Go Back   PowerStrokeArmy > Power Strokes > 7.3 Tech
Reply
Thread Tools Display Modes
  #1
Old 10-22-2011, 09:51 PM
4cstr's Avatar
4cstr 4cstr is offline
Sergeant
Member's Gallery
Default Fuel Bowl Heater
I finally had the fuel bowl heater element break on me today. Boy...when it shorted out...the truck came to an immediate halt.
Anyway...can the element be re-soldered together...or can you just buy a new element? If so...anybody have the part number?
Since I live up here in SoDak...I would kinda like to replace it. Right now I removed it just so I could get the truck back up and running...but like I mentioned...I would like to put it back.
Thanks
__________________
~Dave~
2012 F350 CC KR dually, stock, bone stock.
early 99 F250, some stuff done *traded*
  #2
Old 10-23-2011, 12:56 AM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
Lieutenant
Member's Gallery
Default
Depending on where it burned out, you could maybe solder the wires back on, I know Bob(guzzle) at dieselOrings.com has them, http://www.dieselorings.com/index.ph...cat=18&group=6
__________________
Alan
2000 F-350 SRW CC, Short Bed 7.3PSD BTS Trans, Van Turbo, 6/6 wheel, Tyrant Tuning, 290,000 miles and counting
  #3
Old 10-23-2011, 09:27 AM
Tom S's Avatar
Tom S Tom S is offline
Mod Squad
Member's Gallery
Default
Dorman now makes those as well. I am thinking your early 99 might have thin wire type lke the OBS trucks do. I converted mine to the thick element kind like the later trucks do when I had a fuel bowl.
__________________
1996 F250 Powerstroke 4X4 AUTO
DP-Tuner F-6 chip live tuned, BTS Transmission, Garrett 38R Turbo, Swamps Injectors 150cc, electric fuel,
Banks Intercooler, Reflexxions Cowl Hood, 17 degree HPOP, 4" Stainless Magnaflow &
Aeroturbine exhaust, Aeroforce OBD Scan Gauge, Truxedo tonneau cover
Dana 60 Precision Metal Fab RSK and SD Springs
  #4
Old 10-23-2011, 09:44 AM
Arisley's Avatar
Arisley Arisley is offline
Mod Squad
Member's Gallery
Default
Guzzle has the thick one (looks like an oven heater element), fits perfect. You will not notice the difference at all with it out though.
__________________
E99 ECLB Dually, 2010 bed, 2005 headlights, smoked clearance lights, 2001 cup holder.
365,XXX miles. Pure stock, sorta.
SDRCM #478
PSA Conspirator # 22
  #5
Old 10-23-2011, 02:27 PM
Big Bore's Avatar
Big Bore Big Bore is offline
Major
Member's Gallery
Default
You don't need it, unplug the wire and replace fuse.
__________________
E99 with some junk and tuned by C-Fro. Building some more junk to put in it.
11B
Quote:
Originally Posted by Powerstroked162 View Post
... I don't want to be left assuming you're a dipchit. I want you to prove it to me...
  #6
Old 10-24-2011, 01:41 AM
4cstr's Avatar
Sergeant
Member's Gallery
Default
Quote:
Yep...just had a thin bare wire making about 3/4 circle on the filter plate. Its amazing how Ford wants $100+ for that stinking little thing.
__________________
~Dave~
  #7
Old 10-24-2011, 07:05 AM
Tom S's Avatar
Mod Squad
Member's Gallery
Default
http://www.dormanguide.com/fuel-heating-elements.html
http://www.dormanproducts.com/p-28150-904-210.aspx
  #8
Old 10-24-2011, 03:36 PM
4cstr's Avatar
Sergeant
Member's Gallery
Default
Thanks Tom. Surfed a local autoparts place online, found the Dorman one...got another $10 off for ordering it online...and went out the door for $36 and change. Much thicker than the little wire that broke.
__________________
~Dave~
  #9
Old 10-30-2011, 08:39 AM
JLDickmon's Avatar
JLDickmon JLDickmon is offline
Major
Member's Gallery
Default
the thin wire one is the Ford one.
the thick wire is the International style and is also the aftermarket
__________________
'99 7.3
  #10
Old 10-30-2011, 09:44 AM
Tom S's Avatar
Mod Squad
Member's Gallery
Default
I think the thin wire is a OBS and 99 part and thick was the later trucks.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
