Go Back   PowerStrokeArmy > Power Strokes > 94-97 Tech
Reply
Thread Tools Display Modes
  #1
Old 10-08-2017, 06:25 PM
Peroni's Avatar
Peroni Peroni is offline
Sergeant
Member's Gallery
Default Current Motorcraft Steering Linkage Part Numbers
Helping someone with a 96 SRW 4x4 F350 that needs all new steering linkage, after 310K it is seriously worn out. She wants to replace it all with Ford parts and I have MEOE-133, MEOE-96, MDOE-13 and MEOE-51 for the links, ends and adjusters.
I think those are all the updated Motorcraft numbers? The only one I'm having trouble finding is MEOE-96, it is out of stock at several places and between $175 and $220 at the few places that have them. I have found MDS1071 as a cross over, it is cheaper at about $95. Is this the right part or a lighter duty version?
__________________
97 Green F-350 XLT 7.3L PSD 4x4 CC LB BTS E40D Manual Hubs 4.10 36000 miles when purchased 4/1/06. Mods - ISSPRO Performax gauges, Tymar intake, Tymar 3x4 DP to 4" ss exhaust, custom rear disc brakes, hydroboost conversion w/ 6.0 p/s pump, electric fuel, MANN CCV filter,LPF9750 oil bypass, 6.0 fan, tru-cool 4739, Swamps 200/30 injectors, Adrenaline HPOP, BASB turbo, Fluidampr, Spearco 6.0 cac.
05 Silver Mk4 Jetta GLS TDI
  #2
Old 10-09-2017, 06:37 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
after all the crap i have been going through with the oem replacement steering components on my 6.7, id go with moog it xrf or the like. something with grease fittings cuz the factory stuff anymore sucks.. but that may be different for the older trucks. also, if it is substantially cheaper then it is more than likely a motorcraft value line part. as in a cheaper version..
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #3
Old 10-09-2017, 05:06 PM
Peroni's Avatar
Sergeant
Member's Gallery
Default
I have XRF on my own truck and don't like them. At 70K they are getting loose and had bad tie rod roll from day 1 which even my worn out rusty stock parts never had. MOOG is mostly outsourced from Asia these days and quality is hit or miss so I stay away. Customer wants Motorcraft, or failing that perhaps Spicer. I'll check into that other part being part of a value line.
__________________
  #4
Old 10-09-2017, 05:31 PM
Garbage_Mechanic Garbage_Mechanic is offline
Sergeant
Member's Gallery
Default
Agreed on the XRF, I fell in with the crowd and ordered, the tie rod roll was an issue. I made a pair of "cups" and a urethane washer and so far no roll issues. Way easier to control on the Moog on my other F350. Not sure you can trust Motorcraft either though.
__________________
Mine since 2001: 91 F250 RC 4x4 5spd 7.3 IDI 4.10LS Banks Turbo Electric Fuel 92 D60 w 97 brakes and Powerlock Hydro boost Flatbed
Hers since 7/03: 96 F250 CCSB 7.3 PSD 4x4 5spd 3.55 LS D60 AMP Powersteps Currently ungoing 22 yr Rehab Incl Swamps Long Block, S364.5, IC, RSK etc.
2 Harleys 7 Horses about 50 cows +-
Diesel Mechanic 40 yrs
Now 120 truck Fleet, 80 plus CNG powered
  #5
Old 10-10-2017, 10:43 AM
79jasper's Avatar
79jasper 79jasper is offline
Colonel
Member's Gallery
Default
Isn't OEM Dana/Spicer?
But motorcraft is what?
Sent from my SM-G892A using Tapatalk
__________________
2003 F250 KR SCSB FX4
Depleted, studded, airdog (which isn't currently hooked up), fass regulated return, airaide, 4 inch straight pipe with mbrp muffler(so on to go), glowchit pyro, fuel, boost, and trans temp. (Of course don't work lol) Hercules terra track A/T2 315/70/17.
2013 Honda pilot Touring
http://badges.fuelly.com/images/sig-us/778639.png
http://badges.fuelly.com/images/sig-us/776628.png
  #6
Old 10-10-2017, 10:57 AM
Got4wd Got4wd is offline
Sergeant
Member's Gallery
Default
Funny you bring this up. I have all the pieces except the meoe 96. The 1071 looks the same to me and I canít figure out whatís different. I do have a spacer that was made to prevent tie rod roll and will only work with oem boots. I have never seen spicer part numbers for any of the ford Dana 60.
  #7
Old 10-10-2017, 11:29 AM
Sergeant
Member's Gallery
Default
My point exactly, not sure Motorcraft is as trustable as it once was.
XRF not as good in my experience as the hype.
So Moog isn't what it was, and TRW became Dana / Spicer?
__________________
  #8
Old 10-10-2017, 11:41 AM
79jasper's Avatar
Colonel
Member's Gallery
Default
I've heard of some called mevotech terrain plus. (Or something like that)
Haven't really seen any reviews though. But it's said they are made better.
__________________
  #9
Old 10-10-2017, 03:04 PM
jschildm's Avatar
jschildm jschildm is offline
Sergeant
Member's Gallery
Default
I am certainly no expert on the matter, but have seen where some people said that the NAPA Premium line was Spicer. I have the tie rod roll on my existing joints. For this reason, I recently purchased a drag link end and decided to try the NAPA Premium version. I still can't confirm its exact origin, but it has a stiffer boot that compresses as the joint is torqued that holds the joint in position well. When additional joints are required, I will be getting more NAPA Premium parts.
__________________
1997 F350 CCLB, 3" DP to 5" Straight Pipe, DIY Intake, 6.0 Tranny Cooler,Adrenaline, Irate Electric Fuel, Matt's Tunes and SD Seats ... IC and H2E sitting in the garage.
  #10
Old 10-10-2017, 04:08 PM
gnxtc2's Avatar
gnxtc2 gnxtc2 is offline
Major
Member's Gallery
Default
Wasn't there someone making a spacer for the drag link roll?
They all SUCK!!!!
The OEM ball joints are Spicers, the linkage is manufacturer specific.
There is a difference between FoMoCo parts and Motorcraft. Sometimes you can not get the FoMoCo parts. Example...the black factory batteries with the eye that came with the truck.
Billy T.
gnxtc2@aol.com
__________________
'97 Black F250HD SC, 3.55s, Punisher Trans, PI Converter, Dana 60 RSK w/ V & C SD springs, PIS 175/80s, T500, Cale's tunes, 910s, Smith Bros, ARPs, Fluidampr, IC, E-Fuel, 3" Plenums, CJC Traction blocks, HFHV IDM, T4/BASB, Horton, 268K
- 2016 F350 DRW Ultimate (stock for now )
- 1987 Buick Grand National (Staged)
- 2004 Mercury Marauder
- 1993 Geo Prizm (beater)
  #11
Old 10-10-2017, 04:41 PM
Sergeant
Member's Gallery
Default
Quote:
They all SUCK!!!!
Billy T.
gnxtc2@aol.com
I was the one making a spacer. I will post a pic later.
  #12
Old 10-10-2017, 04:42 PM
gnxtc2's Avatar
Major
Member's Gallery
Default
PM on how to obtain one.
Billy T.
gnxtc2@aol.com
__________________
  #13
Old 10-10-2017, 05:18 PM
79jasper's Avatar
Colonel
Member's Gallery
Default
Iirc, there's a company making them also.
__________________
  #14
Old 10-10-2017, 06:49 PM
Peroni's Avatar
Sergeant
Member's Gallery
Default
I have numbers 410-1033, 410-1034, 401-1425 and 425-1001 for the now defunct Raybestos Chassis parts. Weren't these made by Dana/Spicer? I can get a set of these "old stock" parts for just under $300, Motorcraft for just over $500 or Napa Premium for just under $600.
__________________
  #15
Old 10-10-2017, 07:17 PM
gnxtc2's Avatar
Major
Member's Gallery
Default
Raybestos is/was owned by Affinia- who also bought Spicer- the Pro quality are Spicer parts. Affinia sold the chassis line to Federal Mogul.
https://en.m.wikipedia.org/wiki/Affinia_Group
Billy T.
gnxtc2@aol.com
__________________
  #16
Old 10-12-2017, 06:06 PM
Sergeant
Member's Gallery
Default
Billy T.
gnxtc2@aol.com
Reading that I see that WIX filters now belong to Mann-Hummel.
Meantime Baldwin Filters now belong to Parker..........
I have pics of a tie rod roll eliminator I came up with. Poly washer, 2 machined "cups" No Roll. Couple hours on an old lathe for the washers.
__________________
  #17
Old 10-15-2017, 12:48 PM
Peroni's Avatar
Sergeant
Member's Gallery
Default
I purchased and installed the Motorcraft parts per the owner's request. The parts looked very nice, no indication as to who or where they were made on either the parts or boxes. They all fit fine, took the truck for an alignment and all is good. Tight steering again and no tie rod roll to speak of, owner is very happy. Be interesting to see how long these last. Truck is always heavily loaded and she puts a lot of miles on it going to horse events.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
