AirFishAutomotive
2008 Ford F-250
Rust free (one of the cleanest frames you will ever see guranteed) no body rust at all
6.4 powerstroke turbo diesel (built engine)
Automatic
4x4
Fx4 Lariat black leather
Carbon fiber dipped interior
138k on body only (not engine or trans)
Extended cab long bed
Power seats/ mirrors w fold / windows /cruise control etc
Blue/grey two tone
Xm radio w kicker door speakers /pioneer headunit
New batteries
New alternator
New starter
Title in hand
Edge cts (monitoring purposes)
Sct x4 (tuning purposes)
Truck has normal dings and scratches for the age, one small dent on top of each side of bed (both can be pulled hasn't bothered me so wasn't concerned) has scratches on front bumper in center, can be seen if looked closely in pics
Truck has never been raced so no idea on track times, with good weather truck should dyno 750 - 820 hp/ 1100 - tq easily
Motor - fully built 800 miles on it
Powdercoated hammer grey valve covers /intake manifold/rocker boxes/compressor housing
Elite diesel cnc ported heads w oversized valves & o ringed
Bored .30 over block/magnafluxed/decked/line honed
Afa ported intake manifold
Arp studs
Mid West Heavy duty pistons ceramic coated & flycut
Stage 3 rcd billet cam
Cut & polished crank
R&R billet connecting rods
Motorcraft low pressure oil pump
Motorcraft lpop cover
Motorcraft oil cooler
Motorcraft bearings
Motorcraft waterpump
New rocker arms
Heavy duty lifters
Rcd aluminum oil pan
**Bottom end was balanced before assembled **
Turbo set up-
Custom single turbo set up w 369sxe (turbo has 2,000 miles)
No limit cold air intake
Mpd ccv reroute/ oil fill
4 inch Afe dump exhaust w Mbrp tip
Bd high flow exhaust manifolds & up pipes -new
Turbosmart 45mm wastegate w manual controller & external exhaust dump-new
Fuel system-
Air dog 165 w sump
Beech diesel performance fuel bowl ****** w aeromotive regulator
Diesel dr dual fueler kit w new motorcraft pump
Motorcraft valley pump -new
Motorcraft injectors - new
Rcd 100% nozzles - new
Trans -
Rebuilt trans (20k miles) stage 1 clutches
Triple disc torque converter
Elite billet flex plate
Cooling-
Mishimoto v2 aluminum radiator
Mishimoto intercooler
Mishimoto intercooler boots
Vibrant clamps
Mishimoto electric fans
Cosmetics-
Hid headlights and fog lights
Paint match headlights
Paint match emblems
Tinted tail lights
Tinted cab lights
Rear block removed
5400LB front springs (lowers truck approx 2 inches)
Wheels/tires/etc
Ouo traction bars -new
Ouo front diff cover -new
Ouo rear diff cover -new
22x10 American force nightmares w face plates nitto grappler g2, 3 tires pretty new the other 1 will need to be replaced soon
price is pretty firm, but open to reasonable offers, nothing wrong with it but have done what I wanted to do with it and now time to move on. Still being daily driven so miles will go up slightly. no financing, no trades.
eric @ idp can vouch the truck is pretty clean
Call 302-875-2818
Text 302-752-7309
Automatic
4x4
Blue/grey two tone
New batteries
New alternator
New starter
Title in hand
Arp studs
Motorcraft bearings
New rocker arms
Heavy duty lifters
Turbo set up-
Fuel system-
Air dog 165 w sump
Trans -
Cooling-
Vibrant clamps
Cosmetics-
Paint match emblems
Tinted tail lights
Tinted cab lights
Rear block removed
Wheels/tires/etc
Call 302-875-2818
Text 302-752-7309
