Egts
04cr450
harford county, maryland
Just a easy question. What are your guys cruising egts say at 75 mph. Question is more towards the trucks that run a race file.
Mine is roughly 700 degrees plus or minus 30 degrees. Tyrant race file, just wondering if these are the temps others are seeing?
Getting on it hard ill go to 1400 or so. Fully eleted etc etc.
Whats makes me smh is- towed my utility trailer to the scrap yard and weighed in at 9k or so lbs and egts were just about the same lol...
Hence the question, just wondering if these egts are nornal for a 6.7.
8WR_ZJ
At 75 mine are 640 empty. Towing the 5th wheel at 65 im at 800. At 70 900.
Jomax
Arizona
My egts are about the same. I cruise at 80 with egts between 650-750 unloaded. At WOT I'll hit the same EGTs at you. They'll actually go higher if you keep the throttle mashed longer..
8WR_ZJ
28ft 5th wheel. 7700lbs empty. 72mph. 850egt. 2070rpm. 34% engine load. 5th gear 3.31 rear end. On 34x11.5 tires
Sent from my SM-G935W8 using Tapatalk
What tires are you running? And what is the pin weight on that 5th wheel.
Jomax
Arizona
I like the tune alot. It will stay on the truck for sure. The trans shifting is really good. Power is stronger tha n gh which is a plus. Smokey though
The last part is what I was waiting for. It was a smokey pig for me with the tyran t race tune. Didn't care for it.
CATDiezel
Mine are practically identical. Except towing 5th wheel at 70mph my egts are 875ish... not far off.
jimmystoys
Surrey, BC
Mines about 750-800 empty, 1000-1100 level ground pulling 8500# trailer 70ish mph. Trucks weighing in at about 9000# now lol.
