Go Back   PowerStrokeArmy > Premium Vendors > One Up Offroad
Reply
Thread Tools Display Modes
  #1
Old 06-04-2017, 03:35 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default OUO adaptable length bolt on kit review
i just want to say that besides dereeting my 6.7, that this setup i ordered from jared are hands down the best thing i have ever done to a truck! any truck!! i wish I would have done this when i bought the truck off the lot... my shifts are solid and firm, no sloppy slinky feeling, my braking has even inproved a ton, and it took about 50% of the infamous 40-45mph hop away!!!
the bars are stout and made well, the cast parts are heavy but also weldable if not wanting to drill the frame.. i really thought of doing that as i jave a bum shoulder but looks and functions amazingly well..
only complaint i have are the instructions that came with it.. lots of parts and skipping around a lil made it confusing.. i knownitnis prolly easier to just throw the hole lot in together but there should be directions for each specific set of bars and bolt on kits. i think what took me the longest was reading and re reading and finding torque specs and the order that it was needed to be done and the step by step on what way to put it together.. once you find each part then its ok as long as you dont put them down and let the wond blow them around.. lol.. did that once.. maybe a list of what is needed for install too.. i didnt know i needed a 5/8 hole in the one side of the bar till i was to that point(yes i should have read all instructions first but i was impatient)and i wouldnt have had that bit if i wasnt doing this at work with the mechanics rig that i have stocked with most everything i needed except a nag drill.. lol
drilling sucks.. as i just drilled pilot holes big enough to start a reamer bit and slowly worked them open to just shynof 3/8s and then finished/squared them off with a step bit.. it took so luch less effort to do it that way and not doing a pilot hole then jumping to a 3/8s bit or inwould have needed to stop a quarter of the way through and paid someone to do it for me due to my shoulder.. but anyway, a mag drill or lots of good drill bits would be needed if you didnt do it my way.. i used two 1/4 drill bits(now junk) one 1/2 inch reamer bit(still like new) and a step bit(still ok but not newish anymore) to drill the holes in the frame.. the directions say a minimum of 8 inches of overlap in the tubes is required. so as most know, the longer the bars are, the better the ride is and betternfor towing.. so i marked the inner bars at 8 inches from the end. lined that mark up with the pilot holes on the outer bar so that puts them at close to 9 inches of overlap then set the bolt on frame mount on the end without the bushing and used that as my guide for the distance of mounting on the frame. it worked out to be 3 and 3/4 inces from the body mount.. after it is put together with the bushings installed and tight, that puts about 10 inches of overlap in the tube so i should be good to go there.. it is tedious job but all in all its more time consuming then it is hard to install.. the small bolts for the frame being small only required 18ft lbs which seems super low and they still spun on the washers when not backed up with a wrench but hey, what do i know.. i ended up haveing to go back through and torque each nut on the fram mounts 3 times though cuz it kept tighting more as it went so i kust have got a couple holes not lined up propper but to get them all to 18ish ftlbs of torque and even, that is what i had to do on each side.. so with that said!
absolutely love them!!!
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #2
Old 06-04-2017, 03:44 PM
General
Member's Gallery
Default
oh, and my ride was not effected one bit
__________________
  #3
Old 06-04-2017, 04:28 PM
Zmann's Avatar
Zmann Zmann is offline
Colonel
Member's Gallery
Default
looks good
their directions show a mild steel frame bracket not cast
I wonder why the changed?
pdf http://www.oneupoffroad.com/images/O...action_Bar.pdf
__________________
DTR RON Huxell's Memorial donation page please donate
https://www.gofundme.com/2464axqr
  #4
Old 06-04-2017, 04:35 PM
jimdawg185's Avatar
jimdawg185 jimdawg185 is offline
Major
Member's Gallery
Default
Dereeted? Ruh ro! Maybe re ereeted at ****ty wok!
__________________
The LE Promise:
No other brand of petroleum lubricating
oil whatsoever, regardless of price, will
be found superior in condition to
Lubrication Engineers products at the
end of any given period of use.
CLS Certified STLE
MLT-1, MLT-2, MLA-1, MLA-2 Certified ICML
ISO 9001
J.KUKULSKI@le-inc.com
616-460-9949
  #5
Old 06-04-2017, 04:41 PM
jimdawg185's Avatar
Major
Member's Gallery
Default
__________________
The LE Promise:
CLS Certified STLE
ISO 9001
616-460-9949
  #6
Old 06-04-2017, 06:31 PM
Jomax's Avatar
Jomax Jomax is offline
General
Member's Gallery
Default
Quote:
Originally Posted by Zmann View Post
looks good
Cleaner design. Looks better too!
__________________
2017 F-250 KR CCSB 4x4- 4400 coils, rear block removal, 20x10 novakanes, nitto 420s, king shocks, OUO traction bars, 5in Alum Driveshaft.
  #7
Old 06-05-2017, 02:07 AM
Jomax's Avatar
General
Member's Gallery
Default
So, after driving it for a day, still happy?
__________________
  #8
Old 06-05-2017, 06:51 AM
General
Member's Gallery
Default
looks good
updated the brackets. new style
Quote:
yes, absolutely amazing!
Quote:
lol.. dipchit!
__________________
  #9
Old 06-05-2017, 08:55 AM
C2tuck's Avatar
C2tuck C2tuck is offline
Lieutenant
Member's Gallery
Default
What did those set you back if you don't mind me asking? I know PMF's w/blocks are around $1500.
__________________
2015 CCSB F250 XLT FX4...American Force, Toyo AT 2s, TSD tunes, EZ Lynk, 4 Flo Pro, Fox 2.0s.
  #10
Old 06-05-2017, 10:29 AM
General
Member's Gallery
Default
Quote:
couple hundy less then that.. no lift blocks. stock hight with bottom bolt on plate and upgraded 3/4 u bolts.
__________________
  #11
Old 06-05-2017, 12:40 PM
Zmann's Avatar
Colonel
Member's Gallery
Default
updated bracket may "look" better but welding mild steel to the frame is a lot stronger IMO
seems like a lot of effort to come up with a cast design?
i guess the bracket assembly was tedious?
__________________
  #12
Old 06-05-2017, 12:57 PM
General
Member's Gallery
Default
who knows man.. maybe it was a production call... might produce more that way instead of welding them together... also, it says its a weldable cast alloy so it must not be a true pig iron cast steel..
__________________
  #13
General
Member's Gallery
Default
no idea why that wuoted twice
__________________
  #14
Old 06-05-2017, 03:59 PM
Zmann's Avatar
Colonel
Member's Gallery
Default
I am sure your correct
that must be it it is low alloy cast I have not welded that to mild
__________________
  #15
Old 06-05-2017, 05:05 PM
nighthawk285's Avatar
nighthawk285 nighthawk285 is offline
Sergeant
Member's Gallery
Default
looks good
I had the same question when I did mine. IIRC, Dave told me it was more cost and time effective to have the pieces cast than to bend and assemble the brackets. Batch casting was a better option for them, and it was stronger at the bushing than the mild steel. Their warranty plan is "if you break it, we'll build you something stronger"
__________________
Nick
2005 KR F350 6.0L with some go-fast goodies and look-good-doing-it goodies
  #16
Old 06-05-2017, 06:09 PM
General
Member's Gallery
Default
Quote:
i like that warranty plan
__________________
  #17
Old 06-05-2017, 07:37 PM
Zmann's Avatar
Colonel
Member's Gallery
Default
thanks for the inside info !
__________________
  #18
Old 06-06-2017, 08:32 AM
General
Member's Gallery
Default
well, im sure the cast parts are twice as heavy so im sure that makes it a lil stronger too...
__________________
  #19
Old 06-06-2017, 08:42 AM
Breaking Habits's Avatar
Breaking Habits Breaking Habits is offline
General
Member's Gallery
Default
Quote:
The 101041 & 101044 cast axle bar mounts packaged are only 1lb heavier than the predecessor welded 101041 & 101042(superceded), but are definitely stronger.
The 101020 Beside Frame Pivot Mounts came out about 2 lbs heavier total cast boxed - They are much stronger, and quicker to produce in high quantity for us, so we are much happier. This allows our welders to focus on building more bars, ala's, and traction blocks because we never run out of pivot mounts (we do batches of 500 at a time)
Also Jake, Dave asked me to respond to you about the instructions as well since he doesn't really post on forums
Per Dave -
We are sorry about the torque spec in the instructions.
The 3/8-24 Bolts should be torqued to 33 Ft Lbs when running thru the frame with nut on them instead of the 18 ftlbs.
We have fixed this typo, thanks for helping us with the problem.
If you used Loctite remember to warm up the bolt to release the lock tight to get a true torque.
We update the instructions every time we print them and try to incorporate feedback to make the install more clear.
-Dave Hoppert, One Up Offroad
-Jared
__________________
Jared Rice
___________________________________
One Up Offroad - Sales Director
www.ouostore.com - Now Live, Check It Out!
Orders@oneupoffroad.com
Mobile/Text - 503-780-3818
Midwest Diesel & Auto - Sales Manager
www.midwestdieselauto.com
Jared@midwestdieselauto.com
Mobile/Text - 217-691-3404
  #20
Old 06-06-2017, 08:45 AM
General
Member's Gallery
Default
Per Dave -
-Jared
right on!.. now that makes way more sense!!
should the nuts be taken off and more red lock tight be used if already set up and re-torqued to the 33ftlbs? i would assume so im case it got to hot and burnt it out..
__________________
  #21
Old 06-06-2017, 08:48 AM
General
Member's Gallery
Default
As far as I'm concerned, I don't see anything negative that could become of it
__________________
Jared Rice
  #22
Old 06-06-2017, 08:56 AM
ingrahams's Avatar
ingrahams ingrahams is offline
Lieutenant
Member's Gallery
Default
Per Dave -
-Jared
Just installed the same bars on my 11' ECLB, huge difference and great quality. I'll have to re-torque as well once I'm back stateside, I remember thinking that 18 FT.Lbs sounded a bit light but figured it had to be right.
__________________
08 F350 FX4 D&J Deckplate Cummins Conversion
2017 F-350 CCSB Lariat Ultimate
  #23
Old 06-06-2017, 09:18 AM
General
Member's Gallery
Default
ok. thank you sir! badass product btw, pass it to the rest of the ouo boys please... which im sure they know that already.. lol
now i just need some midwest diesel and auto parts on my truck.. lol
__________________
  #24
Old 06-06-2017, 09:27 AM
Zmann's Avatar
Colonel
Member's Gallery
Default
good info on the cast mounts thanks
the online PDF looks like it still needs updated
__________________
  #25
Old 06-06-2017, 09:39 AM
Sergeant
Member's Gallery
Default
Amen to that. I've used and abused mine with towing, sled pulling, and hauling hay trailers over some nasty uneven terrain, some racing, and they've taken everything I've given them and asked for more. Awesome product
__________________
Nick
  #26
Old 06-06-2017, 05:25 PM
General
Member's Gallery
Default
how much overlap did you end up with?
__________________
  #27
Old 06-07-2017, 08:18 AM
Sergeant
Member's Gallery
Default
I'd have to measure again...it's been long enough I don't remember off the top of my head.
__________________
Nick
  #28
Old 06-07-2017, 10:08 AM
Jomax's Avatar
General
Member's Gallery
Default
When I did my bars 18ft lb didn't feel like enough. I just did good N tight torque spec with red loctite lol.
__________________
  #29
Old 06-07-2017, 02:19 PM
gnxtc2's Avatar
gnxtc2 gnxtc2 is offline
Major
Member's Gallery
Default
I swapped out the Grade 5 bolt for a Grade 8 yellow chromate bolt to match the rest. I like the stainless ARP bolt used as the through bolt.
Now you got me thinking....I dont know if I have the 8" overlap in the bars....
I ran across this issue on the passenger side. I drilled the bracket to secure the Christmas tree strap.
Billy T.
gnxtc2@aol.com
__________________
'97 Black F250HD SC, 3.55s, Punisher Trans, PI Converter, Dana 60 RSK w/ V & C SD springs, PIS 175/80s, T500, Cale's tunes, 910s, Smith Bros, ARPs, Fluidampr, IC, E-Fuel, 3" Plenums, CJC Traction blocks, HFHV IDM, T4/BASB, Horton, 268K
- 2016 F350 DRW Ultimate (stock for now )
- 1987 Buick Grand National (Staged)
- 2004 Mercury Marauder
- 1993 Geo Prizm (beater)
  #30
Old 06-07-2017, 02:31 PM
General
Member's Gallery
Default
Billy T.
gnxtc2@aol.com
oh boy.. is yours a cclb?
__________________
  #31
Old 06-07-2017, 02:49 PM
gnxtc2's Avatar
Major
Member's Gallery
Default
Yep...2016 F350 CCLB DRW with a Titan 65 gallon tank.
Billy T.
gnxtc2@aol.com
__________________
  #32
Old 06-07-2017, 06:03 PM
General
Member's Gallery
Default
Billy T.
gnxtc2@aol.com
oh chit!! so if the frame length and body mounts are the same and i figure i have 10 inches of overlap, and im 3 3/4 inches from that body mount, you are probably under 6 inches of overlap since you are kinda tucked under the mount some... hmmmm
__________________
  #33
Old 06-08-2017, 05:39 AM
General
Member's Gallery
Default
gonna go retorque the frame mounts and new u bolts now..
__________________
  #34
Old 06-08-2017, 07:12 AM
gnxtc2's Avatar
Major
Member's Gallery
Default
Go do something ^^^^^ ^^^^^
Billy T.
gnxtc2@aol.com
__________________
  #35
Old 06-08-2017, 07:22 AM
jimdawg185's Avatar
Major
Member's Gallery
Default
Billy T.
gnxtc2@aol.com
Bwauahahaha!!!!
__________________
The LE Promise:
CLS Certified STLE
ISO 9001
616-460-9949
  #36
Old 06-08-2017, 08:20 AM
General
Member's Gallery
Default
Billy T.
gnxtc2@aol.com
hey, its a good thing i did, one of the nuts on the bottom plate for the u bolt was only at 160 ish and all where below 180 for the 3/4 ubolts..
__________________
  #37
Old 06-08-2017, 08:32 AM
gnxtc2's Avatar
Major
Member's Gallery
Default
Well, probably you were thinking about making a post on PSA instead of properly tightening the u-bolt(s).
I doubt the rear was going anywhere with 160ish lb ft on a 3/4 bolt.
Billy T.
gnxtc2@aol.com
__________________
  #38
Old 06-08-2017, 01:43 PM
General
Member's Gallery
Default
Billy T.
gnxtc2@aol.com
lol.. nope.. i torqued them each 3 times during install.. just like i did with every bolt.. lol
__________________
  #39
Old 06-08-2017, 02:27 PM
Jomax's Avatar
General
Member's Gallery
Default
Good ol U bolts. They always stretch.
__________________
  #40
Old 06-08-2017, 02:29 PM
General
Member's Gallery
Default
its weird how far off the one was too.. i have done many and only be a few lbs off but not 20ish
__________________
  #41
Old 06-08-2017, 02:45 PM
Jomax's Avatar
General
Member's Gallery
Default
Maybe some odd reason it didn't torque right the first time.
__________________
  #42
Old 06-08-2017, 02:48 PM
General
Member's Gallery
Default
digital torque wrench said so.. but still odd
__________________
  #43
Old 06-08-2017, 02:58 PM
gnxtc2's Avatar
Major
Member's Gallery
Default
Battery in digital torque going dead or a Chinese one
Billy T.
gnxtc2@aol.com
__________________
  #44
Old 06-08-2017, 05:35 PM
Jomax's Avatar
General
Member's Gallery
Default
Billy T.
gnxtc2@aol.com
His arm was sore..
__________________
  #45
Old 06-08-2017, 06:17 PM
General
Member's Gallery
Default
Billy T.
gnxtc2@aol.com
i know you guys are just giving me crap but its a napa/Carlyle and i have no idea where its made.. prolly china.. just picked it up a couple weeks ago for the company I work for.. it was like 350 bucks.. fresh batteries too..
__________________
  #46
General
Member's Gallery
Default
His arm was sore..
you have no idea!
__________________
  #47
Old 06-15-2017, 11:51 AM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Just did these to my reg cab....big thanks to Midwest Diesel & Auto
Awesome packaging, beautiful finish on the product, excellent install instructions, outstanding design and quality.
Smoothed out the shifts, stopped the terrible recoil action when coming to a complete stop or taking off aggressively. Minimized the 45mph hop but notice a slightly sharper rebound on bumps-probably because of the short wheelbase.
All in all, should have done it sooner.
  #48
Old 06-15-2017, 11:58 AM
Sergeant
Member's Gallery
Default
Quote:
That was my thought too, and for now, will be one of the first mods on any other truck I own.
__________________
Nick
  #49
Old 06-15-2017, 12:23 PM
General
Member's Gallery
Default
NICE!!! makes it a different truck doesn't it?
__________________
  #50
Old 06-15-2017, 12:30 PM
sootie's Avatar
General
Member's Gallery
Default
Not my first set of traction bars lol
Mainly commenting on OUO's business model-but yes they help the truck
  #51
Old 06-15-2017, 12:42 PM
General
Member's Gallery
Default
well not mine either but the others i have ran and been around aren't as good as these.
my dually needs a set next.. the homemade bars on that do what they need to do but these are far better.. lol
__________________
  #52
Old 06-15-2017, 02:15 PM
Layson's Avatar
Layson Layson is offline
Major
Member's Gallery
Default
I just helped a friend of mine take off his existing traction bars that came with his truck and we installed a set of OUO ones. He couldn't believe how much better the ride quality is with the new bars. It is so hard to convey to someone how nice and well put together OUO's kit is. I have had lots of truck parts over the years and nothing compares to this stuff....
When I ordered my first parts from them, I bitched a little about the cost. But then when I opened them up, it really just blew me away. I had never seen anything packaged as well and how nice the parts are and how great the kit is. It is just hard to convey to someone that you are not going to regret spending this money. When you have everything unboxed and spread out you can really appreciate how nice the kit is. There is absolutely nothing out there that compares to this.
My friend is about as cheap as it gets. Now he has OUO Adjustable Link Arms, OUO Adjustable Leveling Kit, OUO body lift, and OUO traction bars..... He can make a buffalo squeak and this is what is on his truck now...
  #53
Old 06-15-2017, 07:51 PM
Jomax's Avatar
General
Member's Gallery
Default
You guys should've saved the money and got pro comp bars.
__________________
  #54
Old 06-15-2017, 08:39 PM
sootie's Avatar
General
Member's Gallery
Default
You shoulda saved money and bought a Dodge
  #55
Old 06-15-2017, 08:58 PM
Jomax's Avatar
General
Member's Gallery
Default
I cry every night for not saving the coin and getting a Ram.
__________________
  #56
Old 06-15-2017, 08:59 PM
8WR_ZJ 8WR_ZJ is offline
Lieutenant
Member's Gallery
Default
STFU & GTFO
__________________
2015 F-350 CCLB 4WD, S&B, GH SOTF, 4" FLOPRO, FUN SWITCH.
  #57
Old 06-15-2017, 09:00 PM
Jomax's Avatar
General
Member's Gallery
Default
Quote:
Originally Posted by 8WR_ZJ View Post
STFU & GTFO
We know you want one too..
__________________
  #58
Old 06-15-2017, 09:04 PM
Lieutenant
Member's Gallery
Default
Ewww might catch something bleach can't kill.
__________________
  #59
Old 06-16-2017, 06:14 AM
General
Member's Gallery
Default
so mean you are.. lol
__________________
  #60
Old 06-16-2017, 07:18 AM
gnxtc2's Avatar
Major
Member's Gallery
Default
The reason he bought the Ram is so he can drive around with the mirrors flipped up.
Billy T.
gnxtc2@aol.com
__________________
  #61
Old 06-16-2017, 07:24 AM
Black AOD's Avatar
Black AOD Black AOD is offline
Colonel
Member's Gallery
Default
Billy T.
gnxtc2@aol.com
__________________
08' F350 6.4L EC/LB FX4 - long gone.
2017 F350 CCLB 6.7 SRW Platinum - No Limit, Warren Diesel, Exergy, FASS Fuel Systems, Taterbilt Turbos, OUO, KING Racing, PMF
  #62
Old 06-16-2017, 08:11 AM
Lieutenant
Member's Gallery
Default
Lol pull that ghost trailer all over town...
__________________
  #63
Old 06-16-2017, 08:21 AM
sootie's Avatar
General
Member's Gallery
Default
Billy T.
gnxtc2@aol.com
just measure the overall length of the bar right now, if it is 82" or under, you are ok.
  #64
Old 06-16-2017, 09:46 PM
geolp geolp is offline
Private
Member's Gallery
Default
Cutting the overlap down to the minimum 8" might be a good idea for future installers, mine rattled like crazy until I shortened the inside section of the bars. A ton of chatter bumps on these dirt roads doesn't help
  #65
Old 06-17-2017, 01:05 AM
gnxtc2's Avatar
Major
Member's Gallery
Default
Will do
Quote:
You could've wrapped the inner tube with tape or used some RTV to dampen the rattle.
Billy T.
gnxtc2@aol.com
__________________
  #66
Old 06-17-2017, 06:20 AM
General
Member's Gallery
Default
Will do
Billy T.
gnxtc2@aol.com
i dont think mine would have went together with a single wrap of tape. it was snug already
__________________
  #67
Old 06-17-2017, 06:32 AM
gnxtc2's Avatar
Major
Member's Gallery
Default
There was a batch of bars where the tolerances were off causing the bars to rattle.
Billy T.
gnxtc2@aol.com
__________________
  #68
Old 06-17-2017, 10:15 AM
General
Member's Gallery
Default
Billy T.
gnxtc2@aol.com
oh no kidden..
__________________
  #69
Old 06-17-2017, 02:34 PM
gnxtc2's Avatar
Major
Member's Gallery
Default
From the rear bolt to the washer/cup for the bushing on front mount....88 1/2".
Billy T.
gnxtc2@aol.com
__________________
  #70
Old 06-17-2017, 02:38 PM
sootie's Avatar
General
Member's Gallery
Default
Billy T.
gnxtc2@aol.com
You're a little past recommended overlap I would say....probably not totally detrimental if you aren't sled pulling etc but I'm not sure
  #71
Old 06-17-2017, 04:42 PM
gnxtc2's Avatar
Major
Member's Gallery
Default
I do tow heavy.
Billy T.
gnxtc2@aol.com
__________________
  #72
Old 06-17-2017, 07:33 PM
C2tuck's Avatar
Lieutenant
Member's Gallery
Default
So would PMF's be better then since they aren't a 2 piece??
__________________
  #73
Old 06-17-2017, 11:37 PM
General
Member's Gallery
Default
not necessarily.. that is the entire point of "adaptable" length.. can fit many configurations. just needs a recommended 8 inches or more of overlap to be properly installed.. ouo makes a solid one piece bar too..
__________________
  #74
Old 06-18-2017, 09:39 PM
C2tuck's Avatar
Lieutenant
Member's Gallery
Default
Ok. Gotcha
__________________
  #75
Old 08-06-2017, 12:26 PM
General
Member's Gallery
Default
thought i would see just how well these bars articulate.. lol
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
