Sotf and ezlink?
Magicman129
Pasadena, MD
I just put on the ezlink w/ tyrant and sotf from no limit, everything seems good with the tunes, especially 3-5, 1 and 2 the trans shifts a little wierd, however the sotf setting does not show in the ezlink, it says it is on 5 all the time. Is this a switch or ezlink issue? Also the boost seems a little high I have seen almost 35psi on 5 and over 30 on level 1
Bryce_fow
I have there tunes on a sct mine shift crazy sometimes too and my boost is the same I can’t tell you if it’s to high or not but it’s not just yours ha
Magicman129
Pasadena, MD
I wish some of the experts would chime in on that, I know I don't want to be banging head gaskets out on this thing. On my duramax over 30 was not good with out head studs
Bryce_fow
From what I have been told is it is fine on them to not worry and drive it haha
Head gaskets are the last thing you need to be worried about....
Sent from my SM-G955W using Tapatalk
Seriously contemplating one of these trvcks. What kinda power can they hold stock?
If you have the air and fuel to make the power, 11-16 bottom ends are good to around 700 and 17+ mid 700s
Magicman129
Pasadena, MD
I found the answer by calling no limit today and figured I would share just in case anyone else has the same question, if you have ppei thru ezlink it will show in the ts tile with tyrant it will show in the charge air temp tile
16=1
19=2
21=3
24=4
27=5
Or something close to that, and it has to read in celcius I believe
Magicman129
Pasadena, MD
So, after about 2 weeks and 500 miles the tunes seem good I just don't like the trans shifts at all, do I need some other software to reset the kam everyone is talking about, or do I need to contact tyrant directly or no limit. I feel like it upshifts too slow( drags the gears out) and down shifts too slow like still in 3rd at like 10 coming to a stop. I never disconnected the battery. Should this be done, I have just drove it, mostly on the 30 and 65hp tunes
You need someone with IDS to do a KAM reset
Magicman129
Pasadena, MD
I have Maryland performance diesel close to me I guess I can check to see if they have IDS. Dealer is definitely not an option
ToddP
Midland, TX
I have Tyrant tunes w/SOTF also and I used to run in the second setting all the time but I was the same as you the trans felt weird. I didn’t care for the way it shifted at all. I flipped it up to the third setting and it’s perfect. I go back to the first setting when I pull but I daily drive on the third or 4th setting.
