Go Back   PowerStrokeArmy > Power Strokes > 7.3 Tech
Reply
Thread Tools Display Modes
  #1
Old 05-17-2018, 08:13 PM
2000f350intheworks's Avatar
2000f350intheworks 2000f350intheworks is offline
Private
Member's Gallery
Exclamation please help 7.3 problems
Ok im completely stumped first i took valve covers off and did injector cups as i had diesel in my coolant so i had my batterys unhooked pos and neg both sides the whole time i work from 4:30am to 5pm everyday and half day on saturdays so it took me about a week to do them well i got them done and put everything back together how it went hooked batterys up and went to start it and it was dead so i put the charger on the battery overnight and all day till i got home from work went to start it again and i get a click then bam its dead the click is coming from the glow plug relay so i unhooked all the wires to the glow plug relay and still wont startbut the part i dont understand is the back two glow plugs were unplugged on the passenger side so what should i do go back in and unhook them but i cant see why that would cause it to not start not even crank starters brand new batterys are a little older but not years old
  #2
Old 05-17-2018, 08:23 PM
DieselJpower's Avatar
DieselJpower DieselJpower is offline
Lieutenant
Member's Gallery
Default
Starter fuse maybe
__________________
Josh
02 CCSB F350 4x4 -- GONE
04 Excursion 4x4 -- GONE
05 Excursion 4x4
19 CCSB F350 4x4
  #3
Old 05-17-2018, 08:26 PM
Private
Member's Gallery
Default
It wont even start with jumping the starter solenoid i tried itll spark like its going to then nothing
  #4
Old 05-17-2018, 08:28 PM
Lieutenant
Member's Gallery
Default
If the brand new starter has never fired the truck, could be a doa
__________________
Josh
05 Excursion 4x4
19 CCSB F350 4x4
  #5
Old 05-17-2018, 08:32 PM
Private
Member's Gallery
Default
See everything started perfectly fine before i did the cups and thats when i noticed the two back glow plugs were unhooked so i plugged them back in and put everything back together how i took it off then bam nothing no start the wait to start comes on i try starting it then it clicks and if i try to start it again it seems the batterys are dead even on the charger
  #6
Old 05-17-2018, 08:55 PM
Lieutenant
Member's Gallery
Default
Got a volt meter ?
__________________
Josh
05 Excursion 4x4
19 CCSB F350 4x4
  #7
Old 05-17-2018, 09:06 PM
79jasper's Avatar
79jasper 79jasper is offline
Colonel
Member's Gallery
Default
What did you do to get the coolant/oil/fuel from the cylinders?
Sent from my SM-G892A using Tapatalk
__________________
2003 F250 KR SCSB FX4
Depleted, studded, airdog (which isn't currently hooked up), fass regulated return, airaide, 4 inch straight pipe with mbrp muffler(so on to go), glowchit pyro, fuel, boost, and trans temp. (Of course don't work lol) Hercules terra track A/T2 315/70/17.
2013 Honda pilot Touring
http://badges.fuelly.com/images/sig-us/778639.png
http://badges.fuelly.com/images/sig-us/776628.png
  #8
Old 05-17-2018, 09:45 PM
DieselDC's Avatar
DieselDC DieselDC is offline
Sergeant
Member's Gallery
Default
With all things being fair and common sense already checked off the list...
I assume liquids has been evacuated from cylinders by removing glow plugs and rotating the crank a few times...
Check your batteries for proper voltage. Battery amperage tester is even better. Make sure they are connected firmly to the posts.
Check fuse to the heater element inside the fuel bowl as this shares power to your pcm
Then go through all your wiring and make sure all sensors are plugged in
Make sure the starter has tight connections for ground and +.
You don’t necessarily need your gps to start the truck.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
  #9
Old 05-18-2018, 03:07 AM
Dirtclod's Avatar
Dirtclod Dirtclod is offline
Lieutenant
Member's Gallery
Default
I don’t think there’s anything as far sensors that will keep the starter from turning over. Maybe that isn’t the glow plug relay that’s clicking. There’s also a starter solenoid right beside it if you have a super duty. Not as familiar with obs trucks. Dead ass batteries with 200 amp boost would at very minimum turn the starter. Check the bats,use a meter and check the starter side of the solenoid while someone cranks. If you don’t have voltage there solenoid fix. If so check it at starter. And check all the grounds. 99 % of the time I’ve had electrical iaaue on DC it’s a ground.
__________________
01 F-250 4x4 cc/sb 238/100 inj,adrenaline hpop,reg return fuel system,s&b intake,4” elec conduit straight back exhaust,KC stage 1 turbo,hd built auto tranny,pohp hydra chip custom tunes,still needs alot it’s work in progress.
  #10
Old 05-18-2018, 06:58 AM
Private
Member's Gallery
Default
Ill check all that guys thank you its a 2000 f350 7.3 no glow plugs were removed the two back ones on pass side were unplugged the caps that go over the glow plugs so i plugged them back in and ever since i did that the front solenoid ontop of the motor clicks i had my wife try and start the truck it clicks then the batterys seem dead everything goes very dim had two different chargers on the batterys and still seemed dead when i go to try and start it
  #11
Old 05-18-2018, 07:04 AM
DieselDC's Avatar
Sergeant
Member's Gallery
Default
Well unplug the two gp like it was b4 and see what happens.
Something is not allowing the complete circuit btwn battery and starter. If you take the good batteries and connected them straight to the starter, you’re gonna get some cranking and that’s a guarantee.
—————signature—————
  #12
Old 05-18-2018, 08:24 AM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
make sure you got the oil and coolant out of the cylinders before trying to start it or you may have bigger problems on your hands...
  #13
Old 05-18-2018, 08:34 AM
79jasper's Avatar
Colonel
Member's Gallery
Default
Quote:
That's what I was asking. But apparently it's better to assume he did. Even though he said he never removed the glowplugs.....
__________________
  #14
Old 05-18-2018, 01:40 PM
jpow95 jpow95 is offline
Corporal
Member's Gallery
Default
Pull the glow plugs out and see it’ll turn over
  #15
Old 05-18-2018, 01:43 PM
Corporal
Member's Gallery
Default
By hand
  #16
Old 05-18-2018, 02:37 PM
Arisley's Avatar
Arisley Arisley is offline
Mod Squad
Member's Gallery
Default
Best advice so far.
__________________
E99 ECLB Dually, 2010 bed, 2005 headlights, smoked clearance lights, 2001 cup holder.
365,XXX miles. Pure stock, sorta.
SDRCM #478
PSA Conspirator # 22
  #17
Old 05-20-2018, 06:39 PM
Private
Member's Gallery
Default
I got er runnin now thanks for all the help guys really appreciate it was hydrolocked so i sucked everything out of the cylindars on top of the pistons and put it all back together and hand cranked the crank a couple times then got it runnin but now i noticed that it takes a little while to strt it cranks really fast for about 20 seconds then itll start any ideas
  #18
Old 05-20-2018, 06:40 PM
Private
Member's Gallery
Default
No i didnt remove the glow plugs the site wouldnt let me reload it so i havent been able to see everyones comment
  #19
Old 05-20-2018, 06:46 PM
dsberman94's Avatar
dsberman94 dsberman94 is offline
General
Member's Gallery
Default
Just air. It’ll go away
__________________
02 F250 7.3 Crew Cab Short Bed Lariat
PHP Hydra, Ge4rhead tunes, Edge insight CTS monitor
Mild Trans Build, Dual disc TC
GTP38R, T500, PIS 175/80s in the engine. waiting to see rods one day
Turned 200k miles 1/18/2015
  #20
Old 05-20-2018, 06:51 PM
Private
Member's Gallery
Default
Ok thanks so much really appreciate it sounds so muh quieter and smoother its just a stock truck with tony wildman tunes on a ts 6 position chip 6637 air filter halo leds smoked taillights gauges 2017 rims and tires 2” spacers
  #21
Old 05-20-2018, 09:05 PM
79jasper's Avatar
Colonel
Member's Gallery
Default
And that's why I don't assume people "know" what they're doing. Lol
As said above, you'll have to work the air out.
__________________
  #22
Old 05-20-2018, 10:44 PM
DieselDC's Avatar
Sergeant
Member's Gallery
Default
Yes that would be me “assuming” the OP evacuated the cylinders. I assumed such and at the same time, in the same post, I gave solutions on how to correct it if my assumptions were wrong.
I gave the op the benefit of the doubt but I guess I gave too much credit to start with. Regardless, trucks running.
—————signature—————
  #23
Old 05-20-2018, 10:45 PM
DieselDC's Avatar
Sergeant
Member's Gallery
Default please help 7.3 problems
Quote:
You should look into a hydra chip.
—————signature—————
  #24
Old 05-21-2018, 04:26 AM
dsberman94's Avatar
General
Member's Gallery
Default
The chip he has is fine. Doesn’t sound like he’s really into modding it since pulling injectors to replace cups would have been the perfect time to upgrade them.
__________________
  #25
Old 05-27-2018, 02:16 PM
Private
Member's Gallery
Default
whats the hydra chip tony wildman said i could upgrade it to the hydra chip but i had no idea what it was never had a powerstroke only owned a duramax lb7 with efi and a 98.5 cummins that was stock
  #26
Old 05-27-2018, 03:13 PM
DieselDC's Avatar
Sergeant
Member's Gallery
Look it up. Get tunes through email. Worlds better than a ts chip even with stock sticks.
—————signature—————
  #27
Old 05-27-2018, 07:02 PM
Private
Member's Gallery
Default
Ill have to look into it see i dont like the ts chip if i dont hammer the throttle my truck shifts hard on all settings idk why
  #28
Old 05-27-2018, 07:05 PM
DieselDC's Avatar
Sergeant
Member's Gallery
Default
Canned tunes.
—————signature—————
  #29
Old 05-27-2018, 11:15 PM
gnxtc2's Avatar
gnxtc2 gnxtc2 is offline
Major
Member's Gallery
Default
All tunes are canned unless live tuned
Billy T.
gnxtc2@aol.com
__________________
'97 Black F250HD SC, 3.55s, Punisher Trans, PI Converter, Dana 60 RSK w/ V & C SD springs, PIS 175/80s, T500, Cale's tunes, 910s, Smith Bros, ARPs, Fluidampr, IC, E-Fuel, 3" Plenums, CJC Traction blocks, HFHV IDM, T4/BASB, Horton, 268K
- 2016 F350 DRW Ultimate (stock for now )
- 1987 Buick Grand National (Staged)
- 2004 Mercury Marauder
- 1993 Geo Prizm (beater)
  #30
Old 05-28-2018, 07:36 AM
Arisley's Avatar
Mod Squad
Member's Gallery
Default
If you had a Hydra, you could call Tony and tell him the issues you are having with your tunes. He could email adjust your tunes, email them to you, you could load them on the Hydra chip yourself.
__________________
SDRCM #478
  #31
Old 05-28-2018, 07:39 AM
DieselDC's Avatar
Sergeant
Member's Gallery
Default
Quote:
Billy T.
gnxtc2@aol.com
Not everyone can have it lived tuned. Custom tunes would be your best bet.
—————signature—————
  #32
Old 05-28-2018, 07:43 AM
sootie's Avatar
General
Member's Gallery
Default
Quote:
—————signature—————
Thats his point. Any file prepared without physically having the truck is a canned tune.
  #33
Old 05-28-2018, 07:59 AM
Arisley's Avatar
Mod Squad
Member's Gallery
Default
While i pretty much agree with you, especially at this point and time in the lifespan of the 7.3 and the amount of tunes that experienced tuner have written. They can take one of their tunes, do some custom tweaks to it and email it to you. At that point it is a custom, not a canned tune, you are the only one with that particular tune. However, when the tuner clicks on file and save as, it now becomes a canned tune the next time a customer is having the same issue.
Probably, when you call said tuner and complain about your issues with your tune, he will look at his file and see Tune XXX with softer shifting, hmm, exactly what my customer needs. Then you are getting a canned tune.
Even live tuning starts out with a canned tune, and then custom tweaks are added to make it perfect for your particular truck and driving habits and needs.
__________________
SDRCM #478
  #34
Old 05-28-2018, 08:13 AM
DieselDC's Avatar
Sergeant
Member's Gallery
Default
Exactly so... best thing would be custom tunes. At least it’s not 100 cookie cutter files like what hydra has on their server. Tuner can at least change here and there based on knowledge/experience of live tuning.
—————signature—————
  #35
Old 05-28-2018, 08:15 AM
DieselDC's Avatar
Sergeant
Member's Gallery
Default
Dammit no like button...
#like
—————signature—————
  #36
Old 05-31-2018, 02:41 AM
superpsd's Avatar
superpsd superpsd is offline
Major
Member's Gallery
Default
It's still custom tuning. It just may take some data logging and going back and forth with a tuner to get it dialed in. Also every tuner has different tricks. Live tuning is custon tuning it just allows for the truck to be tuned faster and dialed in on a dyno if they are using one (you dont need a dyno to live tune you just need the correct chip)
__________________
97-250 7.3 Eaton TVS Supercharged, S369sxe, R&D IDI performance T4 mount, my B350/200s, Honey Badger SR with My tunes, BMW M3 seats, Sky 5" RSK skyjacker drop pivot brackets, Sky shackles and hangers, Toyo M/T
1948 GMC Detroit 453T
1951 Mack A51T
1916 Federal 1 1/2T
  #37
Old 05-31-2018, 10:25 AM
dmd's Avatar
dmd dmd is offline
Lieutenant
Member's Gallery
Default
Gauges?
It can run hot EGT with tunes and stock exhaust
__________________
2k, F350 SuperCruzer, 7.3L Diesel, Auto trans, 4x4, GH Tunes w/160/30s, S&B cold air intake, 4-inch turbo-back exhaust, Garrett 38r, Adrenaline HPOP, BTS Transmission w/6.0 cooler, Swamps IDM(broke, back to stock), AIC, in-tank and pre-pump mod, Heater valve mod, X-car sound panel mod
  #38
Old 06-02-2018, 05:02 AM
Private
Member's Gallery
Default
Got gauges and a 4” turbo back to a 8” tip axle dumped
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
