit here, with different size turbo options depending on application. Please feel free to contact us or any one of our authorized dealers. https://hs-motorsports.com/turbocharger/08-10-ford-6-4l-sxe-single-turbo-kit.html
Thanks.
Justinlw
H&S makes a great kit. Very clean, and thought out.
Zane listed most of the benefits, but left out that it sounds a lot better than the vgt. Plan on buying a muffler.
johnp115
Southern MD/Charlotte NC
Single turbo
Pros- reliable, cheaper than upgraded compounds, likes nitrous and high rpm, great for racing, sounds amazing
cons- large change in drivability/drving style, typically a good amount of tuning/refinment happens, performs alot better with additional engine/trans changes.
Enjoy...
http://powerstrokearmy.com/forums/showthread.php?t=51039
http://powerstrokearmy.com/forums/showthread.php?t=49876
http://powerstrokearmy.com/forums/showthread.php?t=48494
http://powerstrokearmy.com/forums/showthread.php?t=51878
http://powerstrokearmy.com/forums/showthread.php?t=52205
http://powerstrokearmy.com/forums/showthread.php?t=50436
http://powerstrokearmy.com/forums/showthread.php?t=49623
http://powerstrokearmy.com/forums/showthread.php?t=46210
Bryce_fow
What size would be good for 30s not trying to change subject I have bd turbos now but been thing of going to a single
zwalker
You wont be disappointed with the switch. The single turbo swap from HS really woke my truck up. Sounds awesome too :rockon:
Six_Sloww
Southeast MI
I was thinking 369sxe
I know the 69 is a really popular charger but the quicker spool up of the 66 will actually make the truck feel quicker stoplight to stoplight.
If you want all out power as in the truck will see a lot of track time the 69 is the better choice, if not the 66 is the better pick imo.
Bryce_fow
No where I can get a uppipe for a 6.0 manifold this week
Bryce, what do you do with your truck, what elevation are you at and what didn't you like about the 66mm?
A lot of sizing will depend on what you do with your truck and where you live. The 64mm is my personal favorite on these trucks and tends to work well for a lot of guys. Bigger is an option if you're ok with sacrificing a little bit of spool up for power, live at a lower elevation, don't tow often or very heavy, etc...
Something else to think about, that often gets overlooked, is that larger turbos won't make much more power, if any, over a smaller turbo on stock fuel (or insufficient fuel). The 64mm turbo is about as big as you can go on stock fuel before the increase in power is so marginal that it doesn't make sense to give up the drive-ability. I see plenty of guys running 369's or big S400's on stock fuel and just shake my head because they are giving up power because of the lack of fuel and drive-ability because of an oversized turbo. It would have been better to go with a smaller turbo that would have made similar power with the given amount of fuel but retain a lot of the drive-ability.
Bryce_fow
I am in Georgia
I tow some and kinda heavy
I didn't like that it fell on its face way to soon
I am about to go to a 369 sxe with 30 now to see how that feels right now I have the bd compounds on stock fuel
But I have a lot done to the truck
The engine has
New rods
New bearings
The block
Has new delipped fly cut and coated pistons
stage 1 cam (colt)
New water pump Oem
heads stage oringed
New Molly push rods
Stage 2 valve springs
New oil cooler oem
New high pressure fuel pump
Arp studs
No limit intake
Bd manifold
Rudys hd uppipes
New gaskets from top to bottom
Egr ******
*** gone
All new injectors and injector lines (ford) I have 30% nozzles and ported rails
Maryland crankcase vent
Maryland oil filter cap
New fuel cooler
Fass 150
Dppi coolant filter
H&s mini max hd 300 with custom tunes
Snow performance stage 3 mpg max
4in down pipe 5 in after to a 7 in tip
New bd turbos 73/59 combo
Fuel bowl ******
Mbrp cold side cac pipe
Mishimoto intercooler
Diesel site boots and clamps
Beans sump
All I can think of off top of my head
O and built trans
Six_Sloww
Southeast MI
Are you holding rail pressure? I would look there first if the truck feels as if it's falling on its face...
The stock hpfp doesn't typically maintain pressure with anything larger than stock nozzles on a max effort tune.
Bryce_fow
I had dual pumps with 30 but I blew a line and had to drive 12 hours the next day so I put it back stock
Bryce_fow
But I didn't have the 30s with the 366 it was stock fuel I have swapped up a lot just because I didn't like the turbo so I ran stock then bds with 30s now bds with stock
