Suspension components question
046.ohBills
Middle Georgia
so i have a question. I have some what im sure are suspension components i dont like the looks of. Its attached to the bar behind the front axle and the bar behind it. it goes up from said bar to the frame. what is the real name of the bar from the sway bar to the frame?http://s1383.photobucket.com/user/Robert_Bills/media/28928612_2056549027958095_407383440_o_zps4ytlxinn.jpg.html?sort=3&o=0[/IMG]
[URL="http://s1383.photobucket.com/user/Robert_Bills/media/28832391_2056549034624761_1494750409_n_zpspg9f9hhp.jpg.html?sort=3&o=2"]
http://s1383.photobucket.com/user/Robert_Bills/media/28907637_2056549031291428_395333245_n_zpsywum5y6e.jpg.html?sort=3&o=1
[/URL]
046.ohBills
Middle Georgia
046.ohBills
Middle Georgia
thanks for the reply man. could they also be called stabilizer bar links? they look different in the pictures im searching. where the two ends are in opposite directions. (the threaded bolt i mean)
Joshf250
I’m not sure if they would be called that, are you trying to get new ones or find out a way to get rid of them?
046.ohBills
Middle Georgia
trying to order new ones from rockauto for my truck. dont trust the oreillys or advance auto near me since they have a reputation of getting the wrong parts
Joshf250
Ok well it should be under sway bar end links, and the bolts should be going on opposite directions
Joshf250
Actually they may go the same direction, it’s been a while since I’ve messed with them. Just double check on your truck.
046.ohBills
Middle Georgia
yea so what do i do i would like some to replace those because the bushing looked messed up. so whats the technical term for them?
Mesa, AZ
You need the whole end link. They may he called sway bar end links, stabilizer bar end links, anti roll bar end links, i dunno all sorts of different names depending on who you talk to.
The upper bolts will be different directions from eachother, but go the same way in the vehicle if that makes sense. Both upper bolts will be bolt inside frame, and nut ojtside frame
The lower bolts and nuts, and upper nuts get reused. I cant remember if your lower bolts are facing the correct way or not, but my gut says they are supposed to be the other way.
046.ohBills
Middle Georgia
thanks for the help on this noob question. found them andit was just that theres multiple names for them and the one that works the best (most accurate results) is stabilizer bar end links
