Looking for options on an 08
DieselDC
I don’t know a whole lot but the 6.4 is a fun motor for play - just not for what you’re planning to do with it. You need a built 6.0 or a newer 6.7 for reliability reasons. Let the flames began :)
Mesa, AZ
We work on a ton of hotshot trucks from our forest service, quite a few are 6.4s, and are a major pain in the ass to work on, and they fail quite often. Majority of them are backup trucks for the 6.7 and cummins trucks. They are currently in the process of phasing most of them out, and i think there is only 1 or 2 6.0s left. Dont know if that helps your decision at all, but good luck.
Most of the ones that are chase trucks like you seem to be looking at, are gassers around here.
eng53ine
Ohio
Ok thanks it helps, I've seen many people on here advise to steer clear for normal use I could only imagine with this style of use.
eng53ine
Ohio
This is what our current setup was
This is what I was going for, but not gonna happen.
eng53ine
Ohio
They found a 6.0 with the egr gone, salesman told them that was the only problem 6.0 had. Only had 239k on the clock.
Mesa, AZ
The second picture is most of what i work on. Got a 6.4 one in the shop right now, had to send the head to the machine shop for broken exhaust manifold bolts after an ez out decided it wanted to break in one of thr bolts...
DEEZUZ
NO PUKESTERS
NWI
Just say no to ez outs LOL
DieselDC
That truck will need work but a lot better than the 6.4.
eng53ine
Ohio
That's no good
eng53ine
Ohio
When the build is ready - let us tag along! Love to see sick builds or at least any builds
Will do, hope you like duct tape, tie wire, and tarp straps. LOL
Mesa, AZ
Id love a better way. It was a snap on one if that makes a difference. Lol. Those stupid bolts wont hold a weld, dont know what theyre made of besides lost hopes and dreams... ****ing thing has been tying ul a bay for 3 weeks, between approval and the machine shop... :fustrate:
eng53ine
Ohio
Well I found these local, 2011 F350, 157k for $25k
And this one '11 350, 96k for $27k
Found a few others all with around 100k on the clock, all same to be around the same price just 2-3 hrs up the road.
Good prices for those with the mileage? Would over 100k miles be to much for 6.7?we won't put many on it.
100k is definitely not too much mileage but man, that's pricy imo
hawker25
is a 350 enough truck for what you wat to do? I ask cause we run 250 gallon tanks, which seems pretty standard on most brush setups. Fill that plus a pump, hose, hand tools, saws, and all the other gear and you add up pretty fast. We run 550's for our brush trucks.
