END OF YEAR SALE!!! 15% OFF EVERYTHING
jimdawg185
So, I don’t do much in the last half of December because I’m working in plants during outages.
While Im wrenching I don’t want to neglect yall. So....
15% off all lubricants. I also give 15% off all ancillary stuff to non oil customers. So if you don’t want my oil but wanted a transfer container or a ten pack of analysis kits with your own account here’s your chance to get stuff cheap.
Shoot me an email
[email protected] to get a quote
If you have my number, a text is good as well.
Strokersace
Towanda, KS
When's the cutoff?
I need to order gear lube, oil, trans fluid, and possibly another case of fuel treatment.
8WR_ZJ
Is there a shelf life on your products jim?
bluedge8
Champlin MN
I need to talk to you about my 7.3's and a 2015 t-250 3.5L ecoboost I blew up that I don't want to repeat. I will try to call today, but feel free to call me when you have a minute, thanks Dennis 763-370-----8534
If you want 15-40 for the 7.3s get 8700. If you are super worried about cold starts then maybe you want 5-40 8854 but i wouldn't be afraid to go with the 8700.
5-40 8854 in the eco boost too.. its amazing oil. I have been running it in our 6.0l gm gassers at work.
bluedge8
Champlin MN
Thanks Jake, I talked to Jim for a little while this morning and we got it all worked out, appreciate the help though! Thanks again Jim!
bluedge8
Champlin MN
Oh sweet. What did you decide?
8700 in the 7.3's, I don't drive them enough annually and try not to drive them in the salt. When I find out what the warranty is going to be on the long block for the EcoBoost I will decide on what to do with then but most likely will stick with the 5w30 because it meets Ford spec.
